Newbie Water Cooling Build Parts - Overclock.net - An Overclocking Community
post #1 of 1 (permalink) Old 04-18-2019, 12:57 AM - Thread Starter
Rep: 0
Hi, Guys,
So my friends have listed these items and I have bought them all just waiting for delivery unfortunately, he wont be able to build this together since he already work offshore, and is hard to contact him while he is the Barge ship and wont be back for the next 3 months.
So these parts are ready to build and in terms of base material are all safe ? (copper base and not aluminium, does nickel also copper?)
The case I'm using is Lian Li PC-011 Dynamic White, Processor is AMD ryzen 2600x, Motherboard is MSI X470 Gaming Pro, and the watercooling only for CPU not yet for GPU, does all the fittings required are all enough?
this build is for my learning curve to watercooling.
Appreciated any reply, Thanks
Radiators
Alphacool NexXxoS ST30 Full Copper 360mm radiator V.2
https://www.alphacool.com/shop/radia...or-v.2?c=20545
Fittings
12X - Alphacool Eiszapfen 13mm HardTube compression fitting G1/4 - knurled - deep black sixpack
https://www.alphacool.com/shop/fitti...-black-sixpack
4X - Alphacool Eiszapfen 13mm HardTube compression fitting 90° rotatable G1/4 - knurled - deep black
https://www.alphacool.com/shop/fitti...-black?c=20667
6X - Alphacool Eiszapfen 13mm HardTube union nut modding pack 6 - deep black
https://www.alphacool.com/shop/new-p...-black?c=20667
4X - Alphacool Eiszapfen 13mm HardTube compression fitting 45° L-connector - knurled - chrome
https://www.alphacool.com/shop/new-p...chrome?c=20667
4X - Alphacool Eiszapfen 13mm HardTube compression fitting 45° rotatable G1/4 - knurled - deep black
1X - CPU Block
EK-Velocity - AMD Nickel + Acetal
https://www.ekwb.com/shop/ek-velocity-amd-nickel-acetal
1X - EK-ATX Bridging Plug (24 pin)
https://www.ekwb.com/shop/ek-atx-bridging-plug-24-pin
2X - EK-Cable Y-Splitter 3-Fan PWM (10cm)
https://www.ekwb.com/shop/ek-cable-y...3-fan-pwm-10cm
1X - Alphacool Eisrohr 13/10mm PETG HardTube 80cm - 4pcs
https://www.alphacool.com/shop/hardt...m-4pcs?c=20967
kinzano is offline
