[Build Log] "White Noise" - Fractal Meshify S2 Build - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 07-15-2019, 10:31 AM - Thread Starter
tindolos's Avatar
Rep: 93 (Unique: 81)
Hello OCN,
I recently upgraded my rig with some new-ish parts that I purchased on the OCN marketplace! However, I never got around to upgrading the case, the Fractal Define XL, or making it look very good on the inside. You can see the mess below.
Components:
Mobo: Z270 Gaming Pro Carbon
CPU: i7-7700K
GPU: GTX 1070
RAM: TridentZ RGB 16 GB
PSU: Corsair RM850i
Boot Drive: Samsung 870 Pro 512 GB
Storage: Samsung 840 Evo 250 GB
Case: Fractal Design XL
One thing to note is that before, I was using a Corsair H50 to AIO cool my Phenom II X6 1090T. When I installed upgraded components and started using the i7-7700k, the H50 was NOT cutting it. Kaby Lake runs hot, and the little H50 was on its way out. I installed a Noctua NH-D15S (not pictured in before pic).
The Fractal Design XL is one behemoth of a case! I remember purchasing it because it was advertised as being super quiet, and with the side panels on you cannot hear a thing. But it's so freaking heavy! Lugging it around to LANs was a feat of strength. Today I retired the Fractal Design XL in favor of a newer Fractal Case - the Meshify S2! With the new case in mind, I figured it was high time that I put some effort into making this rig look really good.
So without further ado, here is what I purchased (pic below):
Fractal Design Meshify S2 - White with tempered glass side panel
Chromax Noctua NF-A15 HS-PWM Fan
Chromax Noctua NA-HC4 Heatsink Covers (white)
Asiahorse PSU Extension cables (white)
Cable combs (black)
GeeekPi 5 inch HDMI Monitor
This case is absolutely huge! I couldn't wait to get started building in it!
Some shots of the Chromax Gear
Guys, I really believe Chromax is one of the best things to happen to Noctua
My first time building in a case that has a PSU bracket, a neat little feature
Getting a lay of the land
Dropping in some components!
Also my first time working with cable combs! These little things really help keep the cables tidy, highly recommend!
EPS and 24 pin connectors wired up!
GPU is wired and ready!
Shot of the sketchy cable management job in the back
EPS closeup, and some insight into wiring the upper LED strip! So glad this case has an open spot in the top corner!
Everything seated! I'm getting real hyped right about now!
Playing around with the LED lighting
Remember that 5" LCD panel? Testing it out and seeing what kind of nonsense we can do with it. I mostly want it to display temps and stats!
Propped up inside the case while I decided where to mount this bad boy
Ultimately, I decided to attach it to the PSU shroud toward the bottom of the case. I considered mounting it back in the case were a reservoir goes (behind the BAWLS bottle), but I wanted it to be closer and more focal, so I chose this location instead.
And there we have it! We went from a mess to not half-bad! I want to put a LED coaster under the BAWLS to make it stand out. It will likely be a part of the case until I start watercooling and need the space. The Meshify S2 is an amazingly large case, there is so much room to build, and you can tell that each design decision was made for a reason (well, maybe not the fan controller, but it's better than nothing). I highly recommend pickup up one of these cases if you are on the fence about it! In the future, I will be getting back to watercooling and doing a build inside this case, and I cannot wait!
Thanks for sticking around and please drop a comment if you have any ideas for improvement!
Current Rig
(12 items)
i7 7700K @ 5.0 Ghz
MSI Z720 Gaming Pro Carbon
Gigabyte GTX 1070 8GB WINDFORCE OC
G.SKILL TridentZ RGB DDR4 16 GB @ 3200
Samsung 970 Pro NVMe M.2 512GB
Samsung 840 EVO SSD 250GB
Corsair RM850i
Noctua NH-D15S
Fractal Define XL
Operating System
Windows 10
Keyboard
SteelSeries Apex M750
Mouse
SteelSeries Rival 310
tindolos is offline
post #2 of 6 (permalink) Old 07-15-2019, 11:47 AM
I can count to potato
Fluxmaven's Avatar
Rep: 36 (Unique: 13)
Nice upgrade. I was considering the Meshify S2, but wanted to run a 420mm up top and didn't want the fans/radiator covering up the top of the motherboard.
Do they make a bigger Bawls? It looks a bit small in all that empty space. I like the LED Coaster idea though.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
TridentZ B-die 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #3 of 6 (permalink) Old 07-16-2019, 09:18 AM - Thread Starter
tindolos's Avatar
It really is an awesome case! Yeah, it's a bummer that it covers up components. And I think with a 420, you can't run a rear exhaust fan.
They make them in cans, but then I wouldn't be able to light it up very well. Maybe I'll consider making a stand for it so that it sits a bit higher up. I just wanted to throw something in there because there is so much empty space if you aren't water cooling... I can dream though.
Current Rig
(12 items)
i7 7700K @ 5.0 Ghz
Corsair RM850i
Noctua NH-D15S
Fractal Define XL
Operating System
Windows 10
Keyboard
Mouse
tindolos is offline
post #4 of 6 (permalink) Old 07-16-2019, 09:37 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1238 (Unique: 679)
Looks sweet, any plans for a loop or just wanted a huge case?
a 420 up top is gonna cause issues with any RAM that is >35mm. Even my relatively thin 280 AIO blocked my TridentZ (40mm) and I had to move the rad to the front. A 240/360 would have been fine.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #5 of 6 (permalink) Old 07-16-2019, 10:37 AM - Thread Starter
tindolos's Avatar
That's good to know! Thanks for the input! I've been eyeballing this case for a bit now, and I just pulled the trigger on it. I 100% want to watercool, but I may wait until I upgrade components in the future. It's been about 10 years since my last full WC loop, and I'm itching to get back to it. I haven't been able to find any full coverage blocks for my GFX card, and that is really what is putting me off from doing it at this point in time.
Current Rig
(12 items)
i7 7700K @ 5.0 Ghz
Corsair RM850i
Noctua NH-D15S
Fractal Define XL
Operating System
Windows 10
Keyboard
Mouse
tindolos is offline
post #6 of 6 (permalink) Old 07-16-2019, 11:26 AM
Fluxmaven's Avatar
Having it up on a stand would be a fun way of managing that empty space. I do like that idea, but this case is just begging for water cooling though
I also have TridentZ so the 420 wouldn't have fit. I do have a spare 360mm rad, but I wanted to use the 420mm since most of my nicer fans are 140mm. Just picked up an LD Cooling Little Devil PC-V7 and everything fits great in that.
I need to start build logs for the 2 big case builds I'm doing...
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
GTX 1080 FE
WD Black SN750
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Keyboard
Mouse
Glorious Model O
Mousepad
Audio
Audio
Focusrite 2i4 Gen2
Audio
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
WD Blue 3D m.2
Corsair AX760
InWin D-Frame Mini
i7 6700
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Tags
fractal , fractal meshify s2 , stat screen , white
