[Build Log] Project AD - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 09-17-2018, 11:31 AM - Thread Starter
Black&Red Fanboy
Midknite's Avatar
Rep: 0
Hey everyone. Been lurking for quite awhile but figured I should start logging this since it's starting to get serious. A lot of the hardware is going to be outdated because I started collecting parts back in 2013 so some of it is carry over from an existing build (Graphics cards) but for the most part it's all brand new parts just from the previous generations. I should also probably note that this build is going to take awhile to finish.
I also wanted to try my hand at cable sleeving. Every time I try to look for pre-sleeved cables I either find just extensions which doesn't look as clean, can't find the right lengths or the cables have heat shrink. I'd like to have all shrinkless cables.
Since this is going to be my first watercooling build I'm going to start out with soft tubing and then upgrade to Hard line at a later date.
I'm just going to start with the list and go from there.
Acquired
Case: Corsair 900d
CPU: Intel Core i7-6950X
Motherboard: EVGA X99 FTW K
Power Supply: Corsair AX1600i
GPU 1: EVGA GTX TITAN SC (06G-P4-2793-KR)
GPU 2: EVGA GTX TITAN SC (06G-P4-2793-KR)
GPU 3: EVGA GTX TITAN SC (06G-P4-2793-KR)
Memory: 32GB Corsair Dominator Platinum (Red Top Edition) (8x4gb)
Fans: 4 x Corsair ML120 PRO LED Red
Fan Parts: 23 x Corsair ML PRO Corner Caps (Black)
Radiator 1: XSPC AX240 (Black)
GPU Waterblock: 3 x XSPC Razor GTX 7XX/Titan Series
CPU Waterblock: XSPC Raystorm
OS: Windows 7 Ultimate
Fittings: 1 x Monsoon Free Center Compression Fittings, 3/8" x 5/8" Six Pack - Matte Black
Storage: SAMSUNG 970 PRO M.2 1TB
Cooler: Corsair H80i V2 (For boot test)
Need to purchase
Fan: 1 x Corsair ML140 PRO LED Red
Fans: 18 x Corsair ML120 PRO LED Red
Radiator 2: XSPC AX480 (Black)
Radiator 3: XSPC AX480 (Black)
Coolant: XSPC EC6 Blood Red
Fan Control: 2 x Corsair Commander Pro
CPU cooling: Corsair H100i V2 (for boot test)
Monitor 1: ASUS ROG Swift PG258Q
Monitor 2: ASUS ROG Swift PG258Q
Monitor 3: ASUS ROG Swift PG258Q
Tubing: PrimoFlex Advanced LRT 10ft Tubing - 3/8in. ID X 5/8in. OD - Bloodshed Red
Reservoir Mount: 2 x Singularity Computers Ethereal Dual V3 - Black
Fittings: 2 x Monsoon Free Center Compression Fittings, 3/8" x 5/8" Six Pack - Matte Black
Reservoir Tube: 2 x Singularity Computers Protium – Large 250mm - Black Acetyl
Pump Top: 2 x Singularity Computers Protium D5 Pump Top - Acetal
Pump Cover: 2 x Singularity Computers Protium D5 Pump Cover - Black
Pump: 2 x XSPC D5 Vario SATA Pump
Completed Tasks
-Boot Test
Tasks to complete
-Change fan corner caps
-Sleeve fan cables
-Sleeve power supply cables
-Mount GPU waterblocks
-Test fit pump+reservoir x 2
-Radiator and fan test fit
-Out-of-case test with Corsair Commander Pro x 2
-LED wire routing for CPU and GPU waterblocks
-Cable management
-Loop test
Next items being purchased:
Note: List will be edited as stuff is acquired or changed
Midknite is offline
post #2 of 3 (permalink) Old 07-31-2019, 06:45 PM - Thread Starter
Black&Red Fanboy
Midknite's Avatar
Rep: 0
Time to boot and make sure everything is working. Fingers crossed!
Midknite is offline
post #3 of 3 (permalink) Old 08-02-2019, 01:27 PM - Thread Starter
Black&Red Fanboy
Midknite's Avatar
Rep: 0
Booted successfully with no hardware issues. Also got Windows 7 ultimate installed and some drivers. Man getting Windows installed directly to the Samsung M.2 was a royal PITA. Since Samsung only offers an installation file I had to find a developer kit for extracting the INF files I needed to copy to the thumb drive so that I could load it during the install. Well worth it in my opinion. Tonight I'll be finishing driver installation and Windows activation. Also tested the LEDs in the CPU block to see how it would look. I won't be posting any more pictures or doing any more work until the DSLR arrives.
Midknite is offline
