[Build Log] Corsair 1000D (Case swap + dual system) i7 6800K, 1080FTW i9 9900K 2080ti - Page 2 - Overclock.net - An Overclocking Community
post #11 of 19 (permalink) Old 06-03-2018, 07:07 PM - Thread Starter
Pilz's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by MNMadman View Post
Quote: Originally Posted by Pilz View Post
With how my tower is situated I didn't want the exhaust air (which will be hotter if the rads are my intake) blowing towards me. The intakes are all cool air since inside doesn't get hot whatsoever. My temps dropped by an average Delta of 13°C under heavy loads so there's no need to change it current. Once I add my second system I'll flip the front ones to be my intake since I won't really have a choice at that point.
Corsair made some design compromises compared to other towers I've built.
-The pump mounting area is very small and forced me to stagger the two D5's
-3.5" drive bay is non-removable, but I plan on modding my case and making a smaller enclosure there
-front radiator thickness is limited to 60mm if you want a push/pull due to the drive bays
Other than these things I've been happy with the case. Once I finalize the current design I'm going to start planning how my second system is going to run. I want 4 loops if possible inside the case, 3 at a minimum. My GPU will be getting replaced within a month anyway so that will cue some other upgrades as well.
I've never been able to feel the exhaust air temp when sitting at my desk -- it's always blowing away from me. And those compromises are nothing compared to most other cases. I only use 60mm max thickness rads as I don't like the 80mm ones. The staggered mounts wouldn't bother me, as I'd most likely mount the pump-res combos to the rad fans anyway.
If I was building in this case, I'd have the front and top be cold air intakes for the rads and the rear be exhausting the warmed air. I'd be using monoblocks so there wouldn't be any consequences for having the interior being a bit warmer than it otherwise could be.
Here's a picture showing where my old tower and new one sit/sits. I can feel the heat after a while but I'll likely swap the fans orientation when I get my cables this week. The inside of my case is identical to ambient temperature so there's no issue running my setup as is. I montior thermals at 5 points in my case so I'll have to compare it when I make the change. I agree about the compromise but I'm shocked Corsair didn't make that area removable. In terms of versatility my Thermaltake was significantly better. I like the 1000D a lot becuase the panels make access a breeze plus the downsides are minimal. I'll be pushing the limits with 3 let alone 4 loops. I'm not sure I'll be able to find a Mini-ITX X99 motherboard since only 1 was made and I can't find it in stock (ASRock X99E-ITX). My set up is silent with all 21 fans at 800-1000 rpm, in fact I'll likely be able to shut off the rad fans and passively cool everything I'd I wanted for normal stuff. I think you'll like the set up once I finish it off with new cables and fix the tubing.
Edit: Added older picture of my 'office'
TT 900, Aquacomputer pumps + controller, R9 3900X, Gigabyte Aorus PCIE 4 NVMe, RTX 2080Ti, EKWB, dual 480mm rads
Pilz is offline
post #12 of 19 (permalink) Old 06-05-2018, 12:37 PM - Thread Starter
Pilz's Avatar
Rep: 1 (Unique: 1)
Talking Update 6/5/18
I got a surprise this morning in the form of my CableMod order! The new elegant cables were promptly installed, I flipped all of the fans since I moved the tower to a better location, and fixed a piece of tubing. Proper cable management will be done once I install the Aquaero later. This stage of the build is finally nearing completion. My Aquearo 6XT arrives this afternoon and will be installed alongside the Corsair LEDs tomorrow with pictures to follow. For now enjoy the pictures (some of them keep posting sideways for an unknown reason)
Pilz is offline
post #13 of 19 (permalink) Old 07-19-2018, 05:10 AM - Thread Starter
Pilz's Avatar
Rep: 1 (Unique: 1)
I added in Aquacomputer inline temp sensors, and rearranged some cables/tubing. I'll post an update this weekend when I get some time.
Pilz is offline
post #14 of 19 (permalink) Old 08-02-2018, 01:58 PM - Thread Starter
Pilz's Avatar
Rep: 1 (Unique: 1)
With the imminent launch of Nvidias next gen GPU and intels new CPUs my system is getting a complete overhaul again. I will rebuild the entire PC with a second system and swap my X99 based CPU onto a mITX board so both will fit into the case. Custom loops won't be an option from day 1 unless EKWB releases their waterblocks for Nvidias FE based cards. I have a second CPU block (EKWB Supremacy EVO in nickel) which could hopefully be used with an adapter on the second system. Stay tuned for more updates!
Pilz is offline
post #15 of 19 (permalink) Old 09-04-2018, 03:09 PM - Thread Starter
Pilz's Avatar
Rep: 1 (Unique: 1)
A little update since I forgot to post one before .
2080ti FE and EKWB full nickel/Plexi block + backplate have been ordered! I'm waiting on the i9 9900K to launch so I can add that to the list.
Name:	Screenshot_20180904-161612_Chrome Beta_1536098897779.jpg
Pilz is offline
post #16 of 19 (permalink) Old 10-08-2018, 01:26 AM
Linux Lobbyist
FeeNiXRising's Avatar
Rep: 0
I'm also considering a build in a 1000D, I have an idea for a custom front acrylic sheet, to replace the tempered glass. Can you give me any insight on its dimensions or how it is attached?
FeeNiXRising is offline
post #17 of 19 (permalink) Old 06-03-2019, 03:52 AM
Marucins's Avatar
Rep: 0
Where and how to put in this case Aquacomputer Aquaero?
Atland: Rig! (Click to show)
haMac Atland (LC) Asus Gryphon Z97 AE # Intel i7-4790K # EVGA GTX 980 Ti SC # G.Skill TridentX DDR3 2400MHz CL10 (4x4GB) # Samsung 850 PRO 512GB + Crucial M550 256GB + WD VelociRaptor 1TB # AirPort Extreme (BCM94360CD) # SeaSonic Platinum-1200 XP3 # Phanteks Enthoo Primo
LC: Aquacomputer (D5 + Aquaero 6 PRO + heat sink + flow sensor + temp. sensor) # Koolance (PMP-450 TOP + Reservoir 462ml + CPU-380I + 16/10mm) # EKWB (EK-FC Titan X - Acetal-Nickel + Backplate-Black) # Alphacool 480 (60 & 80) P&P # NF-F12 PWM x16 # PrimoChill PrimoFlex Advanced LRT # Mayhems X1 Oil Black
ADD: Dell UltraSharp U3011 # Logitech Performance MX # Logitech diNovo Edge # intuos3-A5 # Synology DS713+ 2xWD30EFRX # WD My Book Studio II 4TB (Scratch) # Logitech Z5500
Owner Clubs (Click to show)
Marucins is offline
post #18 of 19 (permalink) Old 06-03-2019, 04:19 AM
deanorthk's Avatar
Rep: 0
Very nice build so far!
Got my 1000D two weeks ago, and I do love it a lot.
Asus RIVBE/I7 4960K (passive video card) and Asrock Z170 fatality/I7 6700K/1080ti.
I have swaped the radiator support plate, so I got the two 360 EX radiator on the top, and 3 x 120mm fans blowing "cold" air on the front.
Since I live in a tropical island, I had to do it this way.
Only downside so far, the commander pro is really.. erhm..2 fan port are not working at all well I wish I could install my aquaero 6 instead, but I in the end I think I will drop it inside, it far more robust.
deanorthk is offline
post #19 of 19 (permalink) Old 07-13-2019, 11:09 PM
Marucins's Avatar
Rep: 0
can you put photos, how and where you installed aquaero?
Marucins is offline
