AI CRYSTAL 2020 - Big Red teardown and rebuild - ft. anidées - Overclock.net - An Overclocking Community
post #1 of 39 (permalink) Old 01-18-2020, 09:29 AM - Thread Starter
technologist
neurotix's Avatar
Rep: 356 (Unique: 203)
Hello all,
This build log will be a place to document and show off a rebuild of my current sig rig, Big Red, that will be taking place soon.
I could go into all the reasons why I am doing this, but to keep it short and sweet, I am very unhappy with my current Corsair 780T case, that is essentially falling apart in numerous places. My custom PSU shroud is damaged, and my custom drive cage covers LEDs are failing. It has a non-removable (unless I want to tear the thing all the way down anyway and punch out rivets) 5 1/4" bay in the top. The front and top removable fan filters have an aluminum front bezel that has to be removed to clean the dust filters, and has little tabs on the aluminum that bend around a plastic frame, and on the front one like 6 out of 8 of these have broken off. Same for the top one. It also has no place for drive mounting for my HDDs except in the ugly, provided drive cage that sits in the bottom front, which prevents things like custom water cooling (front mounted radiator, there's no place for a res either).
The case I have picked and ordered is the anidées AI Crystal AR3 RGB
Sorry for the large image, you can see it better on anidées website here: http://anidees.com/product/ai-crystal-ar3/
As far as components, this is a case swap, but I will also be documenting the teardown and cleaning process, and reassembly into the new case. This will mostly be a pictorial process of my rebuild effort. Benchmarks, etc. probably won't be done and posted, given that they have already been done and are available on my hwbot
All of the components will be identical to what is in my current sig rig, Big Red. The previous build log for Big Red will then be retired.
Current components list, in part:
AMD Ryzen 9 3900X
ASUS Republic of Gamers CROSSHAIR VIII HERO
16GB G.Skill Flare X (Samsung B-Die) DDR4-3200MHz 14-14-14-34 1.35v overclocked to 3800MHz 16-16-16-32-50 1.42v 1T (GDM Off) for gaming. G.Skill Turbulence II White LED RAM fan.
EVGA GTX 1080 ti FTW3 @ 2025/5940MHz in SLI
EVGA RGB SLI High-Bandwidth Bridge
Samsung 970 Evo 512GB M.2 drive (boot)
Samsung 840 Evo SATA III SSD
Western Digital Black 2TB
Western Digital Blue 4TB, Western Digital Blue 6TB
Arctic Cooling Liquid Freezer II 360mm AIO (38mm thick, aluminum) with 3x anidees AI-AUREOLA RGB fans
COOLER MASTER V1000 80+ Gold (Seasonic OEM)
power supply recommended by shilka a very long time ago (sup shilka)
anidées AI CRYSTAL v3/AR3 RGB Midtower
I think that's it for the box.
System performance can be seen on http://hwbot.org/users/neurotix as always but here is Fire Strike and Fire Strike Ultra results
https://hwbot.org/submission/4320058_
https://hwbot.org/submission/4320060...ti_14080_marks
Thank you for looking.
~neurotix
Big Blue?
(14 items)
Green
(12 items)
Ryzen 9 3900X @ 4.5GHz CCD0 1.375v VID OC, 4.2GHz CCD1- 1900Mhz fclk/uclk
ASUS ROG Crosshair VIII Hero BIOS 1201
EVGA GTX 1080ti FTW3 2025/5940MHz
EVGA RGB SLI HB Bridge
G.SKILL Flare X B-Die 3200 C14 @ 3800MHz C14-16-15-15-30-48 1T 1.475v GDM off
Samsung 970 Evo 500GB m.2 2280 PCI-E NVMe SSD
WD Black 2TB
WD Blue 4TB
WD Blue 6TB
Samsung 840 Evo SATA 256GB
COOLERMASTER V1000 (Seasonic 1000w 80+ Gold)
Arctic Cooling Liquid Freezer II 38mm 360mm AIO
Anidées AI-AUREOLA RGB fans x7
Prolimatech PK-3 Nano 30g tube
Anidées AI CRYSTAL AR3 RGB Midtower
Operating System
Debian Linux 10
Operating System
Win10 X64 Pro 1903 (gaming only), stripped down, updates blocked, Firewalled.
LG 34WN80C 34" 3440x1440 21:9 IPS, 300 nit, HDR
Keyboard
GMMK v2 104 key | Kailh Box Jades | HyperX PBT pudding (for now)
Keyboard
OCN Ducky DK1008 MX Blues
Keyboard
Corsair K70 Lux red led/MX Reds
Keyboard
Rosewill K85 RGB Kailh/Kaihua Blue switches
Keyboard
Ducky One 2 RGB fullsize
Mouse
Redragon Chroma M710 RGB (Omron Switches)
Mousepad
Corsair Polaris RGB
Audio
Logitech G230 red
Audio
Logitech Z2300 2.1 120w 8" sub, w/ 40w satellites
Other
Phanteks RGB 5050/Digital RGB strips
Other
Respawn Black/Gray Racing Chair
i5-7600k 5GHz 1.32v
ASUS ROG Z270H Strix
Sapphire R9 380X Nitro 1200/1500mhz
G.skill Ripjaws4 DDR4-3000 CAS15
Western Digital Caviar Blue 320gb
Samsung 850 Evo 256gb
OCZ ModXStream Pro 500w
Corsair H60/PK-3
Thermaltake Core V71
Operating System
Win10 Home
2x ASUS V236H 1080p
Keyboard
Corsair K70 Lux Blue LED Cherry MX Blue
Mouse
Cooler Master
Mouse
Thermaltake GAMMA
FX-8350 stock
ASUS ROG Crosshair V Formula
Sapphire R5 230
G.skill TridentX DDR3 2400mhz
WD Caviar Blue
Optical Drive
Lite On DVD-RW
OCZ ModXStream Pro 500W
Cooler Master TX3
Corsair SP120 Exhaust
Corsair C70
Operating System
Win7 Ultimate X64
ASUS V236H 1080p 23"
neurotix is offline
post #2 of 39 (permalink) Old 01-18-2020, 09:29 AM - Thread Starter
technologist
neurotix's Avatar
reserved
Case review from LTT. The one I'm getting is the newer version with ARGB fans and light strips, but should otherwise be identical.
Yes, I am crazy, so I am putting my computer in crazy, apparently.
Big Blue?
(14 items)
Green
(12 items)
WD Black 2TB
WD Blue 4TB
WD Blue 6TB
Operating System
Debian Linux 10
Operating System
Keyboard
Keyboard
Keyboard
Keyboard
Keyboard
Mouse
Mousepad
Corsair Polaris RGB
Audio
Logitech G230 red
Audio
Other
Other
i5-7600k 5GHz 1.32v
Corsair H60/PK-3
Operating System
Win10 Home
2x ASUS V236H 1080p
Keyboard
Mouse
Cooler Master
Mouse
Thermaltake GAMMA
FX-8350 stock
Sapphire R5 230
WD Caviar Blue
Optical Drive
Lite On DVD-RW
Cooler Master TX3
Corsair C70
Operating System
Win7 Ultimate X64
neurotix is offline
post #3 of 39 (permalink) Old 01-18-2020, 09:29 AM - Thread Starter
technologist
neurotix's Avatar
Finished
Hotlink to the build process pictures and finished result.
Big Blue?
(14 items)
Green
(12 items)
WD Black 2TB
WD Blue 4TB
WD Blue 6TB
Operating System
Debian Linux 10
Operating System
Keyboard
Keyboard
Keyboard
Keyboard
Keyboard
Mouse
Mousepad
Corsair Polaris RGB
Audio
Logitech G230 red
Audio
Other
Other
i5-7600k 5GHz 1.32v
Corsair H60/PK-3
Operating System
Win10 Home
2x ASUS V236H 1080p
Keyboard
Mouse
Cooler Master
Mouse
Thermaltake GAMMA
FX-8350 stock
Sapphire R5 230
WD Caviar Blue
Optical Drive
Lite On DVD-RW
Cooler Master TX3
Corsair C70
Operating System
Win7 Ultimate X64
neurotix is offline
post #4 of 39 (permalink) Old 01-23-2020, 05:34 AM
Turtle Lives Matter
damric's Avatar
Rep: 431 (Unique: 332)
I guess I need to order you some new stickers.
Any ideas?
https://www.etsy.com/shop/lukparts?r...about-shopname
Borg Cube AF
(15 items)
Ryzen RGB AF
(11 items)
Polaris
(12 items)
R5 1600 (12nm)
X470 GAMING PRO CARBON
Gigabyte RX Vega 56 Gaming OC
Ripjaws V
Silicon Power A80 NVMe
EVGA SUPERNOVA G3 750W
TCP-612
2x EVGA FX 120mm Fan
2x Cooler Master MasterFan Pro 140 Air Flow
HAF XB
Operating System
10-64 PRO
Samsung 4K 60Hz
Keyboard
Logitech G105
Mouse
Devastator II
Audio
Logitech Z623
Ryzen 5 1600 (12nm)
B450 Steel Legend
Vega 64
2x8GB WarHawk RGB
Silicon Power A80
SUPERNOVA G3
Wraith Stealth
Phankteks Eclipse P400A
Operating System
10 Pro
Samsung 58" 4K
Audio
Vintage Sony
R5 1600 (14nm)
GA-AX370-Gaming K5
XFX RX 570
Ripjaws V
VPN-100 NVMe
Rosewill CAPSTONE
Wraith Stealth
Cougar MX330-G
Operating System
10 Pro
ASUS 1080p 23"
Audio
Xonar SE
Audio
Logitech
damric is offline
post #5 of 39 (permalink) Old 01-25-2020, 10:07 AM - Thread Starter
technologist
neurotix's Avatar
Any ideas?
I'll take a look at that, lol. No- I don't need new stickers. The ones on my case now should probably peel off and still adhere on the new one. I have 3m sticky pads, double sided tape and other stuff like that too to use with them.
Thanks for looking, man, I'll keep you updated.
I have the case now- going to open it later and make sure everything is there, the tempered glass is ok, etc.
I also ordered a Arctic Liquid Freezer II 360mm AIO to replace my 4 year old Corsair H100i V2 cooler, as it is making some weird noises lately on boot, I think the pump may fail soon. I am also thermally limited on my 3900x and a custom loop is too expensive + too much maintenance that I cant really do due to the health issues. This new Arctic AIO is supposed to be great, just came out and was quite cheap for a 360mm aio cooler. I also ordered (and already have) a 3-pack of matching anidees ai-aureola rgb fans to go on the cooler, the same ones as in the case. So I am waiting on the cooler to arrive.
A few years back I had a local guy at an engraving shop make me some replacement acrylic for the top of my old custom arcade stick controller, that I used to use when I played Street Fighter at tournaments. He did an excellent job. If hes still around, I wonder if you can engrave/laser engrave on tempered glass? (I saw this on an LTT video, tge 'hive mind build' stream) I thought about coming up with some custom graphics that say "ai crystal" and maybe the retro vaporwave/synthwave perspective line grid to go across the bottom. And these would both light up from within and change colors from the rgb fans and light strips, and since its engraved in glass it would be translucent. So if its possible I might go that route, please dont send stickers.
Big Blue?
(14 items)
Green
(12 items)
WD Black 2TB
WD Blue 4TB
WD Blue 6TB
Operating System
Debian Linux 10
Operating System
Keyboard
Keyboard
Keyboard
Keyboard
Keyboard
Mouse
Mousepad
Corsair Polaris RGB
Audio
Logitech G230 red
Audio
Other
Other
i5-7600k 5GHz 1.32v
Corsair H60/PK-3
Operating System
Win10 Home
2x ASUS V236H 1080p
Keyboard
Mouse
Cooler Master
Mouse
Thermaltake GAMMA
FX-8350 stock
Sapphire R5 230
WD Caviar Blue
Optical Drive
Lite On DVD-RW
Cooler Master TX3
Corsair C70
Operating System
Win7 Ultimate X64
neurotix is offline
post #6 of 39 (permalink) Old 01-25-2020, 10:26 AM
Turtle Lives Matter
damric's Avatar
Oh I forgot to tell you. I practically stole a Vega 64 from the market at techpowerup for $175. It was so cheap because the guy didn't want to bother with removing the water block. But that made it even more awesome because he included the stock cooler which was he never even used. It's running in Michele's downstairs 4k gaming rig now. I still use the RX 570 in my main rig though.
Borg Cube AF
(15 items)
Ryzen RGB AF
(11 items)
Polaris
(12 items)
R5 1600 (12nm)
Ripjaws V
TCP-612
HAF XB
Operating System
10-64 PRO
Samsung 4K 60Hz
Keyboard
Logitech G105
Mouse
Devastator II
Audio
Logitech Z623
Ryzen 5 1600 (12nm)
B450 Steel Legend
Vega 64
2x8GB WarHawk RGB
Silicon Power A80
SUPERNOVA G3
Wraith Stealth
Operating System
10 Pro
Samsung 58" 4K
Audio
Vintage Sony
R5 1600 (14nm)
GA-AX370-Gaming K5
XFX RX 570
Ripjaws V
VPN-100 NVMe
Rosewill CAPSTONE
Wraith Stealth
Cougar MX330-G
Operating System
10 Pro
ASUS 1080p 23"
Audio
Xonar SE
Audio
Logitech
damric is offline
post #7 of 39 (permalink) Old 01-25-2020, 12:02 PM
Not a noob
Bridgypoo's Avatar
Rep: 2 (Unique: 2)
What a steal! And we know that the 570 is getting good use and is in a home with a good owner.
I'm helping @neurotix with cable management (apparently I'm really good at it) so can't wait for the challenge and to take pictures!
Blue
Intel Core i5 7600k
ASUS ROG STRIX Z70H
Sapphire Radeon R9 380X
16GB Gskill Ripjaws 4 DDR4 PC 3000
WD Green 320GB Sata II
Corsair H60
Xigmatek 140mm blue LED fan x2
Operating System
Windows 10 Home
Asus 238H
Asus 238H
Keyboard
Corsair K70 LUX
Bridgypoo is offline
post #8 of 39 (permalink) Old 01-26-2020, 02:55 PM - Thread Starter
technologist
neurotix's Avatar
Big Blue?
(14 items)
Green
(12 items)
WD Black 2TB
WD Blue 4TB
WD Blue 6TB
Operating System
Debian Linux 10
Operating System
Keyboard
Keyboard
Keyboard
Keyboard
Keyboard
Mouse
Mousepad
Corsair Polaris RGB
Audio
Logitech G230 red
Audio
Other
Other
i5-7600k 5GHz 1.32v
Corsair H60/PK-3
Operating System
Win10 Home
2x ASUS V236H 1080p
Keyboard
Mouse
Cooler Master
Mouse
Thermaltake GAMMA
FX-8350 stock
Sapphire R5 230
WD Caviar Blue
Optical Drive
Lite On DVD-RW
Cooler Master TX3
Corsair C70
Operating System
Win7 Ultimate X64
neurotix is offline
post #9 of 39 (permalink) Old 01-26-2020, 05:30 PM
Turtle Lives Matter
damric's Avatar
I try and look at the case but my eyes only see the couch, pillow, and kitty.
Also a disney character sock
Borg Cube AF
(15 items)
Ryzen RGB AF
(11 items)
Polaris
(12 items)
R5 1600 (12nm)
Ripjaws V
TCP-612
HAF XB
Operating System
10-64 PRO
Samsung 4K 60Hz
Keyboard
Logitech G105
Mouse
Devastator II
Audio
Logitech Z623
Ryzen 5 1600 (12nm)
B450 Steel Legend
Vega 64
2x8GB WarHawk RGB
Silicon Power A80
SUPERNOVA G3
Wraith Stealth
Operating System
10 Pro
Samsung 58" 4K
Audio
Vintage Sony
R5 1600 (14nm)
GA-AX370-Gaming K5
XFX RX 570
Ripjaws V
VPN-100 NVMe
Rosewill CAPSTONE
Wraith Stealth
Cougar MX330-G
Operating System
10 Pro
ASUS 1080p 23"
Audio
Xonar SE
Audio
Logitech
damric is offline
post #10 of 39 (permalink) Old 01-29-2020, 05:14 PM
Rep: 3 (Unique: 2)
definitely in the market for a new big boy case and was checking this out....
excited to see how this progresses
mechavore884 is offline
