RM1000: 8-pin EPS to 2x 6+2 PCIe - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 08-24-2014, 10:44 PM - Thread Starter
Linux Lobbyist
jopale's Avatar
Rep: 0
Hey friends!
I have a Corsair RM1000 PSU for which I am trying to make a cable for; the stock cable goes from an 8-pin EPS (connected to PSU) to a 6+2 PCIe.
The problem? The 6+2 branches off into ANOTHER 6+2. That is, the 2nd 6+2 branches off the first 6+2 (which is connected to the 8-pin EPS). It is difficult to crimp two cables into one terminal.
If I were to make a custom cable for this, is it OK to splice the 2nd 6+2 along the 8-pin to 1st 6+2? Do I have to think about serial or parallel electron flow? How have people in the past done this?
If this is a redundant post I apologize. I have tried to use the search function as well as google and nothing has come up. This is one of the few things I need to do to finish my computer and need guidance!
Basically it looks like this:
9d6bb497_Bu8tN2R.jpeg 1806k .jpeg file
How do I get it to look like this:
http://i363.photobucket.com/albums/oo72/pathfindercod/_DSC3001_zps8fc30c8b.jpg
jopale is offline
post #2 of 5 (permalink) Old 08-26-2014, 02:10 PM
shakmods's Avatar
Rep: 5 (Unique: 4)
i've made a similer cable for a client. i dont think there should be any problem splitting it in 2s from the psu connector.
i have a similer cable here http://shakmods.com/shop!/~/product/category=3316061&id=34448254
This is just a 8pin pcie to 2 x 8pin pcie cable, yours should look similer to this but not an extension.thumb.gif
shakmods is offline
post #3 of 5 (permalink) Old 08-28-2014, 02:20 PM
Linux Lobbyist
Lutro0's Avatar
Rep: 528 (Unique: 406)
We do cables like this all the time. We tend to use the double wire method on this video:
The reason we do it this way is so the end cables dont look like they have a ton of wires crammed into it. IMO it takes away from the clean look that you are trying to achieve by sleeving, and the connector has a hard time handling all of those crammed wires and tends to bend and break.
.-[Owner - Lutro0 Customs]-.
[Project Log]:[ Katharos ]: April MotM Winner
[Project Log]:[ Elektron Mod
Lutro0 is offline
post #4 of 5 (permalink) Old 08-28-2014, 06:40 PM - Thread Starter
Linux Lobbyist
jopale's Avatar
Rep: 0
Thank you for the replies!
It appears that no regard is needed with respect to the electricity going in serial or parallel.
jopale is offline
post #5 of 5 (permalink) Old 08-29-2014, 12:28 PM
Linux Lobbyist
Lutro0's Avatar
I must have missed this part, but as long as you keep the pin out the same that it needs to be everything will be fine.
Lutro0 is offline
