[Scratch Build] "BETA" - Overclock.net - An Overclocking Community
post #1 of 52 (permalink) Old 09-28-2014, 06:45 AM - Thread Starter
QAKE's Avatar
Rep: 29 (Unique: 26)
BUILD EXPLANATION
Modding PCs is a hobby that sucks a lot of money. Being a student, I don't really have a lot of money to spend.
So for this mod, don't expect a lot of overkill components.
One of my friends is working in a waste disposable (Swiss people sort their waste). Electronic waste is growing, also because of the growing number of people that owns electronic stuff.
Anyway, back on the topic! Everyday evening during 2 weeks, I was visiting this electronic waste center, hoping to find some stuff I can further use. My patience was worth the time spender in the waste center! I was able to find more than 150 working electronic pieces, including 4 Eheim 1048 water pumps, a lot of 120 rads, some weird waterblocks (HDD, CPU, RAM, GPU, MB, etc), more than 2 kilo of fittings and 2-3 reservoirs. But most importantly, I found pretty good electronic components that was in perfect shape.
All of this to say one thing: the majority of this build was found in a waste center, so no costs for it!
CURRENT COST OF THE BUILD:
CHF 68.95
USD 72.02
UK 44.81
EUR 57.04
Discovered Means I've discovered it at the Waster center
Owned Means I received it or owned it for a long time
Bought Means I bought it (thanks Captain Obvious...)
PS: Sorry for my english, I speak french and german... doh.gif
New pictures will be put in the Spoiler links and a description will be written with all updates
Here is a list of the materials and some other stuff we used to complete this Mod
BETA Infrastructure:
GA-P55M-UD4 Discovered
Intel I5 750 Discovered
4x2GB Corsair XMS DDR3 1600MHzDiscovered
XFX Radeon HD 6790Discovered
SoundBlaster Audigy 2 Discovered
Samsung 1000GB Discovered
NitroX 600W Semi-modular PSU Discovered
Cooling and miscellaneous:
EKWB Supreme LTX Acetal-Copper Owned
Watercool Heatkiller GPU-X³ Core LC Bought
Alphacool MCX RAM cooler Bought
Alphacool MCX distribution unit Bought
Old Apple Powermac G5 Watercooling unit (rad+pump will be used) Owned
Old Apple CPU, mainboard and VRM cooler Owned
Old Apple PowerMac G5 Fans (DELTA FANS!!!) Owned
Tygoon 2475 Tubing (received it from my old lab) Owned
Plasti-Dip white Bought
Miscellaneous paints Bought
Mayhems Pastel White + Mayhems dyes Bought
Other devices:
Wood board Owned (for the case)
All custom sleeved cables come from Ensourced.net
LIST OF UPDATES
FIRST UPDATE 12 October 2014: Added Pictures of the components
SECOND UPDATE 14 October 2014: GPU air cooler unmount and GPU waterblock cleaning
PRESENTATION VIDEO
FINAL PICTURES
Warning: A lot of them!!! (Click to show)
ΩΛΚΣ - Moddιηg is Λrt
| First build ever - GAMMA |
Sorry for my bad english...
QAKE is offline
post #2 of 52 (permalink) Old 09-28-2014, 08:52 AM
AlderonnX's Avatar
Rep: 53 (Unique: 45)
1st! Always in for a man that makes his own tools. Gamma was a great build.
AlderonnX is offline
post #3 of 52 (permalink) Old 09-28-2014, 09:19 AM - Thread Starter
QAKE's Avatar
LIST OF UPDATES
Update 1: Pictures of all the components
10.12.2014
Update 1 (Click to show)
My ghetto lightbox
Sorry for the crappy quality of the pictures!
Apple had a good taste back then... DELTA FAAAANS!!!
A perfectly fine Samsung 1TB HDD, discovered in the electronic waste
The motherboard
With a working CPU on it, all of this found in the waste center wheee.gifwheee.gifwheee.gifwheee.gif
Took the heatsinsk off the motherboard, and also took the ugly Gigabyte decoration off it
Also found a XFX 6790, working like it was new. I don't really know it's performance, I am actually more on the "Green Side". But a french proverb say: "Only a donkey won't change his mind even one time" (bad traduction...)
Another thing I've discovered, a nice looking soundcart, perfectly working
GPU cooler
Some heatsinks from the old PowerMac G5 I'll be using
One of the first AIO water-cooling loop sold within the PC, back on 2005!!! Apple had impressive stuff...
The 2 Dual-Core PowerPC 2.5GHz processors are on it.
The PowerMac G5 Was so powerful back then that it was forbidden to sell it on USA's enemies (Irak, Korea, etc)
Alphacool MCX RAM coolers and other pieces, to make my own radiator
The Standart CPU cooler of the non-watercooled PowerMac G5 (using it for the homemade radiator)
Blower-style Delta fan, also from the old PowerMac G5 (PWM FANS!)
A 600W Semi-modular PSU, also discovered
Update 2: GPU air cooler unmount and GPU waterblock cleaning
10.14.2014
Warning: Update 2 (Click to show)
So I bought an used universal GPU block for 20 bucks, but ouch!!! It is really dirty! mad.gif
A lot of oxidation on the outer side... MMhh... Okay...
I should check the interior, just in case...
Well, no surprises, some oxidation on the exterior of the plate too.
But... Wait!!!
Yes, there a lot of little things in the channels!!!
Let's clean that!
Mhh, better! (the thing in the channel is some water left when I rinsed it)
I took some polish paste and cleaned the block
Oh, also removed the air cooler of the 6790 and cleaned the dust
Ghetto mod to keep all the screw safe! Yeah, I know, I should buy a little box... tongue.gif
With the GPU waterblock I also received some passive heatsink for the GPU thumb.gif
Update 3: Current state of the build
10.26.2014
Update 3 (Click to show)
Soooo...
As you'll see with the next pictures, the color theme of the build will be mainly white, with light blue and neon green accents. Really no other colors, even on the hardware.
I'll paint it with plasti dip, so I masked the ports. To give you an idea, the card will be all white, but the condensers, the small chips and all the things that won't be flat will be painted either in neon green and light blue. This pattern will also be used on the motherboard and on the GPU
Those waterblocks were sanded and masked, and will be also painted in white, with normal paint.
I took one of the 92mm Delta fans from the G5 to test paint adherence on it (have 8 of them)
I bought some nailbrush for the small part painting
White Block
Tried the neon green on the rings, the blue will be fo the others rings and letters.
As you can see, the paint is not really good, so i'll sand it and paint it again.
Have a nice day
QAKE is offline
post #4 of 52 (permalink) Old 09-28-2014, 09:19 AM - Thread Starter
QAKE's Avatar
Reserved 2
QAKE is offline
post #5 of 52 (permalink) Old 09-28-2014, 09:19 AM - Thread Starter
QAKE's Avatar
Haha thanks!
This one will be something you've never seen anywhere
Stay tuned, I'll begin it in 6 days, just waiting some components;)
QAKE is offline
post #6 of 52 (permalink) Old 09-28-2014, 09:36 AM
d3adsy's Avatar
Rep: 9 (Unique: 6)
d3adsy is offline
post #7 of 52 (permalink) Old 09-30-2014, 11:38 AM - Thread Starter
QAKE's Avatar
Originally Posted by d3adsy View Post
Subbed! Let's see what you offer.
QAKE is offline
post #8 of 52 (permalink) Old 09-30-2014, 03:41 PM
Cbiss's Avatar
Rep: 2 (Unique: 2)
Steam: Biss
Origin: BiSsz
Battle.net: Biss #11594
WoW: Justic (Paladin) -Burning Legion / Biss (Shaman) -Korgath
Cbiss is offline
post #9 of 52 (permalink) Old 10-06-2014, 03:30 AM - Thread Starter
QAKE's Avatar
Sorry guys, I'm waiting for some components.
I will begin this mod the 18 October, because I have too much work now.
The mod will be done in merely one week, there are just 2-3 components I'm waiting for
QAKE is offline
post #10 of 52 (permalink) Old 10-07-2014, 11:33 AM
Canada Goose Puncher
CynicalUnicorn's Avatar
Is your inevitable LAMBDA build going to be based on Half-Life? wink.gif Subbing to see where this goes.
Quote: Originally Posted by TheBadBull View Post
someone sig this
CynicalUnicorn is offline
