[Build Log] Project Edith - Beige Case 4k LAN Box - Overclock.net - An Overclocking Community
post #1 of 58 (permalink) Old 04-10-2015, 04:21 PM - Thread Starter
RoostrC0gburn's Avatar
Rep: 13 (Unique: 8)
Thanks for dropping by the build log. This is my first, so please bear with me.
This build has been inspired by the Beigemodders Club Lots of awesome work going on over there. Personally, I prefer to remain true to the original "look" of the old 90's cases. Square lines, minimal aesthetics, 3.5 floppy drives.. I love the idea of an unsuspicious old beige case running Metro Last Light in 4k @ 60Hz. I also love meticulous builds with minute details that perhaps no one else may ever know about. This build will be a LAN case for starters, and may be retired later to HTPC. I have named her Edith.
Here's what I'm currently working on: Project Edith
RoostrC0gburn is offline
post #2 of 58 (permalink) Old 04-10-2015, 04:22 PM - Thread Starter
Rep: 13 (Unique: 8)
*RESERVED FOR FINAL PICS*
post #3 of 58 (permalink) Old 04-10-2015, 04:22 PM - Thread Starter
Rep: 13 (Unique: 8)
So I got this old pc for $20..
deriveted
Warning: Spoiler! (Click to show)
opened her up
score
turns out its an old Pentium 4 620. 3.2GHz in 2004 is nothing to scoff at.
This was someone's baby once. Now, she sits empty. Waiting to live again
more soon...
post #4 of 58 (permalink) Old 04-10-2015, 04:57 PM
s7Design's Avatar
Rep: 21 (Unique: 16)
s7Design is offline
post #5 of 58 (permalink) Old 04-11-2015, 08:25 PM - Thread Starter
Rep: 13 (Unique: 8)
yeah, man i was just poking through your build log - that's some awesome acrylic work there. great photography also! I am just using my cell phone for now... looking forward to seeing you put it all together.
post #6 of 58 (permalink) Old 04-11-2015, 09:31 PM - Thread Starter
Rep: 13 (Unique: 8)
Did some measuring tonight. The plan is to mount a 2x radiator in the bottom (280 if it will fit), exhausting down, and intake fans on the front and rear.
looks like the footprint i have to work with on the bottom is roughly 150mm wide x 380mm long.
width:
length: (mark @ 30cm from leftmost usable point)
the front of the case has approximately 180mm x 190mm usable space for an intake fan and pump/res.
i would love to have a 140mm fan in the front, but not sure there will be enough room. So, for now it looks like i will be going with the Alphacool NexXxos ST30 radiator and a couple Noctua NF-F12 PWM fans Pump/res will probably be an EK XRES or something similar. I am open to suggestions for other pump/res brands.
i will put up a preliminary parts list soon
post #7 of 58 (permalink) Old 04-13-2015, 10:32 AM
George C's Avatar
Rep: 4 (Unique: 4)
[email protected] name: George_C
George C is offline
post #8 of 58 (permalink) Old 04-13-2015, 11:54 AM
Robitdolan's Avatar
Rep: 3 (Unique: 3)
Subbed, sleeper cases are so awesome. Try to keep the exterior as original as possible.
AMD Phenom II x4 965 & Thermalright True Spirit 120M │ ATI Radeon HD 4870 │ Kingston 8gb DDR2 │ MSI K9A2 Platinum │ WD Green 2tb │ Raidmax Scorpio 868 │ Chieftec CFT-750-14CS │ Windows 8.1 Pro
Raidmax Scorpio 868 Mod [ https://www.youtube.com/watch?v=MHdZQxFE1Ps ]
Robitdolan is offline
post #9 of 58 (permalink) Old 04-13-2015, 01:58 PM - Thread Starter
Rep: 13 (Unique: 8)
Originally Posted by George C View Post
thanks for dropping by, man.
that is the idea, my friend. i am thinking i will repaint the case beige and all exterior components to match. inside, i will paint all that shiny rgs flat black - which will make custom sleeved cables really pop. i dont think i'm going to cut a plexi window. it will be completely unsuspecting at first glance. i will try to keep the front as original as possible, but something has to be done in order to increase airflow...
post #10 of 58 (permalink) Old 04-13-2015, 02:34 PM
George C's Avatar
Rep: 4 (Unique: 4)
The diagonal air vents bottom right on the front, add more of them or increase the size... Possibly on the 5.25" bays?
George C is offline
