Roisin Dearg, a Scratch Built Case (part 2 of Preparing for a Scratch Built Case) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 199 (permalink) Old 12-18-2017, 01:33 AM - Thread Starter
Senioritis Member
Lady Fitzgerald's Avatar
Rep: 527 (Unique: 330)
Mini update (no pictures yet). After spending much of the day Saturday running errands and airing up my tires, I spent most of the rest of the day cloning the 500GB SSD in my notebook to a 2TB SSD, then cloning my main data drive in my desktop computer to the data partition on the notebook SSD, then updating programs, etc. as well as populating two 2TB backup SSDs and installing them in USM enclosures. I still have some more work to do on the notebook but I'm giving it a rest for a day or two.
Saturday evening, I rough cut the MOBO tray back plate, then called quits at midnight. I got up at 4AM due to a ferocious thunderstorm with thunder so loud, it shook the house. I went back to slept about 8AM since I was still worn out from Saturday. I didn't set the alarm since my bladder usually wakes me up every two hours. I slept through to 1 PM!
After lunch, I went back to work on the back plate. I drilled the top for mounting screws, then cut and drilled an angle for the side that goes against the back case panel and riveted it to the back plate (not difficult but tedious.
Sunday, I did a lot of finish filing on the edges of the back plate, then made a tab to rivet to the angle and screw to the rear case panel flange I had just installed so the bottom rear corner of the back plate wouldn't be flapping around but could still allow me to remove the back plate for further work and for any future mods. I also cut, drilled, and installed rivet nut inserts in an angle for the other side of the back plate. I still need to do a ton of filing on that angle (groan), then layout and drill the holes to mount the angle to the back plate (for now, the angle is screwed to the left side panel of the 5.25" bay.
I also knocked over my number drill standard and spilled out all but ten of the bits. I now get to mic and put away around fifty drill bits (mutter, mutter, mumble, mumble). I may wait unto after the Holidays for that onerous, BORING task.
It's well past my bedtime so I'm off to bed. Hopefully, I'll finish with that last angle, get it taped and riveted to the back plate, add a 1/4" square bar stiffener on the bottom of the back plate tomorrow so I can get some pictures of it. Then, I get to figure out the layout for the MOBO tray itself and cut big holes in the middle of the back plate and the rear case panel.
Jeannie
i7-3930k
ASUS P9X79 WS
MSI R7850 Twin Frozr 2GD5/OC Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Monoprice 1x2 powered HDMI Splitter
Kingston HyperX 32GB (8 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K8/32GX
128GB Samsung 840 Pro SSD
4TB Samsung 850 EVO SSD
Optical Drive
LG 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive CH12LS28
Corsair HX750W
COOLER MASTER GeminII S524 120mm Long Life Sleeve CPU Cooler
Antec Two Hundred v2
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Logitech M525 with Unifying Receiving
Audio
Corsair SP2500 2.1 Speakers
Audio
ASUS Xonar Essence STX Virtual 7.1 Channels 24-bit 192KHz PCI Express x1 Interface 124 dB SNR / Headphone AMP Card
Other
LSI 9211-8i HBA card
Other
HooToo® HT-CR001 3.5" PCI-E to USB 3.0 Multi-in-One Front Panel Internal Card Reader (6 Memory Slots, Genesys GL3220 Chipset) & SuperSpeed USB 3.0 3-Port Hub (VIA VL800 Chipset), can read & write: M2/MS Micro, High-Speed CF(UDMA), UHS-I, SD, SDHC,...
Other
StarTech HSB220SAT25B 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane
i7-5930K Haswell-e
Asus X99-E WS/USB 3.1
Visiontek Radeon 7870 2GB with 6 miniDisplayports
G-Skill Ripjaws 64GB (8x8GB) DDR4 2133
Samsung 850 EVO 4TB SSDs
Samsung 950 Pro 512GB m.2 SSD boot drive
Corsair AX760
Noctua NH-D15S Cpu cooler
Scratch built. Currently under construction at https://www.overclock.net/t/1602023/preparing-for-a-scratch-built-case
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
El Cheapo Allsop hard plastic
Lady Fitzgerald is offline
post #22 of 199 (permalink) Old 12-18-2017, 07:41 AM
Typo Elemental
Simmons572's Avatar
You knocked over a box of drill bits too? We just had to play 300 pickup last saturday when my brother elbowed the box of bits off the top of the workbench rolleyes.gif
AMD Threadripper 1900x
Asus Prime X399-A
EVGA 1080 Classified
Samsung 960 Evo
Intel 750 Series 400GB U.2
Samsung 850 Pro 512 GB
Seasonic 1050w 80+ Gold
Corsair Air 740
Operating System
Windows 10 Pro
i5 6600k
Asus Z170i Pro Gaming
Sapphire R9 Nano
Kingston FURY 16GB (2 x 8GB) DDR4-2400
Samsung 950 Pro 512 GB
Athena AP-MFATX40 400W Flex-ATX
be quiet! ​PURE ROCK ​SLIM
Lian-Li PC-TU 100B
Operating System
Windows 10 Pro
ViewSonic XG2401
Keyboard
MK Disco RGB TKL (KBT Brown)
Mouse
Razer Mamba TE
Mouse
Razer Firefly Cloth
Audio
Beyerdynam​ic DT 770 ​Pro 80 ohm
Audio
Antlion Audio ModMic 4 w/ Mute
Audio
Schiit Fulla 2
Other
Noctua NF-A9x14 (x2)
Other
Fractal Design FD-FAN-SSR2-92
Other
Fractal Design FD-FAN-SSR2-60 (x2)
Other
Fractal Design GP12-WT
i7 6800k
Xeon e5-1620 V3
EVGA Micro 2
Asus GTX 780
Sapphire Fury X
Sapphire RX 480
Kingston - FURY 8GB (2 x 4GB) DDR4-2400
ADATA - XPG Z1 8GB (2 x 4GB) DDR4-2400
SanDisk - SSD PLUS 240GB
Kingston - SSDNow V200
Corsair HX850i
be quiet! - PURE ROCK
Thermaltake Core V21
Operating System
Windows 10 Pro
Simmons572 is offline
post #23 of 199 (permalink) Old 12-18-2017, 10:41 AM - Thread Starter
Senioritis Member
300 pickup? That had to be "fun". At least I have only fifty to do (I figure that will be an all day project).
Welcome aboard!
Jeannie
i7-3930k
ASUS P9X79 WS
Optical Drive
Corsair HX750W
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Audio
Audio
Other
Other
Other
i7-5930K Haswell-e
Corsair AX760
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
post #24 of 199 (permalink) Old 12-18-2017, 11:55 AM
Typo Elemental
Simmons572's Avatar
Welcome aboard!
Asus Prime X399-A
Samsung 960 Evo
Corsair Air 740
Operating System
Windows 10 Pro
i5 6600k
Sapphire R9 Nano
Lian-Li PC-TU 100B
Operating System
Windows 10 Pro
ViewSonic XG2401
Keyboard
Mouse
Razer Mamba TE
Mouse
Razer Firefly Cloth
Audio
Audio
Audio
Schiit Fulla 2
Other
Other
Other
Other
i7 6800k
Xeon e5-1620 V3
EVGA Micro 2
Asus GTX 780
Sapphire Fury X
Sapphire RX 480
Corsair HX850i
Operating System
Windows 10 Pro
post #25 of 199 (permalink) Old 12-19-2017, 01:12 AM - Thread Starter
Senioritis Member
Post number 3 was updated 12/18/2017.
Jeannie
i7-3930k
ASUS P9X79 WS
Optical Drive
Corsair HX750W
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Audio
Audio
Other
Other
Other
i7-5930K Haswell-e
Corsair AX760
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
post #26 of 199 (permalink) Old 01-07-2018, 12:44 AM - Thread Starter
Senioritis Member
Post number three was updated 01/07/2018.
Jeannie
i7-3930k
ASUS P9X79 WS
Optical Drive
Corsair HX750W
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Audio
Audio
Other
Other
Other
i7-5930K Haswell-e
Corsair AX760
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
post #27 of 199 (permalink) Old 01-07-2018, 05:49 PM - Thread Starter
Senioritis Member
Post #3 received a minor update (with a few pictures) on 01/07/2018.
Jeannie
i7-3930k
ASUS P9X79 WS
Optical Drive
Corsair HX750W
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Audio
Audio
Other
Other
Other
i7-5930K Haswell-e
Corsair AX760
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
post #28 of 199 (permalink) Old 01-08-2018, 11:05 PM - Thread Starter
Senioritis Member
Post # 4 received an update 01/08/2018. It's starting to look more and more like a computer case!
Jeannie
i7-3930k
ASUS P9X79 WS
Optical Drive
Corsair HX750W
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Audio
Audio
Other
Other
Other
i7-5930K Haswell-e
Corsair AX760
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
post #29 of 199 (permalink) Old 01-09-2018, 11:32 PM - Thread Starter
Senioritis Member
Post #4 was updated 01/09/2018.
Jeannie
i7-3930k
ASUS P9X79 WS
Optical Drive
Corsair HX750W
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Audio
Audio
Other
Other
Other
i7-5930K Haswell-e
Corsair AX760
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
post #30 of 199 (permalink) Old 01-10-2018, 12:08 PM - Thread Starter
Senioritis Member
Post #4 was update 01/10/2018.
Jeannie
i7-3930k
ASUS P9X79 WS
Optical Drive
Corsair HX750W
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Audio
Audio
Other
Other
Other
i7-5930K Haswell-e
Corsair AX760
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
