HAF 912 Plus MOD: max airflow - Overclock.net - An Overclocking Community
post #1 of 19 (permalink) Old 05-05-2019, 12:40 PM - Thread Starter
From Italy
Rep: 0
Hi all,
I'd like to do some modding to my case (an old Cooler Master HAF 912 Plus from 2011). This is the hardware inside:
- i7 2600k 4.5GHz + Noctua NH-D15
- Asus P8P67 + 2x4GB ram Vengeance
- GTX 1060 6GB Zotac AMP
- Corsair AX750
- One SDD, two HDD
Fan configuration:
- Front: 200mm, 700RPM, 19dBA red led (CM MegaFlow) - INTAKE
- Side: 140mm, 900~1300RPM, 17~21dBA no led (Thermalright TY-140) - INTAKE (same high as VGA)
- Rear: 120mm, 1200 RPM, 17 dBA no led - EXHAUST
- Top: 200mm, 700RPM, 19dBA red led (CM MegaFlow) - EXHAUST
I don't like LEDs nor case windows.
What I did:
- Added front fan 140mm Noctua NF P14r 450-1500RPM, 25dbA, no led - INTAKE
What I want TO DO:
- Add bottom INTAKE 140mm fan (same Noctua as above);
- Have some USB3 in the front of the case;
- Add a fan speed controller;
Here are some pictures. What do you suggest me to do to improve this case? Thank you
lpdevIT is offline
post #2 of 19 (permalink) Old 05-05-2019, 01:28 PM
rdr09's Avatar
Rep: 849 (Unique: 621)
We have the same case. I reversed the air flow from rear to front on mine. My R9 290 is watercooled using one 120mm radiator located where it says 2X for push/pull. Fresh air is channeled through the motherboard. I'm only using a single fan on my Noctua U12S. I included a SS of my gaming temp. Ambient is about 24-25c. I leave my R7 2700 stock though. The Noctua fan is slow. Maxes out at 800 rpm.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #3 of 19 (permalink) Old 05-05-2019, 01:54 PM - Thread Starter
From Italy
Rep: 0
Thank you for your answer! So do you suggest me to revert all the airflow? What are the benefits? I'm quite sure the air from the bottom of the case is quite dirty and hot. I don't have any watercooling in it (and don't want to).
lpdevIT is offline
post #4 of 19 (permalink) Old 05-05-2019, 01:56 PM
8051's Avatar
Rep: 21 (Unique: 15)
Is there any intake in the floor of this case?
8051 is offline
post #5 of 19 (permalink) Old 05-05-2019, 02:00 PM
rdr09's Avatar
You can lv your current fan set up. I have an i7 2700K @ 4.5GHz and it really does not heat too much, especially if you have a beefy cooler like what you have. My GTX 1060 does get hot at load (83c) but it does not heat up the inside of the case either. So, unless you are having heat issues, i recommend just leaving it the way it is. My intel setup is set to shut down at 80c and it never does shutdown.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #6 of 19 (permalink) Old 05-05-2019, 02:16 PM - Thread Starter
From Italy
Rep: 0
Nothing at the floor of this case, I just want to drill the holes to make one
Ok thank you. What else do you suggest me to do to improve this case?
lpdevIT is offline
post #7 of 19 (permalink) Old 05-05-2019, 02:26 PM
rdr09's Avatar
There is really nothing much you do with this case without ruining it. You can force a 140 mm Fan up top like i did. I was gonna suggest removing the PCIe Bracket covers but yours are grilled, so those are fine. I did remove the dust covers cos it isn't really dusty where i lv. I think they do decrease air flow, especially when dirty.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #8 of 19 (permalink) Old 05-06-2019, 01:29 AM - Thread Starter
From Italy
Rep: 0
You mean adding another 140mm in the top? I think it's not easy to do and it won't have any benefits.
Yeah PICe Brackets are grilled.
Bottom dust covers are useful for my build because there's a lot of dust
lpdevIT is offline
post #9 of 19 (permalink) Old 05-06-2019, 01:34 AM
rdr09's Avatar
No, i replaced the 120 with a 140. The dust cover in the front grill is the one i removed cos my airflow is reversed. It has one. Also. i don't use the I/O plate.
Oh, you have a 200mm up there. So, that's good.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #10 of 19 (permalink) Old 05-06-2019, 02:14 AM - Thread Starter
From Italy
Rep: 0
Ok I think I'm fine with the 200mm. I need the dust cover in the front because is intake fan and it's not far from the floor (sometimes there is dust).
Why don't you use the I/O plate?
lpdevIT is offline
Tags
Airflow , Case Mod , Cooler Master , haf 912 , modding
