Dumpster case to (hopefully) classy wooden case - Overclock.net - An Overclocking Community
post #1 of 19 (permalink) Old 03-29-2019, 08:13 AM - Thread Starter
Navyblue's Avatar
Rep: 4 (Unique: 3)
Warning: Knowing myself, a project like this would take me months to complete, that’s if I’m lucky.
A few years ago, i picked up a Cooler Master case by a dumpster. It was originally black, scuffed up, and the acrylic window was hazy. I don’t have a picture of it though.
I spray painted it and replaced the acrylic window with gutter mesh.
After I did all that I ended up not using it because it’s a little cramp near the top which results in a less than ideal airflow.
Lately I’ve been trying to place a PC inside a TV console. Most PC cases are too deep for this. There are low profile cases but they all come with crushing limitations, chief of them is there is no way to fit a full size ATX with big chunky cooler. I’d also rather use what I have then go buy a whole new set up just for this. So it looks like I need a custom made case.
I have an idea of making a PC case from wood, but thought modifying a commercial case is a better idea. The motherboard and video card mountings and openings of a commercial case would beat anything I can possibly hack together.
Leading the lamb to slaughter.
First cut.
Where the second cut is to be.
The excess part is off.
Moving onto the panels.
The frame that I will be using.
I was hoping to simply use the windowed panel, but the left over on the edges are too thin and the jigsaw kinda crumpled it.
The head and the tail.
The white spray paint comes off relatively easily, and you can see the original black powder coating underneath it.
That’s all for today, I will have to think about the wood panelling, it’s not easy finding real wood here. Hopefully I will come back to this soon.
Navyblue is offline
post #2 of 19 (permalink) Old 03-29-2019, 10:42 AM
BSME
dirty elf's Avatar
Rep: 8 (Unique: 8)
interested to see what you come up with, have always wanted to do something similar
///M
First Build
(15 items)
10 Year Upgrade
(9 items)
Intel Core i7-870 Lynnfield
Asus P7P55D-E Pro
MSI RADEON RX480 8GB
G.Skill Ripjaws 2 x 8GB
Crucial MX 300
Western Digital Caviar Black SATA 6gb/s 7200rpm Drive
Optical Drive
LG Blu-Ray Drive
Corsair 650TX 650 Watt
Cooler Master Hyper 212 Evo
Antec Three Hundred
Operating System
Windows 7 64-bit Home
Dell U2417H
Dell U2417H
Keyboard
Apple USB Keyboard
Mouse
Logitech M510
Ryzen 9 3900x
MSI B450 Tomahawk Max
RX480
Crucial Ballistix Sport LT
Samsung 970 Evo Plus
Seasonic PRIME Ultra Titanium
Be Quiet Dark Rock Pro 4
NZXT 500
Operating System
Windows 10
dirty elf is offline
post #3 of 19 (permalink) Old 03-30-2019, 01:11 PM - Thread Starter
Navyblue's Avatar
Rep: 4 (Unique: 3)
Thanks!
Temper your expectations though. I am far from experienced with wood, and I live in an apartment, both limits what I can ultimately do.
Back to squeezing my brain to come out with a fan installation method that allows easy filter cleaning and yet completely hidden at the same time.
Navyblue is offline
post #4 of 19 (permalink) Old 04-11-2019, 04:15 AM - Thread Starter
Navyblue's Avatar
Rep: 4 (Unique: 3)
I finally gotten the wood. I didn’t want to deal with veneer, so I got myself some solid wood.
But I think I should have gone plywood and veneer instead. These wood weren’t dried, and who knows how long it will take to dry. They smell like countryside, which is my polite way of saying manure like, or perhaps it is manure that smells like plant?
My only consolation is I live in a humid environment, so the moisture equilibrium point is probably quite high as well.
I think I will put these in a large zip lock bag along with a tub of desiccant, this should significantly accelerate drying.
Navyblue is offline
post #5 of 19 (permalink) Old 04-11-2019, 05:03 AM
I dunno what I'm doing.
Blze001's Avatar
Rep: 64 (Unique: 46)
I assume you're gonna have a gap between the wood and the case frame so the fans can breathe? If so, you could get magnetic covers. Just slide them over the fans on the outside between the wood and the frame, they'll be hidden by the front slab unless you look at a specific angle: and if the case is black, the black filter won't really be noticeable until it's coated with dust.
It is what it is.
ATX PowerMac
(14 items)
i7-8700k
ASRock Taichi Z390
GTX-1080Ti
G.Skill Ripjaws V
Samsung 970 Pro
Adata XPG SX8200
SanDisk Ultra II
Seagate 7200RPM
Corsair RM650x
Apple PowerMac G5
Dell Alienware AW3418DW
Keyboard
Glorious GMMK TKL
Mouse
Glorious Model O
Audio
Creative X7
Blze001 is offline
post #6 of 19 (permalink) Old 04-11-2019, 06:36 AM - Thread Starter
Navyblue's Avatar
Rep: 4 (Unique: 3)
From the look of it, the fans will be in front, like you said with a gap behind the front panel.
The air inlet would be at the bottom part of the front panel, so the fans and filters are only visible from a very steep angle from the bottom. When placed on a desk it would not be possible to see the fans. I also intend for the front panel to be held by magnetic catch so that it is removable.
Navyblue is offline
post #7 of 19 (permalink) Old 04-11-2019, 01:57 PM
BSME
dirty elf's Avatar
Rep: 8 (Unique: 8)
wood mostly expands across the grain. if you take that into account and use slots for your fasteners or joints you can leave it room to expand with the seasons
Sent from my iPhone using Tapatalk
///M
First Build
(15 items)
10 Year Upgrade
(9 items)
Asus P7P55D-E Pro
Crucial MX 300
Optical Drive
LG Blu-Ray Drive
Antec Three Hundred
Operating System
Dell U2417H
Dell U2417H
Keyboard
Apple USB Keyboard
Mouse
Logitech M510
Ryzen 9 3900x
RX480
NZXT 500
Operating System
Windows 10
post #8 of 19 (permalink) Old 04-11-2019, 05:22 PM - Thread Starter
Navyblue's Avatar
Rep: 4 (Unique: 3)
I am in the tropic, so fortunately I am spared of such intricacies.
Just as those were delivered to me yesterday, I found these while walking around.
These were paulownia, not as nice as the other batch (elm). But looks ready for immediate use.
This is apartment style wood curing, I will put those behind the air conditioner. There is a tub of desiccant in the bag. Of course I have no idea if this is going to work. So I guess I’m going to use the other batch.
Navyblue is offline
post #9 of 19 (permalink) Old 05-16-2019, 09:27 AM - Thread Starter
Navyblue's Avatar
Rep: 4 (Unique: 3)
I messed up the wood drying. I thought the tub of desiccant was silica gel, so I put it side way. It turns out it is salt, and putting it side way would make it spill salt water into the wood.
But even then, it collected half a mug worth of brown water. I’m not sure why the water was brown. It also smelled sweet, not like maple syrup, but sweet like syrup.
One of the side piece is now soaked in salt and unusable.
Not a big deal though, because I kind of changed my plan. I thought an all wood look might look a tad too old fashioned for my taste. So I’m going for a 2 toned look. I happen to have some gloss black high pressure laminate. I think it would make a good contrast with wood.
I have some left over plywood, I will be using them to make the outer frame. They weren’t screwed in, I merely placed the components in the respective places so I can picture them better.
The bottom of the case has some protrusions, I have to route out some of the wood so that the left panel would rest flat. As you can see I just freehanded it, I have little inclination for finesse under the hood.
Front panel drilled and covered in laminate.
The back side of the front panel, again little finesse in there. Personally I am a fan of wedging fans by friction instead of screwing them.
The sides were screwed in and then covered in laminate.
The outer frame screwed in. Now it is borderline usable, the rest are mostly cosmetics.
I have no idea how to mount the disk drives yet, I’ll worry about that when I get there.
After this will be the top and the front cover. They will be covered I solid wood. I have the option of using the prettier but wet elm or the paulownia.
Navyblue is offline
post #10 of 19 (permalink) Old 05-16-2019, 11:25 AM
Senioritis Member
Lady Fitzgerald's Avatar
Rep: 531 (Unique: 333)
...I have no idea how to mount the disk drives yet, I’ll worry about that when I get there...
Just do a search for HDD cages and swap bays and you can find any number you can easily adapt to fit inside your case to hold however many HDDs you need (consider getting one with with more bays than you actually need right now for future expansion). Many are quite inexpensive.
Jeannie
i7-3930k
ASUS P9X79 WS
MSI R7850 Twin Frozr 2GD5/OC Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Monoprice 1x2 powered HDMI Splitter
Kingston HyperX 32GB (8 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K8/32GX
128GB Samsung 840 Pro SSD
4TB Samsung 850 EVO SSD
Optical Drive
LG 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive CH12LS28
Corsair HX750W
COOLER MASTER GeminII S524 120mm Long Life Sleeve CPU Cooler
Antec Two Hundred v2
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Logitech M525 with Unifying Receiving
Audio
Corsair SP2500 2.1 Speakers
Audio
ASUS Xonar Essence STX Virtual 7.1 Channels 24-bit 192KHz PCI Express x1 Interface 124 dB SNR / Headphone AMP Card
Other
LSI 9211-8i HBA card
Other
HooToo® HT-CR001 3.5" PCI-E to USB 3.0 Multi-in-One Front Panel Internal Card Reader (6 Memory Slots, Genesys GL3220 Chipset) & SuperSpeed USB 3.0 3-Port Hub (VIA VL800 Chipset), can read & write: M2/MS Micro, High-Speed CF(UDMA), UHS-I, SD, SDHC,...
Other
StarTech HSB220SAT25B 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane
i7-5930K Haswell-e
Asus X99-E WS/USB 3.1
Visiontek Radeon 7870 2GB with 6 miniDisplayports
G-Skill Ripjaws 64GB (8x8GB) DDR4 2133
Samsung 850 EVO 4TB SSDs
Samsung 950 Pro 512GB m.2 SSD boot drive
Corsair AX760
Noctua NH-D15S Cpu cooler
Scratch built. Currently under construction at https://www.overclock.net/t/1602023/preparing-for-a-scratch-built-case
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
El Cheapo Allsop hard plastic
Lady Fitzgerald is offline
