Desk PC - Air or water? - Overclock.net - An Overclocking Community
post #1 of 22 (permalink) Old 07-13-2019, 10:44 AM - Thread Starter
Animag771's Avatar
Rep: 11 (Unique: 4)
**TLDR**
[Help me make the decision between air or water cooling for my future desk-pc, so I can get to the design stage. Is there anything I've forgotten? What would you do and what are the reasons behind it? Any ideas or opinions are greatly appreciated.]
The last time I touched my computer was in 2015 when I switched it over to a custom water cooled loop. I haven't even turned it on in over a year because I've been otherwise occupied building my own house and haven't had time for gaming. It's nothing too fancy... i7-3820, MSI 950, 16GB GSKILL Sniper 1866 RAM, 500GB WD Blue and a CM 850W Silent Pro. It's using an XSPC single bay reservoir, XSPC Raystorm, Phobya DC12-400 pump and an XSPC-EX120 radiator connected with PETG and monsoon hardline fittings (which seem to have been discontinued). Apparently one of my fittings had a tiny tiny leak which never showed up during my initial leak tests and has drained most of my system over the year of sitting there not running. I need to build a desk for the office anyway so I figure why not go ahead and put the computer in it to save some floor space, though I did think of a wall PC, but don't trust the cat and I'm pretty sure the wife would object to the aesthetic.
So with all of that out of the way and since I'll be dismantling the computer anyway, I can't decide to go with air cooling or water cooling.
Air cooling would probably be the easiest to set up, cheapest, possibly quietest and easiest maintenance, but will not be as nice looking, will require a bulkier desk to accommodate the CPU cooler (I'm thinking something like a Dark Rock Pro 4), and will not run as cool as water cooling.
On the other side, liquid cooling will still be very quiet (if I get a better pump), run cooler, look a lot better and allow me to have a more sleek/modern desk, but the maintenance could suck, have to be concerned with the possibility of leaks, more expensive and a PITA to set up the first time ESPECIALLY if I use hard lines again.
The maintenance is a big one because there will be a 20G fish tank sitting on this desk and it would absolutely suck to have to completely pull the top off to clean radiators and I don't want them to be external.
Edit: And yes, I will be giving this poor thing an SSD while I'm at it.
Animag771 is offline
post #2 of 22 (permalink) Old 07-14-2019, 09:05 AM
GRA-HAM's Avatar
Rep: 0
go with the water-cooling . make a air tester for the system. saves a lot of hassle like the pics. cost about 20$ for parts
GRA-HAM is offline
post #3 of 22 (permalink) Old 07-14-2019, 09:16 AM - Thread Starter
Animag771's Avatar
Rep: 11 (Unique: 4)
I appreciate the tip and I see how that could help with leak testing and as a visual indicator that the system is sealed, but it doesn't do much for long term maintenance like cleaning radiators or having to drain the system and clean water blocks etc.
Any particular reasons you chose water over air?
post #4 of 22 (permalink) Old 07-14-2019, 09:37 AM
GRA-HAM's Avatar
Rep: 0
its about 100% more efficient than air so your temps are lower so you can make pc nearly silent though lower fan speed. and it looks cool if done right
GRA-HAM is offline
post #5 of 22 (permalink) Old 07-14-2019, 02:17 PM - Thread Starter
Animag771's Avatar
Rep: 11 (Unique: 4)
Well sorta. The temps can only ever get as low as ambient regardless of water vs liquid and eventually the liquid will reach equilibrium, but yes it is still a more efficient cooling method. I don't do benching and I'm only running a very mild overclock so the performance gain will probably be negligible. It does indeed look sexy though. Nice rig BTW
post #6 of 22 (permalink) Old 07-14-2019, 02:50 PM
Overclocker in training
ThrashZone's Avatar
Rep: 189 (Unique: 114)
Hi,
Bingo ambient can't be beaten without a chiller
Mild oc just air cool it
Plenty of cool looking air coolers be-quiet has some nice ones.
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is online now
post #7 of 22 (permalink) Old 07-14-2019, 07:43 PM - Thread Starter
Animag771's Avatar
Rep: 11 (Unique: 4)
Quote: Originally Posted by ThrashZone View Post
Hi,
I'm currently looking at the be-quiet Dark Rock Pro. It does look nice, but I just wish I could find a cpu cooler that had a vertically oriented fan like the Shadow Rock LP, but with more heatsink space and push/pull fans. That orientation would look so much better from a top down view. All the ones with fans oriented vertically are only rated at about 95W TDP which wouldn't work well for my i7-3820.
So that's 1 vote for air and 1 for liquid. Anybody else? I wish I knew had to start a poll.
post #8 of 22 (permalink) Old 07-15-2019, 05:02 AM
GRA-HAM's Avatar
Rep: 0
Im. not against air cooling. it just my preference to water cool. though. it can take a good part of peoples budget. and time. with maintenance. if you want to built and forget it. a good air coolers the way to go
GRA-HAM is offline
post #9 of 22 (permalink) Old 07-15-2019, 05:09 AM
Shawnb99's Avatar
Rep: 66 (Unique: 47)
I always go with water. Way better temps that way, plus it way quieter. On air my GPU can easily hit 80 degrees, on water I never go above 45.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #10 of 22 (permalink) Old 07-15-2019, 05:40 AM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Depends on the use case but for most users air cooling is good enough
By the way i hope you are not re-using that old CM PSU
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
