Scratch built Inwin 303 clone - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 07-23-2019, 01:24 AM - Thread Starter
Turdsandwitch's Avatar
Rep: 4 (Unique: 1)
I liked the look of the InWin 303 but it was a bit too small to fit my current rads etc and i didnt like all the extra holes and whatnot so i build my own one with plenty of room for activities.
im not a photographer so im not going to bombard you with 100's of photos of capacitors and arty shots of components
First up cut some 1mm thick steel and start bending, we dont have a box folder at work so i had to do it the hard way.
Also im renovating my house so excuse the mess in the background
6700K
ASUS sabertooth Z170
EVGA 1080ti
Turdsandwitch is offline
post #2 of 13 (permalink) Old 07-23-2019, 01:25 AM - Thread Starter
Rep: 4 (Unique: 1)
Time for holes, lots of holes and lots of measuring, fitting up components etc
post #3 of 13 (permalink) Old 07-23-2019, 01:27 AM - Thread Starter
Rep: 4 (Unique: 1)
once i was happy with the fitment i welded everything together and primed it with 2k epoxy urethane primer
post #4 of 13 (permalink) Old 07-23-2019, 01:28 AM - Thread Starter
Rep: 4 (Unique: 1)
One last fit up, lucky i did because there were a few holes i forgot to drill
post #5 of 13 (permalink) Old 07-23-2019, 01:30 AM - Thread Starter
Rep: 4 (Unique: 1)
Got the case back from the painters today, still a few things to do like paint the rads, wire a power button make back plates for the soundcard and GPU and a few other things to make and paint etc
post #6 of 13 (permalink) Old 07-23-2019, 03:41 AM
Jedi Mind Trick's Avatar
Rep: 94 (Unique: 73)
Man, that thing looks AWESOME! Nice job.
Jedi Mind Trick is online now
post #7 of 13 (permalink) Old 07-25-2019, 04:23 AM - Thread Starter
Rep: 4 (Unique: 1)
Fill port actually matches up with the hole i drilled....amazing, El cheapo power button and the rads painted and installed. Just a couple more bends to do but Its late, bed time
Also i lost the IO shield
post #8 of 13 (permalink) Old 07-25-2019, 03:36 PM
Stock is too casual~
Veii's Avatar
Rep: 78 (Unique: 46)
Can't wait for updates :3
Only the intake concerns me a bit
Are you maybe able to 3D laser etch some pattern which inwin cases have on the side / front of it ?
Like a honeycomb pattern (well be more creative) or some different kind of artistic sideways cut air holes
The Radi's will have some hard time to get intake
One thing i personally would add, are those spike feets people use to decouple hi-(fi) high end systems and subwoofers, where you can use them as nice looking artistic feets and decouple the vibrations a bit
Those things:
Ignoring the "how much it's actually worth for audio" part
It would give the case some breath room from the bottom - and overall dampen vibration transmission
SiSandra Inter-Core Bandwith 14nm Ryzen global #1 | Twitter
Personal Records
RAM > Viper Steel @ 3466C14 (64.2ns) & Alt | Hynix-MFR 3333CL14 (72.5ns) & Alt
GPU > Gigabyte 970 G1 @ 1595|1900 (Hynix) | RX 580 Red Devil GS @ 1620|2200 (Micron)
CPU > TR 1950X [email protected]1.2v & [email protected]1.365v[105Mhz FSB](3.23Beta)
#Main: 1700X [email protected]1.365v1.73Ghz IMC CL14 (64.2ns)」+ Dark Rock 3 | X370 Taichi 1.0.0.3 ABBA by The Stilt | Viper Steel [PVS416G400C9K]| Gigabyte 970 G1 | Samsung 850 Evo
Veii is offline
post #9 of 13 (permalink) Old 07-25-2019, 07:34 PM - Thread Starter
Rep: 4 (Unique: 1)
Those things:
ive got some feet from another case i have.
post #10 of 13 (permalink) Old 07-25-2019, 09:09 PM - Thread Starter
Rep: 4 (Unique: 1)
please, PLEAAAAASE Lord Gaben...no leaks
also my new PSU wont be here before the weekend so ill have to throw my old one in
