Kohver v.4 (portable, partly watercooled ATX PC) - Overclock.net - An Overclocking Community
post #1 of 27 (permalink) Old 01-05-2016, 01:28 AM - Thread Starter
Carniflex's Avatar
Rep: 237 (Unique: 187)
It seems I am going to switch to a new case because after getting 390X and hearing it full speed howling it was clear it must be water cooled, however, after careful consideration I decided that my current case is not quite up the task, unfortunately.
Goals/Targets:
* As light as possible while rigid enough for transport.
* Minimum 3x HDD, 2x SSD storage (some hot swap capacity as well if feasible)
* One (primary) GFX card water cooled (case inside must be still accessible if needed).
* As small as feasible (partly because of weight) while keeping the current components.
In a nutshell I'm planning to go for GPU only custom loop with only a water-block inside and all the rest of the loop attached to the side panel above motherboard tray. There will be couple of quick disconnects to make it possible to remove the side panel if needed to access the internals. The idea is similar to what I have done int he past with nova 1080 monster radiator, just not on the side-panel behind the motherboard tray but on the one above it and with much smaller weight (nova 1080 adds 5 kg to the system on its own). This is the past setup from which I'm drawing inspiration.
Revoltex fifty I believe, heavily modded.
And this is my current system Kohver v.3 :
Sharkoon VS3 with some number of mods (internally) to fit longer GFX cards and extra HDD cage on top.
I got an aluminum case for 11 EUR from Ebay when I was thinking about the case options. Add in 14 eur for transport and I had a aluminum case for 25 EUR! Thats like .. uhh .. pretty good price I'd say. The case is Jupiter PSR4609D7 - apparently designed sometime around year 2000 and has been just sitting in its original box some warehouse for the past 13 .. 15 years waiting for buyer. It's not quite ATX compatible but I will make it work - I believe it claimed compatibility for PSII... one 80 mm intake and one 80 mm exhaust and thats about it. It's just anodized aluminium so some paint would have to get involved as well at some point to cover up all the scratches I'm going to no doubt inflict upon this case during handling and modding it to fit my needs.
The components:
PSU - Corsair AX 1200i - 200 mm long, 4 kg, modular
Mobo - Gigabyte X79 UD4
CPU - i7 - 3820
CPU Cooler: Scythe big shuriken v2 with aftermarket fan
HDD: 2x 3 TB 3.5'' and 1x 4 TB 3.5''
SSD: 1x 256 GB + 1x 64 GB
GFX: 1x Gigabyte 390X G1, 1x Club3D 7870 eyefinity 6
Loop components:
Block: Alphacool 390 M04 for the 390X
Tubing: 8/10mm (will give a honest try to sleeving most of it) either UV silver gray or UV red.
Pump: Alphacool DC-LT 3600 rpm rev 2 (~120 l/h flow rate, ~2.2 m H2O pressure) with plexi top
Res: 100 x 50 mm tube res with after-market acetal caps (because of weight)
Rad: Alphacool 2x 280 mm, 45 mm thick full copper (1.4 kg dry mass, about 350 ml capacity)
Fans: 2x Phobya Nano-G 14 1000 rpm S7 with fan grills to keep the cat out.
Quick disconnects: Phobya 10/8mm with bulkhead thread - black nickel (very very restrictive but I have these lying around)
Fittings: G1/4'' 8/10mm compression of various types.
It is done and functional
Carniflex is offline
post #2 of 27 (permalink) Old 01-05-2016, 01:39 AM - Thread Starter
Carniflex's Avatar
There are few things I have done already while preparing to get on with the project seriously. Current plan is to stick an AMD 1055T based system with a 4870 with core only block in the case during figuring out what will need to be done and then after being happy with everything would be the main systems turn to go in there after the painting and stuff before the final stages of the project. On the other hand I'm not sure - perhaps I'll paint the case first and then put a 1055T in there to see if everything works ok and then just take 1055T system out and install my main system over a day or two (cable management is not really my thing so doing it takes ungodly amounts of time for me normally).
Anyway - what I have done so far is few brackets I'll be needing to fit some of the stuff I want onto the side panel.
(1) A bracket for quick disconnects. Aluminum L profile, 20 x 30 mm, 3mm thick.
(2) Two brackets for pump, Aluminum L profile, 23.5 x 43.5 mm, 1.5 mm thick
I'll be using 3.2 mm rivets for adding these to the side-panel when I get around to that. Now the question is - should I be painting them before that or would it make more sense to just pant them at some later time when they are already attached to the side-panel. The current plan for the paint is metallic red and I have both black and red sleeving available for tubes. Not sure about paining any of the compression fittings.
post #3 of 27 (permalink) Old 01-05-2016, 02:03 AM - Thread Starter
Carniflex's Avatar
The case before any work starts with it.
Back side - normal 7 slots, it seems PSU orientation is possible only one way and thats ... the wrong way? We'll see about that I guess. With that limited airflow opportunities in the unmodded case I'm pretty sure I will want my PSU fan to look downwards to the CPU socket to help exhaust some of the hotness from that area. There might be also some space for some additional exhaust in the backside.
Front - there is this fancy multi-colored display thing with clock and one temperature sensor. I'll have to see about what does it do exactly at some later stage. Probably if I cant hook up my water temp sensor in there it might be better to get rid of that for something more useful, like a proper intake fan for GPU area.
Well there are the internals. Note the "tube" thingy - it's some kind of plastic construct for the 80mm exhaust fan from the CPU area. It will remain to be seen if I can find any use fot it or will prefer to get rid of it for some larger exhaust or intake fan. One idea which I had was to perhaps use it instead for air intake dumping cold air from outside straight to the CPU intake. Or perhaps even construct some kind of air duct in there so the fan on the CPU cooler sucks in air from the outside through that duct. We'll see ...
Bottom, btw is more or less solid aluminium so it will need probably some kind of air vets for the bottom GFX card to have at least some air. While the bottom card is most of the time idle there is really no point to cook it if it can be helped. And there is this nice old-school speaker for "beep" - it might have to relocate somewhere else if I will go for an 140mm intake fan in the front but in general I like this thingy over the smaller pieso bleepers coming with some modern motherboards.
And that is the sidepanel where everything would need to go. The tubing would be coming out from the back of the case and then go straight to two quick disconnects, then there would be a radiator, radiator fans, pump and res also mounted to that side panel. Why there and not behind the motherboard tray which would be less inconvinient location - because during transport I intend to set the case on the side which is behind the motherboard tray. The GPU block is about 1 kg and last thing I need is damaged PCIe slot because I hit some pothole in the road.
Edit: Forgot to mention - the material seems to be 1mm thick aluminium. Which is a bit on the thin side TBH for a portable case. I might have to reinforce it in some points with some additional sheet metal to make the case a bit more rigid. But overall I'm reasonably happy with the case as far as canavas for my mod goes. It seems to be pretty ok quality with only few minor defects or burrs here and there but I guess 15 years back the standards for a "fancy case" were somewhat different than they are today and considering the price - it's a damn good bang for buck!
post #4 of 27 (permalink) Old 01-05-2016, 02:18 AM - Thread Starter
Carniflex's Avatar
Few shots of the GPU block as well. I might have to mod that one as well a bit to attach a fan to the semi passive part of the block and to have some kind of location for fixing the back end of the heat-sink to the HDD cage (unless I decide to kick the HDD cage out, that is).
post #5 of 27 (permalink) Old 01-15-2016, 04:51 AM - Thread Starter
Carniflex's Avatar
I have now more or less figured out what, exactly, I want to do. It's going to be a rather simple loop of 1 radiator, 1 pump, 1 res and 1 GPU block.
This is the external view of the sidepanel with all components in correct scale (done in autocad). What I am open about is the arrangement of the radiator - I'm not sure if I want to do push or pull and if it would be better to put the fans above radiator or under it. If I would put them above it it would be some additional protection for the radiator from mechanical damage, if I put them under it that would hide the fan cables a lot better.
Yellow box is 50x100 mm res, red lines represent tubing with hot water from the gpu and blue lines the coolant after going through the rad going back into the case.
post #6 of 27 (permalink) Old 01-15-2016, 05:22 AM
ლ(╹ε╹ლ)
Subbed, I want to see what you come up with. I see you like modding and went with a cheap alternative to the suggestions to make your own case, great idea! thumb.gif
Duality92 is offline
post #7 of 27 (permalink) Old 01-15-2016, 07:21 AM
dirty elf's Avatar
Rep: 8 (Unique: 8)
subbed for the ride
///M
First Build
(16 items)
Intel Core i7-870 Lynnfield
Asus P7P55D-E Pro
MSI RADEON RX480 8GB
G.Skill Ripjaws 2 x 8GB
Crucial MX 300
Western Digital Caviar Black SATA 6gb/s 7200rpm Drive
Optical Drive
LG Blu-Ray Drive
Corsair 650TX 650 Watt
Cooler Master Hyper 212 Evo
Antec Three Hundred
Operating System
Windows 7 64-bit Home
Dell U2417H
Dell U2417H
Keyboard
Apple USB Keyboard
Mouse
Logitech M510
Audio
Bose Companion II Series
dirty elf is offline
post #8 of 27 (permalink) Old 01-15-2016, 09:26 AM - Thread Starter
Carniflex's Avatar
Any good guides on how to paint plexi with automotive paint?
I am considering an option to do a grill for protecting the radiator fins from a 2mm laser-cut Plexiglas as I'm sitting few spare sheets of clear version of it and will need to do a trip to the laser cutter anyway for one other project of mine which has been stalled for a while. .
That should be fairly non-restrictive pattern I'd imagine. Then again perhaps it would be easier to just bolt couple of normal 140mm fan-grills to the radiator if putting fans under it and call it a day. It probably would be a lot more durable for a mobile system than plexi wink.gif
Also - do I need a clear over-layer if I use automotive metallic paint? I got one spray can of metallic red which should be adequate for my purposes but information in the net seems to be a bit conflicting with some sources claiming that the clear over-layer must be used to protect the paint while others seem to imply that it's gonna be fine also without it. On anodized aluminum I should be able to get away without primer as far as I understand.
post #9 of 27 (permalink) Old 01-16-2016, 07:51 AM
dirty elf's Avatar
Rep: 8 (Unique: 8)
clear will help protect the paint, pretty much that simple. if it will be in a place where the paint can get knicked or scratched a lot then I would clear it. if it's going to be a showpiece on the shelf then clear is probably not needed
///M
First Build
(16 items)
Asus P7P55D-E Pro
Crucial MX 300
Optical Drive
LG Blu-Ray Drive
Antec Three Hundred
Operating System
Dell U2417H
Dell U2417H
Keyboard
Apple USB Keyboard
Mouse
Logitech M510
Audio
post #10 of 27 (permalink) Old 01-22-2016, 08:25 AM - Thread Starter
Carniflex's Avatar
At last some rubber washers arrived which I ordered from ebay a while ago. M4 and 2.5mm thick I'll be using them with the pump to (perhaps) dampen some vibrations.
Other than that do not have much progress to report. It's far too cold for painting atm anyway (below -10C) probably will have to figure out some way to do the painting somewhere inside without splattering it everywhere.
