[Build Log] Ryzen & Vega. Enthoo Evolv ATX TG Case Mod - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 04-08-2017, 12:10 AM - Thread Starter
phillyd's Avatar
Rep: 188 (Unique: 146)
I've already started this build, but I'm not finished. I'm doing a silver/grey and black theme with rgb lighting, and I want to include some elements of Yin & Yang in the build. Currently the case is unmodded.
Current Hardware:
AMD Ryzen R7 1700 @3.9GHz
MSi X370 XPOWER GAMING TITANIUM
G.Skill Trident Z RGB 16GB @3000MHz
XFX R9 290X Double Dissipation
Corsair CX850M
Crucial M4 128GB x2 RAID 0
Western Digital Enterprise 2TB
EK Supremacy Evo AMD Nickel Plexi
Alphacool NexXxos GPX
Alphacool NexXxos Monsta 240 (push, front intake)
Alphacool NexXxos XT45 360 (push, top exhaust)
Swiftech D5
Monsoon Compression fittings
Corsair Air SP 120 and AF140
I will be posting mod plans, pictures, final component list, and more soon. The first mod plan involves frosting the inside of the glass panel behind the motherboard tray with using a stencil to leave a transparent section in either a Yin and Yang symbol or something with the Ryzen and Vega logos. Other mods will include front and top panel airflow modifications and/or decals, cable sleeving, and lots of fun with the lighting.
Final Components (tentative):
G.Skill Trident Z RGB 32GB @3000MHz plus
Vega Flagship GPU
Corsair RM850x
Western Digital (or other) 256GB M.2 SSD
New, good looking 512GB SATA SSD
EK Nickel Plexi GPU block
Alphacool NexXxos ST30 (push, top exhaust)
Alphacool NexXxos XT45 360 (push/pill, front intake)
Swiftech D5 with Barrow D5 top, heatsink and tube reservoir
Barrow Compression fittings
NZXT Aer or other RGB fans
Ryzen & Vega Enthoo Evolv ATX TG Case Mod Build Log
Audio (Click to show)
Sources: The Spectre | Lenovus Maximus | Huawei Honor 8
DAC's: HiFimeDIY Sabre SPDIF | iBasso D-Zero
Amplification:ASL MG-Head OTL Mark III
Headphones: Sennheiser HD650 | Shure SE215K | Logitech UE6000
Speakers
Home Theater/Lenovus Maximus: Pioneer Elite SC-85 > Music Angel SDXE M9 > Klipsch KG5.2 w/Crites tweeters/crossovers
The Spectre: Adam Ax7
Build Logs (Click to show)Overclocking Accolades (Click to show)
phillyd is offline
post #2 of 9 (permalink) Old 04-08-2017, 12:23 AM - Thread Starter
phillyd's Avatar
Pictures! Warning: Spoiler! (Click to show)
Speakers
phillyd is offline
post #3 of 9 (permalink) Old 04-08-2017, 12:23 AM - Thread Starter
phillyd's Avatar
Reserved
Speakers
phillyd is offline
post #4 of 9 (permalink) Old 04-08-2017, 02:32 AM
Zantrill is offline
post #5 of 9 (permalink) Old 04-08-2017, 02:55 AM
wrath04's Avatar
Rep: 2 (Unique: 2)
Subbed, Look's like a great parts list you have there! Cant wait to see what you came up with , good luck!
wrath04 is offline
post #6 of 9 (permalink) Old 04-08-2017, 07:27 AM
Mora's Avatar
Rep: 0
Subbed, looks like a similar build to my own.
Mora is offline
post #7 of 9 (permalink) Old 04-09-2017, 12:32 PM - Thread Starter
phillyd's Avatar
Here's how the PC looks as of now!
Speakers
phillyd is offline
post #8 of 9 (permalink) Old 08-15-2017, 01:58 PM - Thread Starter
phillyd's Avatar
Just wanted to leave a quick update. Going to get Vega 64 and a water block as well as some new water cooling gear (smaller radiator, new fittings and tubing, new reservoir and pump) in the next several weeks! Waiting on Vega availability and possibly prices to stabilize.
Speakers
phillyd is offline
post #9 of 9 (permalink) Old 08-24-2017, 09:32 PM
msd0's Avatar
Rep: 15 (Unique: 12)
Very nice job with the cables on the back of the case. I have the same case and it looks like relocating the fan hub makes a big difference.
msd0 is offline
