[Build log] Devotion: a Hardcore Shift X - watercooled, oc'd to the limit, RGBW custom cables. - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 03-05-2019, 09:08 AM - Thread Starter
Enter Plasma
SHNS0's Avatar
Rep: 58 (Unique: 50)
A huge ITX system that is all about beauty and raw power.
Supported by Watercool
Made with <3 by Enter Plasma
Main Features:
9900K & RTX 2080 with heavy OC in a Shift X
Custom, high end, high performance Watercooling
Custom RGBW Cables in MDPC-X Sleeve
Custom Illumination
"Fixing" the Phanteks Shift X and pushing its limits with sheer brute force
A lot of other fancy small details worth checking out
Hardware List:
CPU: Intel Core i9 9900K
GPU KFA2 RTX 2080 OC
Motherboard: Asrock Z370 ITX Fatal1ty
Ram: Corsair Dominator Platinum DDR4 16GB 3000
SSD: Samsung 970 EVO 1TB
PSU: Corsair SF750
Case: Phanteks Shift X
RGB Controller: Raspberry Pi Zero WH
Cooling / Accessories:
CPU: Watercool Heatkiller IV Pro Acetal Ni
GPU: Watercool Heatkiller IV RTX 2080 Acetal Ni
Reservoir: Watercool Heatkiller Tube 100 DDC
Pump: EK DDC 3.2 PWM
Rads: Hardware Labs Nemesis GTS 240 + 120
Fittings: Barrow Black
Tubing: Barrow PETG 14/10
5x Delta AFB1212SH Fans
EVGA Powerlink
PCI-E 3.0 Riser for Phanteks Shift X
Aluminium M.2 Heatsink
Custom Stuff:
Stainless Steel Screws + Alu Washers
RGBW Sleeved Cables with MDPC-X Carbon BTI & Transparency
RGBW Light Bars, other illumination in White
Twister Mod Stickers (Fans)
Custom Motherboard IO Plate
A big shoutout for the help, support and/or inspiration to:
Jacob (Watercool Heatkiller)
Daniel (Twister Mod / Twister7800GTX)
Nils (MDPC-X / Million Dollar PC)
All the customers of Enter Plasma that supported me over the past 3+ years
First Pics:
Devotion
(12 items)
Intel i9 9900k
Asrock Z370 Fatal1ty ITX
KFA2 RTX 2080 OC
Samsung 970 EVO 1TB
Corsair SF750
Custom Watercooling
Phanteks Shift X
Operating System
Windows 10 Pro
Alienware AW3418DW 34"
Keyboard
Logitech G513
Mouse
Logitech G Pro Wireless
SHNS0 is offline
post #2 of 4 (permalink) Old 03-15-2019, 12:30 PM - Thread Starter
Enter Plasma
SHNS0's Avatar
Update #1 - Work starts
UPDATE #1: Finally received the last hardware, work is getting done
Started doing the first tests with RGBW cables, using MDPC-X Transparency sleeve and MDPC-X transparent AWG15 wire.
The controller is a random addressable chinese one that can be controlled with an app. It's not bad, but it's a bit buggy. Not an ideal solution, but I'll keep it for now.
The LED strips for the cables, on the other hand, are glorious. These are addressable RGBW, 144 LEDS / meter. They're beautiful, and also inhumanely expensive lol.
Got the latest shipment from China that was delayed for more than a week unfortunately.
A lot of fancy stuff, but turns out I need more screws. Some of the sizes were incorrect.
Fancy stainless steel screws. I absolutely love these, specially together with the aluminium washers.
Also got a new clear IEC connector to re-make the stock PSU extension for the case. It lights up really well
Some other stuff that arrived recently: SSD, hardline watercooling gear, cable and sleeving material from MDPC-X, and some aluminium bars for LED strips that I'm still not sure about using for this project.
And the replacement riser I'll be using. Unfortunately the original Phanteks riser doesn't seem to be PCI-E 3.0 capable.
NEXT: A lot of cables
Devotion
(12 items)
Intel i9 9900k
KFA2 RTX 2080 OC
Samsung 970 EVO 1TB
Corsair SF750
Custom Watercooling
Phanteks Shift X
Operating System
Windows 10 Pro
Keyboard
Logitech G513
Mouse
SHNS0 is offline
post #3 of 4 (permalink) Old 06-01-2019, 06:49 AM - Thread Starter
Enter Plasma
SHNS0's Avatar
UPDATE #2: Fan cables & LED's in the works
Work has been slow but steady.
I'm currently doing all the splitter cables for fans, LED's and the sorts. They still have to be sleeved of course!
It is a massive work but it's very important - using as less space as possible for cables is top priority for maximizing airflow.
Here's where some of the addressable LED's will go, these will light up the cables from the bottom.
And this is a rough idea of how they'll turn out.
These are not the cables for the project, but I'm thinking about going with this same color scheme (Carbon BTI + Transparency)
This is a rough idea of how the back will be cable managed.
I also had this chinese RGB controller that I though of using, but it was HUGE
So I pried it open...
... And burned the Bluetooth controller trying to desolder those green cable clamps, LOL.
WELL, I guess I'll take the opportunity to do something I've been wanting to try for a while. Using a Raspberry!
It will arrive around next week so we'll see about that.
I also ended up upgrading to a Corsair SF750 Platinum
And I was able to fit another fan on the bottom, for a 120 push/pull. Can't have enough fans in here.
Another issue is these fan screws that have to be trimmed. I'm using M4's and they either come in sizes 30mm or 35mm.
30mm is too short and won't screw in the rad. 35mm is too long and will hit on the fins before screwing in all the way.
These are stainless steel, it's not easy to cut. I'm gonna have to figure out some way.
In the pic you can also see some black aluminium columns that I got to cover up the screw thread. I think it looks really cool!
And finally, this is how I'm ending up with the fan configuration. It's all negative pressure, and the air will be sucked in from the whole of the back.
NEXT: Finished secondary cables, installing the hardware and doing the main cables!
Current Projects:
Devotion: a Hardcore Shift X.
Blood Inside: a Luxury, Budget Meshify Mini.
"Quality means doing it right when nobody is watching."
Devotion
(12 items)
Intel i9 9900k
KFA2 RTX 2080 OC
Samsung 970 EVO 1TB
Corsair SF750
Custom Watercooling
Phanteks Shift X
Operating System
Windows 10 Pro
Keyboard
Logitech G513
Mouse
SHNS0 is offline
post #4 of 4 (permalink) Old 06-03-2019, 11:59 AM
Force User
Jsunn's Avatar
Rep: 27 (Unique: 24)
Jsunn is offline
Tags
9900k , itx , rtx , Watercooling
