[Case Mod] [COMPLETE] December MOTM 2nd Place! - Relic: A BeigeMod First Case Mod - Page 38 - Overclock.net - An Overclocking Community
post #371 of 512 (permalink) Old 11-14-2014, 09:47 AM
sinnedone's Avatar
Rep: 74 (Unique: 57)
You can either constantly disassemble and reassemble while he's not using it or possibly find some non working parts to mock things up.
sinnedone is offline
post #372 of 512 (permalink) Old 11-14-2014, 12:13 PM - Thread Starter
Rep: 30 (Unique: 22)
Thanks. Checking out ebay for a broken/semifunctional mobo of the same type.
Any thoughts on sleeving? This will be my first attempt, and I have a semimodular PSU.
I found this:
1-8-EXPANDABLE-SLEEVING-BLACK-RED-SPIRAL-TECHFLEX-25ft
ModSmart_Kobra_MaxCord_High_Density_Paracord_16_-_18AWG_Sleeving_18_-_Black_-_100_Foot_Spool
Or Lutro0's Teleos with a combination of blacks and reds:
http://modbunker.com/shop/cable-sleeving/lc-teleios-dark-red-25ft/
Any thoughts?
Maybe something like this?
Jhereg10 is offline
post #373 of 512 (permalink) Old 11-14-2014, 01:19 PM
Rep: 5 (Unique: 4)
Originally Posted by Jhereg10 View Post
Would like some advice here.
Oh that's just nasty... if only there was a way at some point to turn that into a nicer case... *taps fingers on table* hmmm.....
Either way, what i'd do is finish as much of the case as you can until it gets time to finish the work by putting the final guts in it. If he really needs a computer by then, he could use a spare system or maybe your sig rig.
vaatibal is offline
post #374 of 512 (permalink) Old 11-14-2014, 01:23 PM - Thread Starter
Jhereg10 is offline
post #375 of 512 (permalink) Old 11-14-2014, 01:25 PM
Linux Lobbyist
Buehlar's Avatar
Rep: 89 (Unique: 70)
The Techflex is a stretchable mesh type that is good for sleeving multiple wires into a single sleeve.
The other two brands are great for sleeving individual wires.
I used the non-paracord variant of Kobra for some of my sleeving on Mid-Lif Cry-Sys, nice quality and easy to work with.
Although I've yet to try it, Lutro0's is highly praised by the pros throughout the modding community.
Here's a great thread with tons of helpful info... https://www.overclock.net/t/662039/cable-sleeving-gallery-discussion
Buehlar is offline
post #376 of 512 (permalink) Old 11-14-2014, 02:37 PM - Thread Starter
Thanks. That's very helpful.
Jhereg10 is offline
post #377 of 512 (permalink) Old 11-14-2014, 08:30 PM - Thread Starter
Got the temporary motherboard back in, and played around with wiring and lighting a bit.
AppleMark
AppleMark
In that last shot, you can see that I added a paper diffuser across the mobo brace to soften the light from the LEDs imbedded in it.
Jhereg10 is offline
post #378 of 512 (permalink) Old 11-15-2014, 04:12 AM
Rep: 35 (Unique: 29)
As for sleeving, I haven't tried it myself (with proper paracord) so I can't say what the various Options are like to work with but the stuff from Lutr0 Looks the best because the colours are nicer and it has a finer weave than the stuff from frozen CPU. I think the techflex Looks the worst of the three.
Have you done sleeving before?
BruceB is offline
post #379 of 512 (permalink) Old 11-15-2014, 09:34 AM - Thread Starter
I have not done any sleeving before, so this is totally a new thing for me. Wish me luck man, I'm going in!
I've now shied away from the Techflex. It's apparently more for bundles of wires and not as good for individual sleeving.
I've decided to settle on paracord.
I opted to get a black with a reflective accent for the base cord, and a sampling of several reds for accent colors (because it's difficult to really see what the colors will look like on the screen):
I'm buying the "helper tool" from Lutro0 Customs and getting the paracord from West Coast Paracord and I already own some pin removal tools. I'm also buying some cable combs, probably from Lutro0 as well.
Unfortunately they don't have a burgundy or merlot, so I may end up getting some more paracord elsewhere. It's cheap enough and useful enough I don't mind buying extra.
On a side note, I've decided to go ahead and assemble the case "as is" for my son to start using it. The little begger stopped by to check on progress, and announced he was done waiting and wanted to start using the case. tongue.gif
Except for the front panel work, I think I can do most of the rest of the work by swapping out components at this point. I have a spare PSU I can put in it, so I can keep the PSU out for sleeving. I can also get spare sata data and power wires and such for sleeving and swap those out as needed, and take fans out one by one for sleeving if I need to. I can also finish the PSU cover and logo outside the case, so that's not an issue.
I think I will focus this weekend on finishing up the front panel (power and reset buttons) and installing the IO panel and fan controllers.
On a side note, I'm seriously considering switching the location of the backlit RELIC logo. I had thought to put it on the PSU cover. But now I'm considering moving it to the front panel in one of the empty 5.25" bays.
So top to bottom would be:
RELIC logo
Fan Controller
IO Panel
Power and Reset
Unless anyone thinks I should change that order around. I'll post some pictures later today or tomorrow with several options. Any thoughts?
Jhereg10 is offline
post #380 of 512 (permalink) Old 11-15-2014, 08:11 PM - Thread Starter
58. When Patience Wears Thin - Transplanting the Computer to the Case
Well my son's patience truly ran out, so I opted to transplant the internal components into the nearly completed case and swap out the remainder of the components as I finish them.
First I removed the "placeholder" motherboard and took out the PSU. The plan is to keep the PSU out and sleeve it while it's out, and use the backup PSU in the build. Or maybe the other way around in reverse.
AppleMarkAppleMark
And here's the motherboard and IO shield installed and the power and reset buttons wired up. I opted to wait on installing the front IO panel to give me time to sleeve it first. I also made sure the control plate for the cold cathode was installed in the lowest PCI slot and slipped under the motherboard.
AppleMark
You'll notice this is an mATX board. That's actually a real benefit for this case with the GPU mod, as we'd be blocking the top 2-3 PCI slots with the top radiator anyway. Which brings me to the trickiest part, installing the GPU.
I had two options, either install the card first, and then the radiator, or vice versa. I opted to install the radiator first in order to ensure I had plenty of room to work. That turned out to be the right choice.
AppleMark
And then the card itself.
And... the GPU plugged in, drives installed, and everything powered up.
AppleMark
And let's see if everything powers up properly:
AppleMark
And with the side panel on and the logo stuck in there. No that's not where it's going to be in the end. rolleyes.gif
AppleMark
Hmm.. I just realized something else I need to fix. The mobo tray flip means the GPU is now upside down. I need to redo the logo so it's not upside down! And the location makes the GPU power cables too short. I need to make an extension so I can properly route it behind the mobo tray.
And an angle shot to get a look at the overall effect.
AppleMark
The boy is most pleased. Just don't ask for a photo of the back of the case at the moment. I haven't done ANY cable management. LOL. And of course all the other stuff that needs done.
Jhereg10 is offline
