[Case Mod] [COMPLETE] December MOTM 2nd Place! - Relic: A BeigeMod First Case Mod - Page 52 - Overclock.net - An Overclocking Community
post #511 of 512 (permalink) Old 09-06-2015, 01:37 PM
AMD Overclocker
Alastair's Avatar
Rep: 261 (Unique: 163)
Originally Posted by Jhereg10 View Post
Originally Posted by Alastair View Post
@Jhereg10 I just wanted to pop in and thank you again for this wonderful build. I am rebuilding my machine and had some ideas for my Phantom 820 case. So I was going through your build log again looking for some ideas and inspiration. And guess what I found it.
Ideas I had.
Make PSU cover. Thanks to you. I now know I will use Foam Board to do it!
Cable grommets. Thanks to you I decided to do my own grommets like you. But no wait. That wasn't enough. So now I am going to use foam board to make my own cable shield/ cover to help cover the cables. This will also double as an SSD mount for me as well!
So thank you. This whole time I wasn't sure what I would use to make the PSU cover and cable cover. But now I do. So thank Ye!
BTW how did you mount the PSU cover to the inside of the case? Screwed in? How is it secured?
I'm very glad that you found use in my build log. That was my main motivation when I started it. redface.gif
As far as mounting the PSU cover, it just sits in place on mine. There wasn't anything needed to lock it down.
I see. I would probably want to have mine secured though. Also how durable do you find foam board? Like does it bend or damage easily?
If You Can Cool It! You Can Clock It! (AMD's Vishera)
GHOST rev 4
(26 items)
Rura Penthe
(12 items)
AMD Ryzen 7 3800X
Gigabyte Aorus X570 Pro Wifi
MSI VEGA 64 WAVE
Avexir Core 2 3600MHz 18-20-20-44
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
Samsung Spinpoint HD502HI
CoolerMaster V1300 Platinum
XSPC D5 Bay Res
1x CoolerMaster Storm Force 200
XSPC Raystorm CPU Block
EKWB Coolstream PE360
6x CoolerMaster Jetflo's 120mm
XSPC D5 Vario
EKWB Coolstream CE280
6 Corsair ML140's
Barrow Vega 64 full cover waterblock.
NZXT Phantom 820 Black
Operating System
Windows 10 Pro 64-Bit
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
GX Gaming SW-G2.1 3000
Audio
Kingston Hyper X Cloud Core
AMD Athlon 860K
Asus A88X-Pro
MSI R6850 Cyclone Power Edition
G-Skill Ares 2133 CL10 8GB (2x4GB)
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Arctic Cooling Freezer A30
Corsair Carbide SPEC-02
Operating System
Windows 10 Home Edition 64bit
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte RX580 Gaming 4G
Gigabyte RX570 Gaming 4G
XFX RX480 reference edition 8G
Gigabyte RX570 Gaming 4g
G-Skill Ares F3-1600C9D
Samsung 750 Evo 120GB
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #512 of 512 (permalink) Old 09-06-2015, 03:23 PM - Thread Starter
Rep: 30 (Unique: 22)
I'd call it moderately durable. If you press with some force on it with a fingernail, it will cause an indentation there but won't break or buckle it. The vinyl wrap helped with that.
Overa it is very lightweight, easy to work with, and not extremely tough.
Jhereg10 is offline
