[Build Log] True Blue and UV, my first OCed and water cooled computer. - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 01-01-2018, 09:07 PM - Thread Starter
Intel Overclocker
JMTH's Avatar
Rep: 16 (Unique: 14)
Hello, well I guess I am doing this in the wrong order (since its already finished lol) but here goes!
Some of these components I already owned, but I listed them anyway.
Components, Rev A Build:
Case - Corsair Obsidian Series 750D Performance Full Tower Case
Motherboard - X99-DELUXE II
CPU - Boxed Intel Core i7-6850K Processor - Broadwell-E
Memory - G.SKILL TridentZ Series 64GB (4 x 16GB) 288-Pin DDR4 SDRAM DDR4 3300 (PC4 26400) Desktop Memory Model F4-3300C16Q-64GTZKW
Power supply - CORSAIR RMi Series RM850i 850W 80 PLUS GOLD
Hard drives - 2X Samsung 850 EVO 500GB 2.5-Inch SATA III Internal SSD (MZ-75E500B/AM), 1X Win 7 Samsung 960 EVO Series - 250GB PCIe NVMe - M.2 Internal SSD (MZ-V6E250BW), 2X 2 TB Seagate Drive RAID 1 Storage.
Video Card - AMD 100-505940 Radeon Pro WX 5100 8GB GDDR5
Cooling;
Additives - Petra's Tech Nuke PHN Concentrated Biocide, Feser View UV Dye - UV Clear
Thermal Interface - Thermal Grizzly Conductonaut Thermal Grease Paste
Fans - 2X Corsair ML140 Pro, 140mm Premium Magnetic Levitation Cooling Fan CO-9050045-WW
EK-FB ASUS X99 Monoblock - Nickel
EK-HDC Fitting 16mm G1/4 - Nickel
EK-RAM Monarch X4 - Nickel
EK-RAM Monarch Module - Nickel (2pcs)
EK-CoolStream CE 280 (Dual)
EK-DBAY D5 PWM (incl. pump)
EK-AF FillPort G1/4 - Nickel
EK-AF Angled 90° G1/4 Nickel
EK-AF Extender 20mm M-M G1/4 - Nickel
EK-AF Extender 20mm M-F G1/4 - Nickel
EK-AF Extender 50mm M-F G1/4 - Nickel
EK-AF T-Splitter 3F G1/4 - Nickel (QClass2)
EK-AF Extender Rotary M-M G1/4 - Nickel
EK-ACF Fitting 12/16mm - Nickel
EK-AF Ball Valve (10mm) G1/4 - Nickel
EK-AF Angled 90 G1/4 Fitting - Black Nickel
Alphacool Eiszapfen quick release connector kit G1/4 inner thread - Chrome
TUBE PrimoChill PrimoFlex™ Advanced LRT™ 15
PrimoChill Vortex Black POM Visual Flow Indicators - UV Blue Faceplates (FI-V-UB)
Alphacool G1/4 Flow Indicator with RPM Signal | Plexi (17176)
Koolance Threading Adapter, G 3/8" Male to G 1/4" Female
Cables;
Wire - M1 Custom 2.4mm OD White 16 AWG
Sleeving
LutroO Customs Teleios 4mm Sleeving - Fusion Black / Aqua Blue - 25 Foot
LutroO Customs Teleios 4mm Sleeving - Fusion Blue / Aqua Blue - 25 Foot
Aquamarine MDPC-X Small Sleeve (25ft)
Riviera-Blue MDPC-X Small Sleeve (25ft)
Black MDPC-X Small Sleeve (25ft)
Darkside 2mm (5/64") High Density Cable Sleeving - Dark Blue UV (DS-HD2-BLU)
Darkside 2mm (5/64") High Density Cable Sleeving - Aquamarine Blue (DS-0057)
Darkside 2mm (5/64") High Density Cable Sleeving - Black (DS-HD2-BLK)
Aquamarine MK2 MDPC-X SATA Sleeve (5ft)
Black MDPC-X SATA Sleeve (5ft)
Riviera-Blue MDPC-X SATA Sleeve (5ft)
Connectors
FrozenCPU ConnectRight 24-Pin Female ATX Power Connector - Blue UV
FrozenCPU ConnectRight 8-pin Male 12V EPS Power Connector - UV Blue
FrozenCPU ConnectRight DIY SATA EZ Crimp Connector - Blue UV - 90° (M-SCA-16F-UB), Cover Style!: End Cap
FrozenCPU ConnectRight DIY SATA EZ Crimp Connector - Blue UV - 90° (M-SCA-16F-UB), Cover Style!: Pass Thru Cap
FrozenCPU ConnectRight 14-Pin Male PSU Power Connector - Corsair / Seasonic - UV Blue
FrozenCPU ConnectRight 10-Pin Male PSU Power Connector - Corsair / Seasonic - UV Blue
FrozenCPU ConnectRight 6-Pin (Upside Down) Male PSU Power Connector - Corsair / Seasonic - UV Blue
FrozenCPU ConnectRight 4-pin Male 12v Pentium 4 Power Connector - UV Blue
FrozenCPU ConnectRight ATX / PCI / EPS Gold-Plated Connector Pins - Female - 4 Pack
FrozenCPU ConnectRight 18-Pin Male PSU Power Connector - Corsair / Seasonic - UV Blue
FrozenCPU 4-pin Male PWM Fan Connector - UV Blue
FrozenCPU ConnectRight Standard 4-pin Female Connector - UV Blue
FrozenCPU ConnectRight Standard 4-pin Male Connector - UV Blue
FrozenCPU ConnectRight 6-pin Female PCI-Express Power Connector "Version 2" - UV Blue
Cable Management
Icemodz Cable Comb Clear Closed - 24-pin
Icemodz Cable Comb Clear Closed - 14-pin
Icemodz Cable Comb Clear Closed- 8-pin
Icemodz Cable Comb Clear Closed- 6-pin
Icemodz Cable Comb Clear Closed- 4-pin
Misc:
USB 3.0 20-Pin Internal Header MF Extension Cable (Low Profile Connector) (CAB027)
Phobya G1/4 Inner/Outer Temperature Sensor with C/F Display (71177)
8X Alphacool Aurora HardTube LED Ring 16mm Deep Black - UV (15292)
Bitspower X-Station LED Power Hub - UV LED (BP-XSLEDPH-UV)
16.4 ft RGB 5050 LED LightStrip
16.4 ft 3528 UV LightStrip
Zitrades 5050 LED LightStrip Connectors (Qty 10)
NZXT Internal USB Hub Controller
Monitors - 2X ViewSonic 27"
Mouse - Logitech G502 Proteus Spectrum
Keyboard - Logitech G510
Rev B components when Deluxe ii had to be RMAed
EK-FB ASUS R5-E10 Monoblock RGB Edition
Black Ice Nemesis 280GTX® Dual-Core Xtreme Profile Radiator - Black Carbon
4X EK-Furious Vardar EVO 140 (2500rpm)
ASUS ROG RAMPAGE V EDITION 10 LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.1 USB 3.0 Extended ATX Motherboards - Intel
Corsair AX1200i finally a PSU with the same number of pinouts as the mobo needs!
Components Removed in Rev B
ASUS Deluxe ii
Alphacool G1/4 Flow Indicator with RPM Signal | Plexi (17176) - Made too much noise the clicking sound was driving me crazy!
Corsair RM850i I still want to kick the person who made the pinout!
ASUS Maximus XII Extreme, delided i7-10700k, 32GB (2x15) G.Skill F4-4000C19D-32GTZR, ROG-STRIX-RTX2080TI-O11G-GAMING, Custom water loop. || 24x7 Sync: 5100 MHz Core, 100 BCLK, 4800 MHz Cache, DDR4-4200 MHz @ 16-16-16-29-CR2, Core 1.375v, VCCIO 1.23v, VCCSA 1.215v, 1.375v DRAM, LLC 4. || Video Card OC: 1810 MHz Clock (+160), 16000 MHz Memory (+2000), +100% Voltage Limit, 125% Power Limit (+25%) || BIOS: 0607, OS: Windows 10 Pro x64, Version 1903, Build 18362.900 || X99 Build Log ||
True Blue (and UV)
(21 items)
True Blue Upgrade
(7 items)
Intel Boxed Core i7-6850K Processor (15M Cache, up to 3.80 GHz) FC-LGA14A 3.6 6 BX80671I76850K
ASUS Rampage V Edition 10
AMD 100-505940 Radeon Pro WX 5100 8GB GDDR5 4 DisplayPort's Workstation Video Card
Seagate Barracuda ST2000DM006 - hard drive - 2 TB - SATA 6Gb/s
Samsung 960 Pro 512 GB M.2
Optical Drive
ASUS Computer International Direct Blu-Ray Writer BW-16D1HT
CORSAIR AX1200i
Custom EK Liquid Cooling, details in comments
Operating System
Windows 10 Pro
ViewSonic VA2702w
Benq PD3200U
Keyboard
Logitech G510
Mouse
Other
Sleeving, Combs, Wire/Cables, Connectors, Pins, and Ties, Clamps (Check Comments)
Other
Lights, so far (Check Comments)
Other
Tools (Check Comments)
Other
Tax, Shipping (Check Comments)
i7-10700k
ASUS Maximus XII Extreme Z490
F4-4000C19D-32GTZR
Samsung 970 Pro
Corsair AX1200i
Custom Water Cooled
JMTH is offline
post #2 of 15 (permalink) Old 01-01-2018, 09:12 PM - Thread Starter
Intel Overclocker
JMTH's Avatar
The first components arrive!
Strip the case down.
Planning on having a Blue ray burner installed. Also one of my dogs in the background heh.
Pull the front panel connectors / switch housing apart, what a mess.
True Blue (and UV)
(21 items)
True Blue Upgrade
(7 items)
Optical Drive
CORSAIR AX1200i
Operating System
Windows 10 Pro
ViewSonic VA2702w
Benq PD3200U
Keyboard
Logitech G510
Mouse
Other
Other
Other
Other
i7-10700k
F4-4000C19D-32GTZR
Samsung 970 Pro
Corsair AX1200i
Custom Water Cooled
JMTH is offline
post #3 of 15 (permalink) Old 01-01-2018, 09:18 PM - Thread Starter
Intel Overclocker
JMTH's Avatar
More components!
Fill tube hits the front panel connector / switch housing mounting features.
No problem, we can cut that out!
We have clearance Clarence. Yes I cleaned it up a little better! Just cant find that pic yet lol!
True Blue (and UV)
(21 items)
True Blue Upgrade
(7 items)
Optical Drive
CORSAIR AX1200i
Operating System
Windows 10 Pro
ViewSonic VA2702w
Benq PD3200U
Keyboard
Logitech G510
Mouse
Other
Other
Other
Other
i7-10700k
F4-4000C19D-32GTZR
Samsung 970 Pro
Corsair AX1200i
Custom Water Cooled
JMTH is offline
post #4 of 15 (permalink) Old 01-01-2018, 09:26 PM - Thread Starter
Intel Overclocker
JMTH's Avatar
Time to put the fill tube in! Measure twice, cut 20 times!
Its open!
Looking good!
No just to install the Res/Pump, clank, what? Dooh!
Never fear dremel is here! And about 2 hours of grinding to make the electrical box coupling work heheh, Like a glove!
Found the pics where I cleaned it up!
True Blue (and UV)
(21 items)
True Blue Upgrade
(7 items)
Optical Drive
CORSAIR AX1200i
Operating System
Windows 10 Pro
ViewSonic VA2702w
Benq PD3200U
Keyboard
Logitech G510
Mouse
Other
Other
Other
Other
i7-10700k
F4-4000C19D-32GTZR
Samsung 970 Pro
Corsair AX1200i
Custom Water Cooled
JMTH is offline
post #5 of 15 (permalink) Old 01-01-2018, 09:33 PM - Thread Starter
Intel Overclocker
JMTH's Avatar
Ok I think I want this spinney thing here but how to hold it on.
Wish I had a drill press, while it looks sloppy hehe it works!
True Blue (and UV)
(21 items)
True Blue Upgrade
(7 items)
Optical Drive
CORSAIR AX1200i
Operating System
Windows 10 Pro
ViewSonic VA2702w
Benq PD3200U
Keyboard
Logitech G510
Mouse
Other
Other
Other
Other
i7-10700k
F4-4000C19D-32GTZR
Samsung 970 Pro
Corsair AX1200i
Custom Water Cooled
JMTH is offline
post #6 of 15 (permalink) Old 01-01-2018, 09:39 PM - Thread Starter
Intel Overclocker
JMTH's Avatar
Ok time to prep the memory. Qty 4
Now the Motherboard
Ok now fit check!
True Blue (and UV)
(21 items)
True Blue Upgrade
(7 items)
Optical Drive
CORSAIR AX1200i
Operating System
Windows 10 Pro
ViewSonic VA2702w
Benq PD3200U
Keyboard
Logitech G510
Mouse
Other
Other
Other
Other
i7-10700k
F4-4000C19D-32GTZR
Samsung 970 Pro
Corsair AX1200i
Custom Water Cooled
JMTH is offline
post #7 of 15 (permalink) Old 01-01-2018, 09:49 PM - Thread Starter
Intel Overclocker
JMTH's Avatar
Ok lets get the PSU in there
Ok where to put the Fan Extension board...
The first sleeved cable is in!
Time to bend some tubes! Yes first time hehe what a pain! Not a single straight run! I was also planning on adding a parallel path to the GPU, but I never did. Thats why the 3 way block is right after the flow indicator. Lets add a loop just for fun as well!
True Blue (and UV)
(21 items)
True Blue Upgrade
(7 items)
Optical Drive
CORSAIR AX1200i
Operating System
Windows 10 Pro
ViewSonic VA2702w
Benq PD3200U
Keyboard
Logitech G510
Mouse
Other
Other
Other
Other
i7-10700k
F4-4000C19D-32GTZR
Samsung 970 Pro
Corsair AX1200i
Custom Water Cooled
JMTH is offline
post #8 of 15 (permalink) Old 01-01-2018, 09:57 PM - Thread Starter
Intel Overclocker
JMTH's Avatar
Time for some paint!
Sleeves while the paint dries!
Start installing!
Kick it into high gear!
Lets see how the UV looks!
True Blue (and UV)
(21 items)
True Blue Upgrade
(7 items)
Optical Drive
CORSAIR AX1200i
Operating System
Windows 10 Pro
ViewSonic VA2702w
Benq PD3200U
Keyboard
Logitech G510
Mouse
Other
Other
Other
Other
i7-10700k
F4-4000C19D-32GTZR
Samsung 970 Pro
Corsair AX1200i
Custom Water Cooled
JMTH is offline
post #9 of 15 (permalink) Old 01-01-2018, 10:06 PM - Thread Starter
Intel Overclocker
JMTH's Avatar
The wife wants me dead!
The final nightmare, some jerk at Corsair creates a pinout from hell. 28 at the PSU side and 23 at the Mobo. I want names!!! Lol
Time to install the UV lights!
Ok start installing again! If only this Mobo cable pin-out didn't twist the signals 5 ways from Sunday!
Ok its time to fill and start testing / ocing!
Done!
True Blue (and UV)
(21 items)
True Blue Upgrade
(7 items)
Optical Drive
CORSAIR AX1200i
Operating System
Windows 10 Pro
ViewSonic VA2702w
Benq PD3200U
Keyboard
Logitech G510
Mouse
Other
Other
Other
Other
i7-10700k
F4-4000C19D-32GTZR
Samsung 970 Pro
Corsair AX1200i
Custom Water Cooled
JMTH is offline
post #10 of 15 (permalink) Old 01-01-2018, 10:09 PM - Thread Starter
Intel Overclocker
JMTH's Avatar
Ok OCing goes ok, but I start having issues with my Deluxe ii. After trying to deal with tech support at ASUS, I give up and RMA it. Well, its going to be awhile before I get it back so lets just buy a new Mobo and sell the Deluxe ii for a loss when I get it back! Sweet! Go team money drain!!!
The New Mobo!
New PCIe M.2 Watercooled card, because I also bought a new 960 Pro NVMe! The 960 EVO was running really hot!
New Fans and an additional Rad!
Open the Drain!!!
While attempting to straighten out this mess I um accidentally well, pop! Time to get a new PSU and RMA this one!
True Blue (and UV)
(21 items)
True Blue Upgrade
(7 items)
Optical Drive
CORSAIR AX1200i
Operating System
Windows 10 Pro
ViewSonic VA2702w
Benq PD3200U
Keyboard
Logitech G510
Mouse
Other
Other
Other
Other
i7-10700k
F4-4000C19D-32GTZR
Samsung 970 Pro
Corsair AX1200i
Custom Water Cooled
JMTH is offline
