[Scratch Build] - Victorian Desktop - Mosquito - Updated 2nd Jun. 2015 - Final Pictures! - Overclock.net - An Overclocking Community
post #1 of 103 (permalink) Old 01-22-2015, 08:34 AM - Thread Starter
Rep: 31 (Unique: 24)
Victorian Desktop
My wife’s laptop is no longer working happily, so she’s asked for a desktop. Well, I can’t leave well enough alone, so why would I build her one in a stock case (of which I have several laying around), when I could do another scratch build project?!
This case will be another wooden scratch build, as many of my projects are. I have some old cast iron pieces that will be incorporated into this project as well. It’s going to be built out using solid mahogany, and will be finished in a way to emulate a lifetime of use. I don’t really want it to look brand new, as the cast iron parts are not, and we like the look of them as they are.
Mosquito
- Staff Writer for The Mod Zoo
Scratch Build Case Club
Case Mod: Visible Contrast | Dancing Iridescence
Scratch Build: Victorian Desktop | Mini Watercooled HTPC
Mosquito Mods is offline
post #2 of 103 (permalink) Old 01-22-2015, 08:34 AM - Thread Starter
First things first, I decided to throw most of the hardware parts together to make sure it all works happy before I get too far.
The main idea behind this build is a cube style case, with one side to house an ATX power supply, and the hardware on the other side. I wanted to keep it as compact as I could. I ended up going with an ITX board, a 90 degree PCIe hard riser card, and a low profile GPU.
I know I know, “Stock Intel cooler?!?!?”… Just running on air to make sure it all works. There will be a 200mm radiator once things get rolling.
The Gigabyte Phoenix-WiFi motherboard has built-in orange LEDs on the underside of the motherboard.
The hardware (motherboard + GPU) is about 9.5” (~241mm) in length, which is about perfect for what I’m hoping to do.
The 200mm radiator is the perfect height to match the hardware.
And what’s more, the cast iron grate my wife picked up at an antique store a while ago, is dead on the size of the radiator. That works out quite nicely.
G.Skill Ares RAM 8GB 1600MHz kit goes superbly with the color scheme of the motherboard.
The internal color scheme will be based around the orange, and I will be using orange tubing as well.
Next thing up is to get started on the woodworking! A big piece of mahogany. 4/4 rough sawn, about 8’ long and 14” wide.
Time to get started cutting it up. Next update will be prepping the main pieces of the case.
Thanks for checking it out! I look forward to this project quite a bit (and so does my wife, as she wanted it a month ago…)
Mosquito
post #3 of 103 (permalink) Old 01-22-2015, 09:11 AM
vaporizer's Avatar
Rep: 52 (Unique: 32)
subbed. i love wood. i love the design you posted in the scratch build thread as well.
vaporizer is offline
post #4 of 103 (permalink) Old 01-22-2015, 09:14 AM
morencyam's Avatar
Rep: 277 (Unique: 203)
Sub'd as well.
Never attribute to malice that which is adequately explained by stupidity
morencyam is offline
post #5 of 103 (permalink) Old 01-22-2015, 10:50 AM
vaporizer's Avatar
Originally Posted by morencyam View Post
Sub'd as well.
post #6 of 103 (permalink) Old 01-22-2015, 05:07 PM - Thread Starter
Sub'd as well.
lol thanks guys!
Mosquito
post #7 of 103 (permalink) Old 01-23-2015, 01:40 AM
8.2 liters
WiSK's Avatar
Rep: 553 (Unique: 361)
WiSK is offline
post #8 of 103 (permalink) Old 01-25-2015, 05:49 AM
mopro's Avatar
Rep: 0
mopro is offline
post #9 of 103 (permalink) Old 01-25-2015, 11:08 AM - Thread Starter
Originally Posted by WiSK View Post
Originally Posted by mopro View Post
Thanks guys!
Mosquito
post #10 of 103 (permalink) Old 01-26-2015, 12:30 PM - Thread Starter
Right, so time to get thing’s kickin’.
The rough cut board had a bad end when they crosscut it to length, so first things first; cut a nice clean square end and go from there.
I could have used a panel saw (or power tools, for that matter), but I prefer my backsaws for cross grain work, at the bench. The board is wide enough, that the cut angle has to get shallow to get all the way across.
Nice clean end. Now repeat 4 more times.
The 5 main panels all cut to rough size. They’re almost cut to length, but all will require ripping to width.
Using a handplane on the end grain always requires a bit more effort; let alone 3 boards at once.
All 3 will be the same length once done, by clamping them all together and checking for square.
Next up, I marked out the width on the pieces, and ripped them to width.
Luckily although it’s a hardwood, mahogany actually works quite nicely with hand tools. It’s a bit rough on sharpened edges, but that’s why one learns to sharpen their tools themselves.
Next up, a little edge planing to get the edge straight, and clean up the saw marks.
On to planing the face of the board to take out the cupping in it; it was kind of bad. First diagonally across the board one way, and diagonally across the other way, then with the grain.
This process makes quite the pile of shavings. For reference, this is only two boards so far.
Due to the cupping in the boards, these ended up being just barely over 1/2" thick once done. If they had been flat, they would have been about 3/4" thick instead. Oh well, this gives me an extra half inch inside smile.gif
That’s all I’ve got for now. More work to be done to get the other 3 boards ready to go, then it’ll be time to get these things joined together.
Thanks for watching.
Mosquito
