[Scratch Build] My first attempt at a custom case! - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 08-14-2015, 12:15 AM - Thread Starter
Jakerz's Avatar
Rep: 2 (Unique: 2)
I've built about 5 custom computers of various specs between myself and my brother, my last rig was my first venture into liquid cooling and it went very well I think, and I'm pretty much hooked now ><, so I wanted to try my hand at building a custom case. The inspiration/ideas came from a lot of different sources but most notably the Thermaltake Level 10 style case and the various wall mounted rigs I've seen on this site and many others.
Anyway, the main "case" will be made of wood, the outside edges will be Tiger Maple and the inside panel where everything will be mounted will be Walnut, the wood choices are just from lots of furniture I've seen around and I really like the color contrast between the two woods. Everything will be mounted to the left side of the vertical panel and will be exposed, all the wires will be hidden between the front and rear panel to give a clean look. The tubing will be stainless steel and use EK hard-line fittings and most of the components used are EK.
Specs as of now:
Mobo: EVGA X99 Micro ATX w/ Custom WC Blocks
CPU: Intel I7 5820K w/ EK LTX Block
GPU: Zotac GTX980 w/ EK Waterblock
PSU: EVGA 750 G2
RAM: DDR4 3000 Hyper X
SSD: 2x Corsair Force GS 240gb
Rad: HW Labs SR-2 480mm
Fans: Blacknoise PL-1 900rpms (push/pull)
Pump: D5 Vario on an EK Top
Res: EK 250mm V3
As of now I'm still debating on WC the ram and Mobo (I've already got the Mobo block) but I'm worried it will make everything look to busy and kill the simplicity of the build. Overall I'm going for a modern look with the wood choices and the stainless and hopefully I can make the image in my head a reality! lol
A few quick sketchup drawings of the basic idea, and hopefully I can start on the case this weekend as I just got the last of the wood in today!
A basic layout of how everything is going to be positioned on the case:
Hopefully more to come this weekend!
Jake
Lian Li PC-O6SX
(21 items)
i7 8700K
EVGA Z370 Micro
GTX 1080Ti
Corsair Vengeance LED
Samsung 960 Pro M.2 NVMe
Samsung 950 Evo
Corsair SF600
Watercool Heatkiller IV CPU Block
Watercool Heatkiller 1080Ti Block & Backplate
Watercool Heatkiller 200mm DDC Pump/Res Combo
Hardware Labs 360GTS Radiator
Bitspower Fittings
Bitspower 16mm PETG Tubing
Thermaltake RIING Plus Fans
Barrow Flow Meter
Lian Li PC-O6SX
Operating System
Window 10 Home
Alienware AW3418DW Ultrawide 34"
Keyboard
DAS Keyboard 4 Pro
Mouse
Razer Deathadder RGB
Mousepad
Mionix Alioth XXL Stiched Gaming Pad
Jakerz is offline
post #2 of 5 (permalink) Old 08-14-2015, 08:58 AM
roflcopter159's Avatar
Rep: 42 (Unique: 35)
Just a suggestion, but I would consider moving the power supply to an edge of the case so you don't have the cable from the wall running between the components
Like everyone on this site, I am still learning. If I ever make a mistake or a bad recommendation, please let me know so that I can learn from it
Steam/Origin - roflcopter159
Audio: Schiit Modi 2 Uber > Aune T1 > Audeze LCD 2.2f/MrSpeakers Mad Dog/RHA MA750
Keyboards: Poker 2 (MX Blues), Ducky Shine 3 TKL (MX Reds, Red LEDs)
roflcopter159 is offline
post #3 of 5 (permalink) Old 08-14-2015, 10:11 AM
dirty elf's Avatar
Rep: 8 (Unique: 8)
im a huge fan of scratch builds -> subbed!
///M
First Build
(16 items)
Intel Core i7-870 Lynnfield
Asus P7P55D-E Pro
MSI RADEON RX480 8GB
G.Skill Ripjaws 2 x 8GB
Crucial MX 300
Western Digital Caviar Black SATA 6gb/s 7200rpm Drive
Optical Drive
LG Blu-Ray Drive
Corsair 650TX 650 Watt
Cooler Master Hyper 212 Evo
Antec Three Hundred
Operating System
Windows 7 64-bit Home
Dell U2417H
Dell U2417H
Keyboard
Apple USB Keyboard
Mouse
Logitech M510
Audio
Bose Companion II Series
dirty elf is offline
post #4 of 5 (permalink) Old 08-14-2015, 01:01 PM - Thread Starter
Jakerz's Avatar
Rep: 2 (Unique: 2)
Yea that was the original plan, but there just isn't enough room on the board to have the Mobo, GPU and Power Supply in the same line, I did order a 90 degree power cord from Amazon and it's going to go through the front panel where all the other cables are and come out the bottom. So all you'll see is the connector and maybe an inch or two of wire.
Thanks!
Jake
Lian Li PC-O6SX
(21 items)
i7 8700K
EVGA Z370 Micro
GTX 1080Ti
Samsung 950 Evo
Corsair SF600
Bitspower Fittings
Barrow Flow Meter
Lian Li PC-O6SX
Operating System
Window 10 Home
Keyboard
DAS Keyboard 4 Pro
Mouse
Mousepad
Jakerz is offline
post #5 of 5 (permalink) Old 09-06-2015, 08:22 PM - Thread Starter
Jakerz's Avatar
Rep: 2 (Unique: 2)
Update! Finally lol. I've been busy doing just about everything but getting build this computer ><. But I finally got some time to work on it this weekend and got a good bit done.
This is my first time working with hardwood and it there was a learning curve for sure! Finally got the frame pieces ripped, sanded, angle cut, rabbeted and glued together! Took about 2 days total.
Pic of the frame together:
Was able to get the Walnut panels cut to size yesterday! I've experimented on the lower left corner with tung oil just to see what kind of finish I'm going to end up with, the final product will be darker.
Today I got started on the radiator mount and hit a snag when my Dremel died! lol.
Final layout of the part I need to cut:
And how far I got before my Dremel died!
I'll pick up a new Dremel sometime this week for sure, I've needed one for 6 months or so as this one has been on its way out for a while. I need to get the radiator mount finished and mounted, I've already got the holes for the Motherboard and the Graphics Card drilled, just need to make the standoffs. The PSU mounts are coming this week as well so I can get everything mounted and figure out exactly where I need to cut the slots for wires and get the final layout and see if I like it, but its coming along great so far!
Thanks,
Jake
Lian Li PC-O6SX
(21 items)
i7 8700K
EVGA Z370 Micro
GTX 1080Ti
Samsung 950 Evo
Corsair SF600
Bitspower Fittings
Barrow Flow Meter
Lian Li PC-O6SX
Operating System
Window 10 Home
Keyboard
DAS Keyboard 4 Pro
Mouse
Mousepad
Jakerz is offline
