Project: Half Life 2: Gordon Freeman edition - Page 12 - Overclock.net - An Overclocking Community
post #111 of 120 (permalink) Old 07-20-2019, 02:05 PM - Thread Starter
SotosLg's Avatar
Rep: 3 (Unique: 2)
Hello again!! Today was a big day as i did made the holes for the wheels, painted the case and glued the first two pieces of the logo to one side panel!!
So, first things first, the day doesn't begin without a cup of coffee so lets proceed!!
Here i took the already existing holes and widen them for the rivets to fit properly!!
Same thing happened to the rest of the feet!!
So, next i took the side panel i had it cure over night from fiberglass repair and did a slight repair also today!!
Furthermore, i glued the first two pieces of the game's logo where they should be placed on the side panel!!
So, i took the pieces and sanded them down a bit to roughen its surface for the fiberglass to stick better!!So, next i took the side panel i had it cure over night from fiberglass repair and did a slight repair also today!!
Next i marked the area so i could sand it a bit to stick better!!
Then i made some fiberglass mixture with some silicon and thinned it with aceton so i can process it longer!!
Using that stick i spreaded the fiberglass where it should be placed and sticked the logos!!
It doesn't matter if the liquid exceeds the drawing as it will be painted so it will match the front panel and the inside!! The crackle effect will remain in some areas to show that both painting techniques are used!! The post will continue next!!
SotosLg is offline
post #112 of 120 (permalink) Old 07-20-2019, 02:11 PM - Thread Starter
SotosLg's Avatar
Rep: 3 (Unique: 2)
The post continues!!
So now, it is time to paint the case!!
But before every paint always comes the primer first!!
Now it is time to paint ti orange gloss!!
SotosLg is offline
post #113 of 120 (permalink) Old 07-20-2019, 02:19 PM - Thread Starter
SotosLg's Avatar
Rep: 3 (Unique: 2)
So, here now lets paint it black!! Here is the cause for that effect!! I apologize for the poor quality photo, i couldn't have that time very adequate lighting!!
 Here is the inner bottom side painted with the plastic bag effect!!
Then, the rest of the case!!
 I thought then to add some extra effect on it and i decided to add some paint splashes!!
ID:	282180Click image for larger version
ID:	282176Click image for larger version
And bottom side!!
Final picture for today!! I must say i am quite ecstatic with the result, i wouldn't expect to get that beautiful!!
 So, that is all for today, more will come tomorrow with the hardware installation and see if everything goes as they should be working!! Until then, Peace Brothers!!
SotosLg is offline
post #114 of 120 (permalink) Old 07-20-2019, 02:29 PM - Thread Starter
SotosLg's Avatar
Rep: 3 (Unique: 2)
Hello again!! Today was the day i installed the parts and did a fresh windows installation!!
The components so far are:
PSU: CoolerMaster G750M
RAM: Gskill Ares orange colour
CPU: Amd Phenom 2 x6 1100t (stock clocks)
Motherboard: Asus Crosshair IV formula
SSD: Corsair force LS 120gb
GPU: Nvidia (XFX) 8800gt (temporary)
The Freeman desperately awaits so lets begin!!
Post at last!!
Along with installing Windows, i installed also the wheels on the case using rivets and screws!!
The detail here is that the front wheels have brakes on them for just in case!!
Next thing to do is install the motherboard tray, the back part of the case and the rear i/o panel!! In the next update i will be posting some cpu-z images or using everest, until then Peace Brothers!!
SotosLg is offline
post #115 of 120 (permalink) Old 07-20-2019, 02:33 PM - Thread Starter
SotosLg's Avatar
Rep: 3 (Unique: 2)
Hello again!! This will be a long update with lots of photos so bare with me!! So, let's begin!!
Here we have the 5.25" where the Freeman will stay!! After some trimming and hair cutting we have this result and ready for the first coat of primer!!
 Here is the bay after one or two thick layers of primer!!
The detail here is to make it look rough or unprocessed!! The post will continue with painting the 5.25" bay!!
SotosLg is offline
post #116 of 120 (permalink) Old 07-20-2019, 02:37 PM - Thread Starter
SotosLg's Avatar
Rep: 3 (Unique: 2)
The post continues!! Here i decided to paint the sides and the inner side orange!! On the two sides i wanted to add a sticker with the logo and paint it and it did went well so i removed it and paint it normally!!
Here is the bay ready to be painted orange!!
 Here is painted orange and ready to add the plastic bag effect!!
After few tries, here is finalized with some extra paint splashes!!
The post will continue with painting the rear part of the case!!
SotosLg is offline
post #117 of 120 (permalink) Old 07-20-2019, 02:41 PM - Thread Starter
SotosLg's Avatar
Rep: 3 (Unique: 2)
The post continues!! Here is the inner side of the rear part of the case ready to be primered and painted!!
Here is painted with the plastic bag effect!!
The i added an extra effect some paint splashes before i apply clear coat!!
 I apologize for the poor image quality, there was not adequate lighting!! The post will continue with clear coating the parts!!
SotosLg is offline
post #118 of 120 (permalink) Old 07-20-2019, 02:50 PM - Thread Starter
SotosLg's Avatar
Rep: 3 (Unique: 2)
The post continues!! Now it is time to apply clear coat to all of the parts and first in line is the rear part of the case!!
The are the other parts too waiting to be clear coated!!
Next what i did to the rear part was to darken it a bit and add some paint splash too!!
ID:	282256Click image for larger version
ID:	282252Click image for larger version
 On that part i applied some rust effect few weeks back so next in line are the main case, the motherboard tray and the rear i/o panel!! The post will continue!!
SotosLg is offline
post #119 of 120 (permalink) Old 07-20-2019, 02:57 PM - Thread Starter
SotosLg's Avatar
Rep: 3 (Unique: 2)
The post continues!! So next in line to be clear coated is the main case!!
ID:	282294Click image for larger version
ID:	282292 Click image for larger version
Next in line are the rear i/o panel and the motherboard tray!!
ID:	282278Click image for larger version
 Next and final for today is the upper panel with the logo attached, so the post will continue!!
SotosLg is offline
post #120 of 120 (permalink) Old 07-20-2019, 03:10 PM - Thread Starter
SotosLg's Avatar
Rep: 3 (Unique: 2)
The post continues!! Last part for today!! Here i apply clear coat on the upper panel and some extra effect to make it look relevant to the rest of the case!!
Here i applied the plastic bag effect with a slight different way!! The sponge method with the plastic bag!!
Here now comes the clear coat in some angles!!
ID:	282310Click image for larger version
ID:	282306Click image for larger version
Some areas are not quite visible because the paint couldn't reach that part!! I might be adding some paint splash on that part tomorrow where installing the parts will happen!! Untill then Peace Brothers!!
SotosLg is offline
