[Build Log] Pew Pew Reactor (powered by "Grape Soda") - Cooltek (Jonsbo) W2 X99 system. - Page 3 - Overclock.net - An Overclocking Community
post #21 of 32 (permalink) Old 04-24-2015, 07:15 AM
Nizr's Avatar
Rep: 4 (Unique: 3)
The "silver" one plain brushed aluminium, mmmmmmmm wink.gif will do some modding on it and have a log here, when I am ready. Until then I view images and read logs smile.gif
Good thing you like it and it looks like the temps are ok even so it's such a small case! Gj!
Björn showed us what kind of level one can achieve with a keen eye for detail and a sense for style. - SM i PC moddning 2015
Nizr is offline
post #22 of 32 (permalink) Old 04-24-2015, 08:07 AM - Thread Starter
BakerMan1971's Avatar
Rep: 105 (Unique: 78)
well I would sure love a link to your log from my log so all the w2 logs can come together in some kind of log nexus smile.gif
Also the temps are not a problem because most of the stuff that normally blocks airflow etc in a standard case is round the back of the motherboard.
If I could have a few vent holes in the front panel that would be nice, they would have to be neat though.
Surprised you didn't go for the windowed version to show off posh innards ! redface.gif
♦░▒█▓▒░♦MSI X99S Motherboard Owners Club♦░▒█▓▒░♦
X99 Cooltek W2 Build Log
Pew Pew Reactor
Z87 Corsair C70 Build Log
meet "Twisting Get"
BakerMan1971 is offline
post #23 of 32 (permalink) Old 04-24-2015, 09:04 AM
Nizr's Avatar
Rep: 4 (Unique: 3)
Oh, i am having the window version! Might change the screws though and I will put holes in the front, think I have a neat solution!
Edit: could you please measure the inside of the roof? Roof->MB and width of the roof? Thinking of having a radiator at the top.....
Nizr is offline
post #24 of 32 (permalink) Old 04-24-2015, 01:40 PM - Thread Starter
Here we go:
Radiator: 35mm Thick
Bequiet Shadow Wings 25mm Thick Total installation 60mm
GPU 275mm
Space to front fans (internally mounted 315mm
Take front fans out and you can fit 340mm graphics card in there
even the sapphire tri x is only 305mm long so that would fit with the fans in the front
Pew Pew Reactor
meet "Twisting Get"
post #25 of 32 (permalink) Old 04-28-2015, 12:27 AM
Nizr's Avatar
Rep: 4 (Unique: 3)
Here we go:
GPU 275mm
Thank you so much! This means that the numbers in cooltek site is wrong (max GPU 320). Your GPU plus rad and fans is 335 and still looks like you have some mm to go.
Means there's no problem adding a 280mm rad and a gtx 980 (water cooled)!
Waiting for the case to arrive and I'll post a log!
+rep for you!
Nizr is offline
post #26 of 32 (permalink) Old 04-28-2015, 12:39 AM
Lefik's Avatar
Rep: 80 (Unique: 65)
I'm intrigued, but less potato shots with flash; instead try a more refined french fry camera tongue.gif
Lefik is offline
post #27 of 32 (permalink) Old 04-28-2015, 02:05 AM - Thread Starter
+rep for you!
be careful of 280mm rad, its not the length that would be the problem its the width possibly contacting the pegs that hold the side panels on.
and Lefik, I am a terrible photographer, I even think cheap cameras deliberately downgrade themselves because I don't deserve any fancyness smile.gif
Pew Pew Reactor
meet "Twisting Get"
post #28 of 32 (permalink) Old 04-28-2015, 02:53 AM
Nizr's Avatar
Rep: 4 (Unique: 3)
The cooltek site says a 280 rad would fit (hope this is right tongue.gif) and I've seen builds using it!
The case is on the way, so I could do some measuring myself now! Thx to your measures it's now ordered smile.gif
Nizr is offline
post #29 of 32 (permalink) Old 04-28-2015, 04:40 AM - Thread Starter
ah actually it's for bottom mounting that there is a 240 limitation (memory kicking in now)
the front panel of course comes with two 140mm fans already installed.
Pew Pew Reactor
meet "Twisting Get"
post #30 of 32 (permalink) Old 05-11-2015, 04:29 AM - Thread Starter
Overclocking Update
Hi Guys
quick update in my overclocking adventure with my 5820k
I have been shooting for 4.5GHz but that is eluding me at the moment
currently tweaking 4.4GHz to stability
started at 1.26v vcore everything else auto but with Adaptive voltage mode
moved it up to 1.265, 1.27 and after that BSODed with a 124, 1.275v
seems stable now, temperatures seem good all well below 65C under full load.
Pew Pew Reactor
meet "Twisting Get"
