Desk PC - Air or water? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 22 (permalink) Old 07-15-2019, 05:57 AM
Da Boss
NexusRed's Avatar
Rep: 155 (Unique: 131)
I've been on all 3 sides of PC cooling. Air, Close Loop, and Custom.
The real question that should be asked is, "Do I want to deal with any maintenance outside of the regular stuff?"
If the answer is yes, then custom water cooling is on the table.
If the answer is no, then pitch it to the wind.
NexusRed is offline
post #12 of 22 (permalink) Old 07-15-2019, 07:15 AM
Overclocker in training
ThrashZone's Avatar
Rep: 186 (Unique: 111)
Hi,
Yep usually the only real detail necessary is will the giant piece of aluminum and copper fit in my case
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is offline
post #13 of 22 (permalink) Old 07-15-2019, 07:24 AM
Overclocker
JackCY's Avatar
Rep: 364 (Unique: 261)
Put the PC in fish tank. If you still want it separated from the tank then well go air cooling, so much simpler and maintenance free, no risk of leaks etc. cheaper too.
JackCY is offline
post #14 of 22 (permalink) Old 07-15-2019, 01:31 PM - Thread Starter
Animag771's Avatar
Rep: 11 (Unique: 4)
Quote: Originally Posted by GRA-HAM View Post
Im. not against air cooling. it just my preference to water cool. though. it can take a good part of peoples budget. and time. with maintenance. if you want to built and forget it. a good air coolers the way to go
Budget is a concern, but considering I already have a custom loop, I could just swap the pump (mine is noisy) with a decent pump/res combo and redo be set. Build and forget would be great though because having to drain a 20G fish tank every time I need to pop the top of the desk open for anything will get old real fast.
Quote: Originally Posted by Shawnb99 View Post
I always go with water. Way better temps that way, plus it way quieter. On air my GPU can easily hit 80 degrees, on water I never go above 45.
I won't be water cooling my GPU for multiple reasons. It's not good enough to bother adding a water block to, I hate the idea of having to get a new waterblock if I ever want to upgrade and it's also a terrible investment 9/10 because for the added cost you could dang near just run SLI/Crossfire with a second GPU.
Quote: Originally Posted by shilka View Post
Depends on the use case but for most users air cooling is good enough
By the way i hope you are not re-using that old CM PSU
Is there something inherently wrong with the CM? I have been wanting to swap it for some time now for a more efficient EVGA, just hasn't seemed worth it since I haven't had any issues with it.
It's such a toss up... Sexy looking, better performing water cooling setup all lit up under a glass desktop sounds great and I could reuse most of my water cooling stuff which wasn't exactly cheap. But it comes at the cost and headache that goes with it. Algea, corrosion, mineral buildup, clogged water blocks, system draining, leaks, trying to get all the bubbles out, the list goes on. I know there are ways around a lot of the issues but it's a lot to deal with.
Quote: Originally Posted by ThrashZone View Post
Hi,
Well since I'll be building the desk from scratch that's not a problem at all. If I end up going with air, if I get a bequite! Dark Rock TF (just stumbled across it) instead of a Shadow Rock Pro 4 clearances will be even less of a concern, but I can't find any comparisons.
Umm... No. If you're talking about a mineral oil build, that's a heck of a mess that I don't plan to get myself into. Also there will be live fish and living plants in the tank so that's not an option. I did however consider drilling the side of the tank and putting a heat exchanger inside it in-line with a water cooling loop to help dissipate heat. But then reality hit and I realized it would be way overkill for just gaming on a mild overclock and the additional heat added to the tank would probably kill (or at minimum, stress) my fish.
Animag771 is offline
post #15 of 22 (permalink) Old 07-15-2019, 02:12 PM
Intel Pariah
King4x4's Avatar
Rep: 98 (Unique: 75)
Let us say your are building a complete air system... let us say your complete rig requires 10 fans and they will run at 1600rpm full time to cool the complete system.
In water, You can fill it full of rads and run twice that number of fans... at 900rpm. Full Quiet and get better cooling.
Of course that might cost you between 1000-1500$. But, It's a loop that will survive multiple times with only a gpu waterblock changed everytime.
Hell I got parts from Hydra 1 still being used in my current project Hydra 3.
As for the SLI cost versus waterblocks, You got a point... but dual SLI air cards I WILL NEVER RUN ON AIR. I would rather game on a single waterblocked gpu. Water is meant for SLI period. Dual GPUs running full throttle is a sound I would rather not hear after 6 years of watercooling.
Check out my buids:
Build Log: Hydra
Build Log: Hydra 2
Build Log: Hydra 2.5
Build Log: Hydra 3
Build Log: Mini-Hydra
Hydra
Hydra 2
(23 items)
Hydra 3.0
(10 items)
Intel i7 3930k @[email protected]
Asrock X79 Fataility Champion
3xInno3d GTX 780 with Full Nickel EK Waterblocks
Gskill RipjawsX [email protected] 11-11-11-31
2xSamsung 830 256gb
Seasonic 1250 watt
Custom H2O - 3x XSPC RX360 with EK Blocks
Danger Den Double Wide 21
Surround Gaming [email protected] (X-Star)
Keyboard
Cooler Master Trigger Red Caps
Mouse
Roccat Kone+
Audio
Roccat Kave 5.1 Headphones
Audio
Creative ZX (Incoming)
4930k
Asus Extreme Black Edition
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Gskil TridentX 2400mhz
Samsung 830 256GB
Samsung 840 500GB
2x Seasonic 1250watt
EK Supramacy
4x EK Blocks
6x EK XTX480
EK XT360
Case Labs TH10
Operating System
Windows 8.1
BenQ 3201 32in 4k IPS
Qnix 32in 1440 MVA
Qnix 32in 1440 MVA
Keyboard
Coolermaster Storm Trigger
Mouse
Roccat Kone
Audio
Creative ZX
Audio
AKG K7XX
3900x
Gigabyte Aorus Ultra
EVGA 1080 Ti
EVGA 1080 Ti
Ballistix Sport LT 32GB
EVGA G2 1600w
Full EKWB
Caselabs TH10
Operating System
Win 10 Pro
Acer 144hz G-Sync
King4x4 is offline
post #16 of 22 (permalink) Old 07-15-2019, 02:42 PM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Your PSU is 10 years old and while its not horrible it wont last forever and frankly you should not really be using that old of a PSU in a modern system
As for EVGA unless its a G2/P2/T2 dont bother most EVGA units are either flawed mediocre or outright crap
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #17 of 22 (permalink) Old 07-15-2019, 03:19 PM
Da Boss
NexusRed's Avatar
I hear ya. I loved my custom loop. I did it right the first time and didn't have any issues. No type of build up, no bubbles beside the initial leak down test.
The initial cost is somewhat expensive, but if you are smart and go with universal parts, it's not that bad. I spend about $500 total. That's fittings, tubing, waterblocks for both GPU and CPU, 2x360mm rads, fans, and little extra. That all lasted about 3 builds before I shelved it. Still have everything besides fresh tubing and distilled water.
Crap.. Now all of this talk makes me want to go back lol.
NexusRed is offline
post #18 of 22 (permalink) Old 07-15-2019, 03:27 PM - Thread Starter
Animag771's Avatar
Rep: 11 (Unique: 4)
Wow it's really been 10 years already. Holy crap, good point. I was looking at the G2, I've recently put one in my HTPC build and hasn't let me down yet, not to mention it's dead silent.
post #19 of 22 (permalink) Old 07-16-2019, 12:58 AM
Senior OCN Member
shilka's Avatar
The Seasonic Focus and Prime Ultra are also options worth looking at
I bought a Prime Ultra to replace my 5 year old EVGA G2 because it does not have enough cables and there is no ports left to add more
I am just waiting for the CableMod cables i ordered to show up
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #20 of 22 (permalink) Old 07-16-2019, 06:17 AM
TeslaHUN's Avatar
Rep: 23 (Unique: 21)
I vote for water . If u are designing new Desk PC , you can have huge rads ,so it will be dead silence under load.
Exactly what i did , designed a desk (made from wood scrap lying around my house for years ) to hold 3x 400mm radiator. You are not restricted to use 120 /140mm radiators ,like in PC cases . In total i had 6x20cm fan on the radiators at 350rpm even on load. With that much radiator surface u can cool anything.
YT video , under gaming benchmark ,whisper quiet .And the best part ; i cant hear the coil whine from the VGA , the 6mm thick tempered glass is isolating it so much better then any PC case with 3mm glass
TeslaHUN is offline
