Converting a battery powered LED strip to a cord - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 10-30-2018, 01:48 PM - Thread Starter
TheGreyWizard's Avatar
Rep: 1 (Unique: 1)
A bit off topic of computers, but I figure you guys here have the knowledge & skills for what I'm trying to do anyways.
So I have an LED strip that is currently powered by a battery pack & I would like to convert it so that it has a cord & I can plug it in 24/7.
I'm not sure of the exact type of LEDs, they are just a wire with tiny baby drop LEDs on them and it is just wired to a small battery & controller (on/off/strobe)
So what type of inverter would I want/need to add a wire & plug to these type of LEDs?
Also, can anyone tell me why the end piece is discoloring like it is and if it's safe?
The reason only the end piece itself is affected is because I am only using that section of the LED strip in a glass art display.
Thanks.
TheGreyWizard is offline
post #2 of 15 (permalink) Old 11-05-2018, 05:02 PM - Thread Starter
Rep: 1 (Unique: 1)
anyone?
post #3 of 15 (permalink) Old 11-05-2018, 05:14 PM
essanbee's Avatar
Rep: 101 (Unique: 82)
You will have to find out the exact specifications of the voltage and amperage provided by the 3 batteries and converted by the electronics in the circuit board. Then you will have to find out if there exists any converter box to run off of the PSU. I would just buy an LED strip to replace it that will run off of your PC's power.
Big Blue
(14 items)
Intel Core i5 2500K
P8P67 DELUXE
EVGA GTX 980 FTW
G.Skill
Western Digital WD1002FAEX-00Z3A0
Optical Drive
ASUS DRW-24B1ST
THERMALTAKE TOUGHPOWER XT 775W
SWIFTECH H20-320 EDGE HD APOGEE HD WATER BLOCK
APEVIA X JUPITER S TYPE METALLIC BLUE
Operating System
WIN7 64bit
ASUS VE258Q
Mouse
RAZER DEATHADDER 3500dpi
Audio
Creative Soundblaster Z
Other
SSD Samsung 840 EVO 250 GB for OS
essanbee is offline
post #4 of 15 (permalink) Old 11-14-2018, 10:12 PM - Thread Starter
Rep: 1 (Unique: 1)
Hmm I should just be able to use a voltage meter on the battery box with new batteries to see what the output is?
This isn't on my computer, it's a separate non-computer light, but I figured the community here has the knowledge to help me out.
The key to this piece of dichroic art piece is the LED strip is basically invisible because it's just a thin wire with some drops of LED goo every few inches, so it works perfect for this application.
Any idea what these kind of LEDs are called so I can try to find a set with a converter box & plug?
post #5 of 15 (permalink) Old 11-14-2018, 10:21 PM
High Clocker
bmgjet's Avatar
Rep: 186 (Unique: 160)
3X AA batery is going to be 4.5V when fully charged and drop down to 3.6V when getting low.
Then the circuit is just going to be a current limiting resistor and switch most likely.
Most simple way would be keep the circuit there and wire it to some old wall adapter you have from like a old router.
Check the sticker on the wall adapter to make sure its some where between 3.6 and 4.5v other wise youll need to use something like a zenner dieode in line to drop voltage from a 5V one which would drop it to about 4.3v.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #6 of 15 (permalink) Old 11-18-2018, 09:15 PM - Thread Starter
Rep: 1 (Unique: 1)
Ok great I'll try out the router plug and report on how it works.
Thanks!
post #7 of 15 (permalink) Old 12-05-2018, 03:33 PM - Thread Starter
Rep: 1 (Unique: 1)
Well I found 2 small wall plugs with USBs on them, I think they were from bluetooths.
One is an
LG Travel Charger: 5.1V - 0.7A
Then I have a Jabra: 5-6V Max 3W (5V - 0.5A)
These are both pretty small power plugs and the only 2 I had in general.
So I can't use either one as is? I need to add zenner diodes connecting the 2 wires? Are there any plug ports that give you a cleaner finished product instead of twisting the wires together. Or do I want to solder? (which I don't have one but could probably locate someone who does)
post #8 of 15 (permalink) Old 12-05-2018, 03:57 PM
*cough* Stock *cough*
Nukemaster's Avatar
Rep: 129 (Unique: 101)
Fully changed AA batteries can be about 1.6 volts. chances are 5v would not harm the leds(unless they are running the leds to the max).
I recommend a USB power supply with as many 4001-4007 diodes(normal cheap rectifiers) in series as required to drop to a voltage your are comfortable with.
A 4001 diode will generally drop 0.7 volts. so a single diode should bring a 5v supply down under 4.5. The voltage drop will depend on the current being drawn as well.
I used a single diode to drop 5 volts for a flashlight that had a "4.1" volt lead acid(it was over 4.5 at full charge).
EDIT.
I can draw what you need to do if you wish.
Gaming
(15 items)
Media Center
(17 items)
2600K @ 4.4
Maximus IV Gene-z
Asus Dual 1070 OC with Artic Mono Plus
G.SKILL F3-1866C9D-16GXM Ripjaws X 16GB
M4 256
MX 300
Optical Drive
Liteon Slot load
Corsair 850HX
H80i
Silverstone FT03
Operating System
Windows 7 HP 64 bit
BenQ XL2420Z
Keyboard
Logitech G810 Orion
Mouse
Logitech G502
Audio
X-fi Titanium Fatality
i5 750
h55n usb3
msi gtx 650 ti
Corsair XMS3 CMX8GX3M2A1600C9
WDC Red 3tb
M4 128
WDC scorpio Blue 2.5
Optical Drive
Sony AD-7690H-01
FSP SFX 300 watt
Geminii S
SG05
Operating System
Windows 7 HP 64 bit
SyncMaster 245t
Keyboard
Logitech Wave
Mouse
Logitech G9
Audio
Sound Blaster Omni
Other
HD PVR
Nukemaster is offline
post #9 of 15 (permalink) Old 12-06-2018, 12:49 AM - Thread Starter
Rep: 1 (Unique: 1)
Yes can you please draw me a schematic? This is out of my wheel house as I usually don't tinker like this, but can follow directions good lol
Thanks!
post #10 of 15 (permalink) Old 12-06-2018, 06:40 AM
Nukemaster's Avatar
I made a quick paint drawing of how it would be connected.
The IN4001 diodes drop about 0.7, but it will drop more as the power draw increases(and a bit less if the load is very low). I would guess only 1 diode would be required for this application, but if you start with 2, you can test the voltage and see what you get.
This is only 1 of many ways you can do this. As mentioned above you could use a zener diode regulator(2 components) or even a linear or switching regulator(regulators have the advantage of allowing a wide range of input voltages.), but for this project, I do not think it is required. If you knew the power consumption of your lights, you could have used a single resistor to "eat" the extra voltage.
Moving on.
You have 2 power supplies. 1 that is 5-6 volts @ 500ma. This power supply does not appear regulated and will most likely deliver closer to 6 volts under the light load of your leds. The LG power supply lists 5.1 and seems to be regulated. I think I would use the LG power supply.
To get power out of these units you will either have to cut the plug off or get a matching plug. Do not cut the plug off if you still need to use those power supplies.
In my illustration, you would connect to the existing battery compartment. This leaves the strobe mode and on and off switch functional. Connect negative to the far left top battery connector and positive to the lower right connector.
Once connected, before powering up(power supply plugged in and led's turned off), check the voltage with a meter set to DC(check at the newly connected battery terminals). Turn it on and check again. A small drop is to be expected as the leds will draw power once switched on. As long as you are under 4.5 volts, you are good to go. If the voltage is lower, you may notice dimmer light from the leds. This should not hurt the device or else dead batteries would hurt it.
If you have questions. just ask. I will try to make a demonstration picture a bit later today.
EDIT.
Here is a practical setup for testing. I have about 200ma of leds when run from 4.5 volts. The blue one is because I had no white with long leads left.
I placed the 2 IN4001 diodes in series with the + side. This causes about 1.54 volts to be dropped leaving about 3.46 volts. LEDS are dimmer, but light and will last forever.
With a single diode the voltage drop was about 0.8v leaving about 4.2 volts. leds are slightly dimmer, but with batteries the voltage had to drop overtime anyway.
I hope this gives you an idea of what I was talking about. You can also get USB or other plugs that can be mounted on the light. This would give a clean finished look to the project. I also would not use diodes to drop lots of voltage. if you had 12 volts, a switching regulator would be best(much less heat than a linear regulator).
EDIT first image has been re-added. I just fluke noticed it does not work on some mobile devices.
Gaming
(15 items)
Media Center
(17 items)
2600K @ 4.4
Maximus IV Gene-z
M4 256
MX 300
Optical Drive
Liteon Slot load
Corsair 850HX
H80i
Silverstone FT03
Operating System
Windows 7 HP 64 bit
BenQ XL2420Z
Keyboard
Logitech G810 Orion
Mouse
Logitech G502
Audio
i5 750
h55n usb3
msi gtx 650 ti
WDC Red 3tb
M4 128
Optical Drive
Sony AD-7690H-01
FSP SFX 300 watt
Geminii S
SG05
Operating System
Windows 7 HP 64 bit
SyncMaster 245t
Keyboard
Logitech Wave
Mouse
Logitech G9
Audio
Sound Blaster Omni
Other
HD PVR
Last edited by Nukemaster; 12-07-2018 at 10:35 AM. Reason: Added information and fixed spelling errors.
