Can I polish the Acrylic Side panel window? - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 07-21-2014, 05:21 PM - Thread Starter
Questionnaire galore!
Speedster159's Avatar
Rep: 65 (Unique: 57)
I have a Switch 810 and the window on it is not exactly that perfect anymore so I'm thinking of replacing it with Laminated glass.
But then looking at Build Logs I saw people polishing the EK waterblocks. Could I polish the side panel window to get rid of the small scratches and make it shine?
Sunkissed Beauty
(26 items)
Alienware M17x R4
(17 items)
Quirky
(12 items)
Intel Core i7 3770K [ 4.5Ghz | 1.370V ]
AsRock Z77 OC Formula
ASUS GTX 1060 Strix OC
Crucial Ballistix Elite 16GB 1866Mhz CL9 1.5V [ 4 x 4 ]
Crucial MX100 256GB
Western Digital Caviar Blue 500GB [ WD5000AAKX ]
Western Digital Caviar Blue 1TB [ WD10EZEX ]
Western Digital Caviar Green 1TB [ WD10EARS ]
Seasonic X760
Corsair H100i Push&Pull
Corsair SP120 PWM High Peformance [ 2X ][ H100 i]
NZXT FN 140RB [4X][Case]
Cooler Master Sickleflow 120 Red [ 2X ][ Case ]
Corsair SP120L PWM [ 2X] [ H100i ]
NZXT Swtich 810 Black
Operating System
Windows 10 Pro x64
LG 29" Ultrawide 29UM69G
Keyboard
Corsair Vengeance K95 RGB [ MX Brown ]
Mouse
Logitech G402
Mouse
Razer Goliathus Alpha Control / Steelseries Qck Mass
Audio
Audio-Technica M40x
Audio
Creative Inspire T7900
Audio
Audio-Technica ATR2500-USB
Other
NZXT Sentry LX
Other
NZXT Sleeved LED Kit | Orange 2M
Intel Core i7 3630QM
Alienware M17x R4
Nvidia GTX 660M 2GB
Intel HD400
Alienware OEM 6GB [ 1x4, 1x2 ]
Western Digital Caviar Black 500GB
Optical Drive
Alienware OEM
Alienware OEM
Alienware OEM
Alienware M17x R4
Operating System
Windows 8 Pro 8.1
Alienware OEM 1080p
Keyboard
Alienware OEM
Mouse
Logitech G602
Mouse
Audio
Alienware OEM
Intel Pentium Dual-Core E2200
MSI 945GCM5-F V2 (FSB 1333)
Inno3D Nvidia GeForce GTS 450 1GB (Cooler Ripoff)
Optical Drive
Benq DVD-R,CD-R,DVD-ROM,CD-ROM
AcBel R8 PowerII 650W 80+
Intel Stock Fan
Vertu Santa Fe "Blue"
MAG InnoVision 770FS
Keyboard
Logitech Internet Pro
Mouse
Mouse
CM Storm Pad
Audio
Sound Blaster Audigy 2 ZS
Speedster159 is offline
post #2 of 9 (permalink) Old 07-21-2014, 08:11 PM
Overclock Failed...
billbartuska's Avatar
Rep: 1249 (Unique: 969)
Yes there are products specifically for that.
What tools you have will determine which one to use, ie electric drill, buffer, buffing wheel, just cloth etc.
I've had very good results with a 10" buffing wheel at 1750 rpm and a compound specifically made for plastic polishing.
You can remove some pretty deep scratches, but you have to be really careful about heat though.
https://www.overclock.net/images/smil...lame-small.gif5 GHz Overclock Club https://www.overclock.net/images/smil...lame-small.gifMisinformation is available from a variety of other sources. Misinformation is just like real information but wrong
....and enough power to shoot the speaker cones through the walls.
billbartuska is offline
post #3 of 9 (permalink) Old 07-21-2014, 08:44 PM - Thread Starter
I have access to cloths and a power drill.
Why would you need heat? Heat caused by the friction I assume?
Sunkissed Beauty
(26 items)
Alienware M17x R4
(17 items)
Quirky
(12 items)
Crucial MX100 256GB
Seasonic X760
Operating System
Windows 10 Pro x64
Keyboard
Mouse
Logitech G402
Mouse
Audio
Audio-Technica M40x
Audio
Audio
Other
NZXT Sentry LX
Other
Alienware M17x R4
Nvidia GTX 660M 2GB
Intel HD400
Optical Drive
Alienware OEM
Alienware OEM
Alienware OEM
Alienware M17x R4
Operating System
Windows 8 Pro 8.1
Alienware OEM 1080p
Keyboard
Alienware OEM
Mouse
Logitech G602
Mouse
Audio
Alienware OEM
Optical Drive
Intel Stock Fan
Keyboard
Mouse
Mouse
CM Storm Pad
Audio
post #4 of 9 (permalink) Old 07-21-2014, 08:59 PM
Overclock Failed...
No, you don't want heat. The friction generated by using powered equipment to polish will easily generate enough heat to melt the plastic if you're not carefull.
post #5 of 9 (permalink) Old 07-22-2014, 04:47 PM
Lefik's Avatar
Rep: 80 (Unique: 65)
I've cleaned and polished delrin and acrylic on water blocks using a Novus kit I bought on amazon, it works great. I just use a microfiber cloths well as some fine paper towels that and polish them gently by hand.
Lefik is offline
post #6 of 9 (permalink) Old 07-30-2014, 06:29 AM
Rep: 116 (Unique: 108)
This. Novus works great.
A man who praises himself displays his deficiency of intellect.
Raul-7 is offline
post #7 of 9 (permalink) Old 08-08-2014, 05:53 PM
Myka's Avatar
Rep: 2 (Unique: 2)
Yes indeed you can, I restore aircraft poly-carbonate and acrylic windows at my work and fix up and clean new bubble windows we manufacture for helicopters. I have a repair technique I've written for some of the guys at work.
As Raul-7 indicated Novus is a quality product I use. It comes in Novus 1, Novus 2 for fine and course grades. For deep scratches I use the micro-mesh system that wet sands out the scratches. Early in my career I used power tools and wool and foam pads, but I never use power tools now, strictly by hand. We had problems with the small orbital scratches left by the polishers. Then it was filled with waxes or glazes that eventually wore off and the orbital scratches were still there. In bright sunlight, these fine scratches actually blinded the pilot from seeing out.
Some would balk at that at taking too long, but I achieve better results since air power tools seems to glaze up and mark up the window and you have to mechanically remove all scratches, that means even by elbow grease!
Just go at it by hand with some super fine soft microfiber cloths. I just bought a good one from Simoniz (Detail Microfiber Polish cloths). I bought the pack that contains 3 X 14"X14" cloths for $5.00. I cut the band of stitching off the perimeter because this can leave super fine scratches. After I'm done hand polishing with the Novus 1 and 2 coarse and fine I give it a coat of Mothers glaze to get rid of all residue and it leaves a nice shine. I also like to spray mist my polish cloths with water and very light spray on the surface I'm polishing and it reduces the static buildup that attracts dust. With the fine mist you keep the compound wet and it dries on the surface as you're polishing, you can feel the grab and bite of the action, then when it dries too much I give it another shot of mist and repeat this over and over.
If you can't find Novus you can use paint clear coat polish and this will work as well, although Novus is specifically designed for plastic.
Mike
Myka is offline
post #8 of 9 (permalink) Old 08-08-2014, 06:23 PM
dlemaregssr's Avatar
Rep: 0
just use a microfiber cloths well as some fine paper towels that and polish them gently by hand.rect
dlemaregssr is offline
post #9 of 9 (permalink) Old 08-09-2014, 07:29 AM
Myka's Avatar
Rep: 2 (Unique: 2)
Speedster,
Heat buildup from too much RPM might cause distortion, or breakdown of the acrylic surface even causing crazing (fine cracks). Some acrylics are harder than others too. Polishing in one spot too long I've seen can cause distortion. It behaves like an optical lens if you take off too much material, say if you focused too much polishing on one spot on a deep scratch with your finger. You want to spread the repair over a larger area like I do when fixing a dent in body work, using a cross hatch sanding motion. Another trick s to wrap your polish cloth in a foam sanding block, 3"X3" square this keeps everything nice and flat and polishes evenly.
I would stay away from paper towels with all due respect, these will leave very fine scratches, if you do use them, use paper towels in the coarse stage, I use the softer thicker shop towels from auto parts dealers and then use the better cloths (super fine and soft microfiber cloths) in the polishing fine stage. Polish cloths, rags, paper towels make all the difference in the end product. One piece of grit and start over, so cleanliness is of absolute importance!
Mike
Myka is offline
