[Case Mod] [COMPLETE] December MOTM 2nd Place! - Relic: A BeigeMod First Case Mod - Page 47 - Overclock.net - An Overclocking Community
post #461 of 512 (permalink) Old 12-18-2014, 11:12 AM - Thread Starter
Rep: 30 (Unique: 22)
66. Front Panel Finishing Touches
After considering the excellent advice here, I took into account the time available and decided to flip the power switch to the right, and to address the clashing IO box color scheme. I hope you agree that it was the right choice, considering my time constraints.
Here's where I started:
AppleMark
I decided that my first task would be to pop off that front panel from the IO box and paint it to match the finish of the other components.
AppleMark
It came off pretty easy. Little clips along the perimeter, and one connector for the power switch. Couldn't easily remove the power switch.
AppleMark
So I just masked it off.
AppleMark
And a couple coats of Krylon Fusion, same stuff I used on the bay covers.
AppleMark
And I think the final product on the plate looks much better.
While I had it off, I painted some of the visible metal and plastic bits on the IO Box with a small brush, so when I replaced the plate, the red accents would show through and match the existing paint scheme.
AppleMark
And here is the finished product. I think it's a big improvement over the before shot. I really appreciate the advice you guys gave me. I may still go forward with a flip-out cover at some point.
Jhereg10 is offline
post #462 of 512 (permalink) Old 12-18-2014, 11:30 AM - Thread Starter
67. Wire Management Woes
Well I'm really crunched for time at this point, and I'm having serious issues with wire management. It really comes down to the fact that all the components have far too many excess wires, or in some cases the wires are too short. As a result, even with the bumpout I added, there's just no way I can cram it all in back there, much less make it as neat as I want.
Here's what I have to deal with:
AppleMark
Ugly as sin. You may notice I removed the cold cathode inverter from its case. Also if you are wondering about the blue tape, that's to remind me of where the boundaries of my bumpout are so I don't try to leave wiring sticking up outside that area.
AppleMark
The case was simply too tall. The other issue is that the cold cathode wire from the inverter to the tube is too short to get it where I want it. It leaves it right at the edge of the bumpout (now I wish I'd made that slightly bigger and deeper, lol)
AppleMark
I also need to do something about the annoying blue LED.
And some closeups of rats-nest wiring.
AppleMarkAppleMark
After some work, I managed to make some improvement, but it's still too bulky to get the back cover on:
AppleMark
I think I'm going to be spending tonight cutting, splicing, and soldering wires to get them all arranged nicely. I may also have to widen the hole for the PSU wires coming into the back side of the case. mad.gif
Of all the things that are going wrong, I think these are looking pretty nice:
AppleMark
AppleMark
Jhereg10 is offline
post #463 of 512 (permalink) Old 12-18-2014, 12:00 PM
*cough* Stock *cough*
Nukemaster's Avatar
Rep: 129 (Unique: 101)
Wire management is always fun with extras in the case.
If the LED bugs you, you may be able to swap the resistor or just remove the led all together.
Gaming
(15 items)
Media Center
(17 items)
2600K @ 4.4
Maximus IV Gene-z
Asus Dual 1070 OC with Artic Mono Plus
G.SKILL F3-1866C9D-16GXM Ripjaws X 16GB
M4 256
MX 300
Optical Drive
Liteon Slot load
Corsair 850HX
H80i
Silverstone FT03
Operating System
Windows 7 HP 64 bit
BenQ XL2420Z
Keyboard
Logitech G810 Orion
Mouse
Logitech G502
Audio
X-fi Titanium Fatality
i5 750
h55n usb3
msi gtx 650 ti
Corsair XMS3 CMX8GX3M2A1600C9
WDC Red 3tb
M4 128
WDC scorpio Blue 2.5
Optical Drive
Sony AD-7690H-01
FSP SFX 300 watt
Geminii S
SG05
Operating System
Windows 7 HP 64 bit
SyncMaster 245t
Keyboard
Logitech Wave
Mouse
Logitech G9
Audio
Sound Blaster Omni
Other
HD PVR
Nukemaster is offline
post #464 of 512 (permalink) Old 12-18-2014, 12:13 PM
PurdueBoy's Avatar
Rep: 70 (Unique: 63)
Depending on how the circuit is built it might be something as simple as unsoldering the led and tossing it out, I'm not electronic expert so I'd usually shy away from that unless things are really simple. I've had good luck on slapping a little bit of black acrylic paint on external LEDs that I want to hide. Makes it look really clean and is alot nicer than slapping electrical tape over them. LEDs don't get too hot, but there is a certain amount of heat involved.
I mean when you think about it removing the LED shouldn't do anything, if it did that means if the bulb burnt out the entire circuit wouldn't work? Seems like circuits wouldn't be designed like that.
PurdueBoy is offline
post #465 of 512 (permalink) Old 12-18-2014, 03:26 PM
ReaperN1's Avatar
Rep: 42 (Unique: 29)
Ironically I'm working on cable management designs right now as well. It's an almost never ending endeavor. For me it works best if I start at one end and work my way to the other. Keep up the good work buddy.
"wнy ғollow ѕoмeone elѕeѕ paтн, wнen yoυ can rυn ѕcreaмιng тнroυgн тнe woodѕ and мaĸe yoυr own."
-n1
"A wise man can learn more from a foolish question then a foolish man can from a wise answer."
-BL
ᗷᑌIᒪᗪᔕ ↴Warning: Spoiler! (Click to show)
ReaperN1 is offline
post #466 of 512 (permalink) Old 12-18-2014, 09:40 PM - Thread Starter
Thanks guys. Since it wasn't exactly an overly expensive inverter, I'm going to go ahead and desolder the LED and see what happens. Won't be able to get to it before the competition though. With the holidays and all, I think the family will not appreciate me barricaded in the workshop muttering to myself. wink.gif
Thanks Reap. I just finished what I would call a "hack and slash" cable management session. Basically all I did was cut out any unneeded wiring, splice in a few extensions, and try to neaten everything up as best I could. It's nowhere near where I want it, but it's miles ahead of where I started. Any further modifications will have to wait until after the holidays and after MOTM competition.
I just got through taking photos of the finished (for now) product. I'll be posting them side-by-side with some "here's where I started" photos tomorrow. But here's a few teaser photos.
AppleMark
AppleMark
AppleMark
Jhereg10 is offline
post #467 of 512 (permalink) Old 12-19-2014, 06:36 AM
Dortheleus's Avatar
Rep: 9 (Unique: 9)
Very well done sir. Be sure I'll be voting for you as soon as Voting starts. thumbsupsmiley.png
“Who’s the more foolish; the fool, or the fool who follows him?”
“That… is why you fail.”
“It’s worse.”
“That’s no moon.”
“Sorry about the mess.”
Dortheleus is offline
post #468 of 512 (permalink) Old 12-19-2014, 12:02 PM
GerbenWerkhoven's Avatar
Rep: 6 (Unique: 6)
Good old Cooler Master 690 II is getting some love. TOPIC HERE: CM690 II overhaul rolleyes.gif
GerbenWerkhoven is offline
post #469 of 512 (permalink) Old 12-19-2014, 12:13 PM - Thread Starter
68. COMPLETE (For Now) Before and After Shots
This log, in many ways, has been about resurrecting the castoffs of days gone by. And in many ways, I owe it all to Overclock.net. I discovered this site after buying my first set of components in years to replace an old store-bought PC and was inspired and blown away by the mods here.
Many of the techniques I used (often imperfectly) I learned from seeing what others here had done. And in a real way, this mod is due directly to OCN. Most of the internal components in the mod were purchased directly though the OCN marketplace to build this, my son's first PC, including:
  • GPU Galaxy GTX480 moded with an Antec Kuhler AIO from coachmark2
  • Motherboard GA78LMT-USB3 from lapengu
  • CPU AMD FX6400 from lapengu
  • RAM Crucial Ballistic Sport 2x4 GB from irush
  • PSU Corsair HX520 Semi-Modular from slider46
  • Corsair SP120 Quiet Series Fan, Fan Extensions, and 4 LED Puck from slider46
  • SSD Samsung SSD 830 128gb from crazyg0od33
  • Fan Controller NZXT Sentry Mesh from whodie
So let's get to it. What the heck did I do? I resurrected the dead, that's what I did. The following photos are highlights from this log showing what I did to the decade+ year old case. It was a wild ride, and I hope you enjoy it.
Front View:
Original:
Modded:
AppleMark
Frontside Exterior View:
Original:
Modded:
AppleMark
Backside Exterior View:
Original:
Modded:
AppleMark
Rear View:
Original:
AppleMark
Modded:
AppleMark
Top View:
Sorry no original. Here's the modded view:
AppleMark
Frontside Interior View (Empty):
Original:
Modded:
AppleMark
Backside Interior View (Empty):
Original:
AppleMark
Modded:
AppleMark
Interior Wiring:
Original:
AppleMark
Modded:
AppleMark
3.5" Drive Bay:
Original:
AppleMark
Modded:
AppleMark
PSU:
Original:
Modded:
AppleMark
Custom Stuff:
PSU Cover Scratchbuilt:
AppleMark
Two-tone paint job, wrapping around the side and top panels:
AppleMarkAppleMark
AppleMark
AppleMark
Wiring Management Panels Scratchbuilt:
AppleMarkAppleMark
AppleMark
And here's why I needed those panels.
AppleMark
Detail Closeups:
AppleMark
AppleMark
AppleMark
AppleMark
AppleMark
AppleMark
AppleMark
AppleMark
AppleMark
A few more beauty shots:
AppleMark
AppleMark
Jhereg10 is offline
post #470 of 512 (permalink) Old 12-19-2014, 04:53 PM
Linux Lobbyist
Buehlar's Avatar
Rep: 89 (Unique: 70)
Front View:
Original:
Modded:
AppleMark
Original:
Modded:
AppleMark
Original:
Modded:
AppleMark
Rear View:
Original:
AppleMark
Modded:
AppleMark
Top View:
AppleMark
Original:
Modded:
AppleMark
Original:
AppleMark
Modded:
AppleMark
Interior Wiring:
Original:
AppleMark
Modded:
AppleMark
3.5" Drive Bay:
Original:
AppleMark
Modded:
AppleMark
PSU:
Original:
Modded:
AppleMark
Custom Stuff:
AppleMark
AppleMarkAppleMark
AppleMark
AppleMark
AppleMarkAppleMark
AppleMark
AppleMark
Detail Closeups:
AppleMark
AppleMark
AppleMark
AppleMark
AppleMark
AppleMark
AppleMark
AppleMark
AppleMark
AppleMark
AppleMark
Buehlar is offline
