Ryzen 5 1600 AF build - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 02-18-2020, 10:13 PM - Thread Starter
RWBY FNDM's Avatar
Rep: 6 (Unique: 4)
Case is the Matrexx 30. Cable management isn’t very good, so I’ll come back to it. Needs GPU, and storage, and it’ll be done.
Any other advice or tips?
This is going to be a sub $650 build.
RWBY FNDM is offline
post #2 of 3 (permalink) Old 02-18-2020, 11:07 PM
Stock is too casual~
Veii's Avatar
Rep: 50 (Unique: 32)
Advice's:
- Put the tiny Wraith Spire switch to High Mode, so you get the full PWM Range
- Install ASRock Polychrome in the future, to update the RGB firmware ~ fixes some sensoring issues with ASRock boards
- Read out Ram with Thaiphoon Burner, so you know what you'll be running and which SOC voltage you'd need to run
- =//= SOC voltage ~ don't keep it at over 1.1 usually 12nm needs in the 1.025-1.05v region (depends on memory speed and IC)
- If you want to be fancy and know you have a good chip, flatten out both IHS and CPU Cooler as one is Concave, the other Convex (strongly optional)
Storage advices depend on the current spend $ and the location + usecase
Same for the gpu
SiSandra Inter-Core Bandwith 14nm Ryzen global #1 | Twitter
Personal Records
RAM > Viper Steel @ 3466C14 (64.2ns) & Alt | Hynix-MFR 3333CL14 (72.5ns) & Alt
GPU > Gigabyte 970 G1 @ 1595|1900 (Hynix) | RX 580 Red Devil GS @ 1620|2200 (Micron)
CPU > TR 1950X [email protected]1.2v & [email protected]1.365v[105Mhz FSB](3.23Beta)
#Main: 1700X [email protected]1.365v1.73Ghz IMC CL14 (64.2ns)」+ Dark Rock 3 | X370 Taichi 1.0.0.3 ABBA by The Stilt | Viper Steel [PVS416G400C9K]| Gigabyte 970 G1 | Samsung 850 Evo
Veii is offline
post #3 of 3 (permalink) Old 02-19-2020, 12:18 AM
rdr09's Avatar
Rep: 880 (Unique: 638)
I suggest a 1T M2 drive. For the gpu, fastest card that does not require power from the the psu or at most an 8 PIN.
https://www.newegg.com/zotac-geforce...-480-_-Product
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
