[Case Mod] [COMPLETE] December MOTM 2nd Place! - Relic: A BeigeMod First Case Mod - Page 8 - Overclock.net - An Overclocking Community
post #71 of 512 (permalink) Old 06-05-2014, 03:27 PM - Thread Starter
Rep: 30 (Unique: 22)
23. BEZEL SPOT FILLING - A LITTLE DAB'LL DO IT
In which we find that glazing putty is a gift from the gods.
Yon glazing and spot putty:
AppleMark
Applied much smoother and easier than the Everglass. And stayed workable for minutes. A pleasure to use.
AppleMark
First pass:
AppleMarkAppleMark
Sand with 320 grit:
AppleMarkAppleMarkAppleMarkAppleMark
And a second, skim coat:
And sand again with 320 grit:
AppleMark
Spot filling:
AppleMark
And final sanding, again with 320 grit:
AppleMark
After I finished, just to check the surfacing, I wet-sanded it down with 800 and 1000. It was smooth as a baby's bottom. A pity I'll have to rough it up again with 400 before I do the final painting.
Let's do another comparison, before starting, and progress to date:
AppleMarkAppleMark
Notice that I also filled in the groove that ran up the side posts in addition to sculpting the new fan ducts. This turned out 1000 times better than I expected I could do.
Jhereg10 is offline
post #72 of 512 (permalink) Old 06-05-2014, 04:22 PM
Sparda09's Avatar
Rep: 16 (Unique: 16)
Subbed! this looks interesting.
“Sanity and happiness are an impossible combination.” - Mark Twain
"Happiness is a warm gun" - The Beatles
Sparda09 is offline
post #73 of 512 (permalink) Old 06-05-2014, 04:40 PM
nickcnse's Avatar
Rep: 9 (Unique: 9)
You're doing a great job of keeping it even on both sides. The finished product is going to look amazing. Are you going to do any sort of mesh or pattern in the fan ducts or leave them open so the lights really shine through?
R2D2
nickcnse is offline
post #74 of 512 (permalink) Old 06-05-2014, 04:53 PM - Thread Starter
Thanks!
And thank you, Nick.
I'm going back and forth on the mesh. My wife had this folding metal-mesh filing box that fell apart (hinges broke), and I'm thinking of salvaging mesh from it.
AppleMark
It's pretty nice looking stuff. Especially since it's free!
But I really need to add some sort of filter media to that intake to keep dust down, too.
So I'm torn on what to do. I may try to modify the front bezel (add a slot on the bottom or one side) so that I can easily slide a mesh/filter in and out, so that I can have the exposed view when I'm showing it, but filtered the rest of the time.
Jhereg10 is offline
post #75 of 512 (permalink) Old 06-05-2014, 05:00 PM
nickcnse's Avatar
Rep: 9 (Unique: 9)
That mesh looks about perfect. I ended up ordering some from frozencpu that was only a dollar but it looks horrible. On the plus side I didn't feel bad when I messed up and cut some holes in the wrong place or bent it inappropriately so I had to start over. I also finally gave up on figuring out how to filter it because my case is open every other week or so and I just clean everything out while I'm in there. one of the things I was thinking about though is attaching the filter (a nylon) to a magnet and just clipping it onto mesh fan guards.
R2D2
nickcnse is offline
post #76 of 512 (permalink) Old 06-05-2014, 11:33 PM
Rep: 94 (Unique: 73)
Next up you're going to want to get some high build primer to go over all that body cheese. Also, a somewhat curved but fairly rigid sanding block will help knock down any remaining high spots. If you just hand sand, your fingers will put pressure into the low spots too, so it's harder to get an absolutely even finish. Now is the time to make sure it's flawless as when you paint it you will see every imperfection.
I use IKEA trash cans for mesh. Same idea and looks like the same stuff... except yours has grooves bent into it for rigidity. The IKEA trash cans used to be just a rolled tapered cylinder. They switched designs and now they're more square, and have a round semi-spherical bump on all sides. Much harder to flatten out.
I have a hammer! I can put things together! I can knock things apart! I can alter my environment at will and make an incredible din all the while! -Calvin
TLHarrell is offline
post #77 of 512 (permalink) Old 06-06-2014, 05:25 AM - Thread Starter
You are absolutely right.
Unfortunately, I painted it last night and didn't see your post until this morning. frown.gif
At this point, I'm going to have to wait until the current paint fully cures (7 days) before attempting any fixes or tweaks. It doesn't look bad at all!, heck it looks awesome...but you can definitely see some imperfections if you look closely. I'm open to further suggestions. Thanks for sticking with me as I stumble through all this.
Jhereg10 is offline
post #78 of 512 (permalink) Old 06-06-2014, 06:29 AM
Covfefe
Wihglah's Avatar
Rep: 84 (Unique: 75)
Let's see it!
Ro'Ghaf II
Oldness
(14 items)
Intel 9900k
Some crappy 4 phase rubbish from Asus that was way overpriced.
EVGA 980ti ACX2 SC+
G.Skill Trident Z RGB 4266 16Gb
Samsung 970 Evo
Corsair AX860i
EK Supremacy Evo
Cooler Master Haf Stacker 935
Haf Stacker 915R
Operating System
Windows 10 Pro
Asus ROG Swift
Keyboard
DuckyShine 6 YOTR
Mouse
Logitech G502
IvyBridge 3770K
Asus P8Z77-V Pro
560Ti Direct CU II
Geil DDR3
Western Digital
Western Digital VelociRaptor 10K
Optical Drive
liteOn Bluray Burner
OCZ 1000W
EK Supreme HF Copper / Plexi & Vapochill Chiller
Lian Li
Operating System
Windows 7
LG 21"
Keyboard
Logitech G15
Mouse
Logitech
Wihglah is offline
post #79 of 512 (permalink) Old 06-06-2014, 07:12 AM - Thread Starter
23. BEZEL PAINTING - IF PERFECTION WAS OUR GOAL....
Body work's done, so here's the painting process and result. I think that the final result is frankly quite nice, but far from perfect. Have a gander!
TIL: Primer is more than about ensuring a good paint bond. It's also an opportunity to spot imperfections in the finish so you can fix them before you lay down your fancy shmancy paint coat. So props to TLHarrell, whose very wise words of wisdom came alas too late.
Originally Posted by Wihglah View Post
Let's see it!
Ask, my friend, and it shall be yours.
So here's where I started. A roughed-up front bezel and Krylon Fusion satin finish. I thought about going completely flat, and was warned away from glossy finishes, so I figured this was a decent compromise:
AppleMark
TIL: It is impossible to really see the imperfections in the body filler. You absolutely *must* lay down a primer coat first. The uniformity of color will help bring them out so you can repair them then.
First Coat:
AppleMarkAppleMark
Dry for about 20 minutes, then recoat:
AppleMarkAppleMark
And repeated a third time, which I didn't photograph.
And the final result:
AppleMarkAppleMark
AppleMarkAppleMark
AppleMark
These are the kind of imperfections that you can see if you look closely and the light catches it just so:
AppleMark
But overall, I think this is a bit better than what I started with. wink.gif
AppleMarkAppleMark
Now, after it cures for 6 more days, I can (if it bugs me too much) sand it down some more, fill those spots, and have another whack at it. I'll have to see what gnaws at me.
Next step, I have to get the internal frame painting finished and assembled, so I can see what this bad boy looks like with lights in it!
Jhereg10 is offline
post #80 of 512 (permalink) Old 06-06-2014, 07:46 AM
PurdueBoy's Avatar
Rep: 70 (Unique: 63)
For sure, I'd say priming is the most important part of painting. It looks like you've still got some pretty big problem areas (on your top hole) that you should still be working with glazing putty, maybe even a bit of body filler, its tough to see how deep it is.
Everyone has a different process, but for me when I'm priming the first coat of primer gets sanded about 90% off back down to bare. Clean and prep surface, re-primer, sand down again, leaving more and more each time depending on how many coats you want to do. It's a really time consuming process, but it make or breaks your project.
As for colors I've heard that the darker the color the more noticeable any imperfections will be, so if you go black and shiny you're gonna have to have a pretty much perfect surface.
Waiting for 7 days? I guess if you want to take a break or something that's nice, but I don't think it's necessary, especially if you are just going to sand it off and use an actual primer on it. I remember I had a project and I started painting like 18-24 hours before it's deadline, I managed to do like 6 coats of filling primer and 4 or so coats of paint, of course I didn't get to sleep until the final dry time (around 4 hours) but it turned out pretty nice so I think waiting 7 days is overkill.
I've never used type of Krylon paint, but I think that primers used different chemicals in them that are better suited to concealing small defects. I love how it says no sanding or priming required right across the can^^
PurdueBoy is offline
