led strip connected to a fan controller - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 08-09-2014, 07:55 AM - Thread Starter
benhiggs's Avatar
Rep: 0
Ok quick question, would like some help
Was looking at getting a NZXT mix 2 for my bitfenix prodigy, keeping it clean without digital crud all over the front like read outs for stuff i care little for
My prodigy has a single 5.25, and i was going to use leds in the case.
My question is would i be able to use led strips instead of a fan, as i will not have 6 separate fans.
I have had experience with fitting strips with resistors built in using a fuse tap in the car, but the only leds i have used on pc were the nzxt kits and the hue.
would a few 30cm strips run from a single port. and if so, would the 1m nzxt kit run from a fan output?
thanks for any help
ben
benhiggs is offline
post #2 of 3 (permalink) Old 08-09-2014, 08:00 AM - Thread Starter
benhiggs's Avatar
Rep: 0
im assuming that the 1m led kit would work with this controller, as the mix 2 boasts a 30w channel
benhiggs is offline
post #3 of 3 (permalink) Old 08-09-2014, 09:06 AM
Lefik's Avatar
Rep: 80 (Unique: 65)
Yes it should work.
Lefik is offline
