MAD MAX CASE MOD - Overclock.net - An Overclocking Community
MAD MAX CASE MOD
post #1 of 44 (permalink) Old 05-16-2018, 08:25 AM - Thread Starter
Hardware Rep
Rep: 283 (Unique: 184)
MAD MAX CASE MOD
Welcome! Thanks for checking out my tribute to Mad Max & his Interceptor build log. This is one of my Bucket list theme PC builds. My mother brought me to the premiere of The Road Warrior movie and I've been fan of this world ever since. This will be a modified desktop PC with liquid cooling. Inspired by visual elements of Max's Interceptor and the Mad Max World. ...and maybe Fury Road. There shall be rust and maybe even a Detonator attached to the PC? (lol). I'll be sharing highlights of it's progression stages, including video clip links as I move along in this thread. I have a basic idea of what PC hardware components will occupy this mad max inspired PC (motherboard, CPU, DDR, GPU, SSD, PSU) The case is an Enermax Equlilence they donated to me last year. If you've followed my past personal builds, I like to find good deals on hardware whenever possible I do plan to fabricate the liquid cooling lines from 361 marine grade stainless tubing. No idea what brand of CPU & GPU water blocks, radiators and fittings I'll use yet.
The case is the Enermax Equilence I was given. It's sorta looks like a Fractal Case, but without any of the well thought out features.
I apologize in advance if you're expecting me to pose a Mad Max action figure inside the case (haha). The Interceptor's V8 feels more appropriate. The scale Ford engine I'm using is by LIBERTY Classics, http://www.libertyclassics.com/
I've added motorized shaft to spin the supercharger belt, you can watch it here, https://twitter.com/Mnpctech/status/992023385818492928
I've modified the supercharger pulleys with larger plates to keep the belt from rolling off.
I will be fabricating a new engine scoop to emulate Max's Scott Injector Scoop and painting everything dark grey.
Bill Owen is offline
post #2 of 44 (permalink) Old 05-16-2018, 08:34 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1324 (Unique: 703)
My first WC loop used a Heatercore from a '77 Pontiac Bonneville
http://martinsliquidlab.petrastech.c...re-Review.html
would fit a Mad Max theme build nicely, but it can be a bit of a PITA to mount. Mine was external.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (Blues)
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is offline
post #3 of 44 (permalink) Old 05-18-2018, 08:53 AM - Thread Starter
Hardware Rep
thats awesome!
If anyone's interested, my DIY guide on using hole saw to improve airflow in a plastic PC bezel,
I cut this opening in the Equilence bezel with a Jigsaw.
post #4 of 44 (permalink) Old 05-19-2018, 04:20 AM
=GzR=SmokeyDevil's Avatar
Rep: 13 (Unique: 13)
I'm looking forward to watching this build progress from concept to completion!
=GzR=SmokeyDevil is offline
post #5 of 44 (permalink) Old 05-23-2018, 09:57 AM - Thread Starter
Hardware Rep
Thank you for checking it out!
oh, and no RGBs will be used in this build (lol)
post #6 of 44 (permalink) Old 06-11-2018, 05:23 AM - Thread Starter
Hardware Rep
Had opportunity to get back into the workshop yesterday and make some progress on my Mad Max / Road Warrior / Fury Road tribute PC build. I've decided to locate the V8 to the top panel. I'm going to mock up a 120mm slim radiator to see how it looks in front of the V8 engine and bezel. Hmm, on 2nd thought, maybe a 80mm radiator would be better scale? I still need to fabricate the proper diamond blower for the engine. The Enermax Equilence case lacks a vertical GPU mount, so I've modified the chassis for this compact ITX/MATX vertical GPU bracket, goo.gl/XGejK1 It's mounted on aluminum diamond plate, painted matte black. Here's a photo I found of the Falcon XB from the Fury Road movie before some stages I captured of my progress.
Compact Vertical GPU Mounting Bracket for MATX & ITX cases, https://mnpctech.com/case-mods-gamin...s-cutting.html
post #7 of 44 (permalink) Old 06-12-2018, 05:10 AM - Thread Starter
Hardware Rep
That's location for the GPU with this do-it-yourself vertical mount. The final GPU will have water block.
Next stage is modifying the top rear portion of the Enermax Equilence case to hold two water reservoirs to emulate the rear fuel tanks on the falcon XB.
post #8 of 44 (permalink) Old 06-13-2018, 07:18 AM - Thread Starter
Hardware Rep
To emulate the rear fuel tanks in the Falcon XB, I'll be using EK-RES X3 150mm reservoirs. btw, these photos are stills from video I'm making of the entire build, once it finished for my YT channel, https://www.youtube.com/user/MonsterMawd
I'm wondering if I can use clips from the movie without audio in my video? no clue...
post #9 of 44 (permalink) Old 06-15-2018, 06:27 AM - Thread Starter
Hardware Rep
Do you recall the Red pull switch on Max's stick shift for his Supercharger? I thought it would be fun to somehow implement it into my Mad Max tribute build. The switch is used in commercial vehicles for controlling a two-speed axle assembly. I found it on Ebay as Cole Hersee part number 50036-BX.
post #10 of 44 (permalink) Old 06-16-2018, 01:48 AM
Rep: 0
Wow subbed!
HuguesP is offline
