Shift - An ongoing tale - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 03-18-2020, 01:10 PM - Thread Starter
Rep: 0
So the Phanteks Shift is terrible for temperatures, but oh so achingly good looking. I'd love to say that I am far too sensible to won over by looks, but here I am.
This is my journey trying to make things better.
Initially I am starting with just a simple config.
ASUS 1070 Strix O8G
i5-8400
ASUS H370-i mini-itx
Samsung 970 Evo 1Tb M.2-2280 NVME
Corsair SF 600 Platinum
The temperatures weren't great. I guessed that the primary problem was the 8 pin ATX motherboard cable which could only route downwards and block airflow to the primary case exhaust fan. Looks like a job for some custom cables!
AlSki.net is offline
post #2 of 18 (permalink) Old 03-18-2020, 01:36 PM - Thread Starter
Rep: 0
In another sensible decision of style over substance, I've chosen the MPDC transparent 15AWG wire which I am using un-sleeved. At least this time I can probably claim that the reduced heat from the extra cross-sectional area will make all the difference in trying to keep this case cool.
I mean cool in temps, the way the cable catches the light is already so cool (if you like that kind of thing).
I also got some custom cable combs from ShakMods. They were able to lasercut them to take the 28 wires, and all I paid was the same as any other of their ebay bundles.
post #3 of 18 (permalink) Old 03-18-2020, 01:39 PM - Thread Starter
Rep: 0
Next
Still need some more wire for the GPU 8 pin (and enough spare in case I upgrade and need another 6/8 pin)
Re-wiring fans
Replacing the cooler
and possibly cutting the case to pieces to get a 240mm radiator in without changing the overall dimensions!
post #4 of 18 (permalink) Old 03-18-2020, 01:45 PM
Taking a break
iamjanco's Avatar
Rep: 145 (Unique: 66)
like it--subbed
Muffler Bearings
(24 items)
i9-7900X, i9-10940x
Asus Rampage VI Extreme
EVGA X299 DARK
EVGA GeForce RTX 2080 Ti XC
(2 ea) EVGA GTX 1080 Ti FTW3
G.SKILL F4-3200C14Q2-64GTZ
(2ea) Intel Optane 900P (480GB)
(2ea) Samsung 850 Pro 1TB
(2ea) Samsung 850 Pro 256GB
(2ea) Samsung 970 Pro 512GB
(1ea) Samsung 950 Pro 256GB
EVGA SuperNOVA 1600 T2
Custom water
Custom, 8020x3060 and x2020
Operating System
Win 10 Pro/Ubuntu
NEC PA272W-BK-SV
Eizo ColorEdge CE240W
Alienware AW3418DW
Keyboard
Ergodox EZ with Kailh Thick Gold (Bronze) and Copper switches
Audio
Bottlehead Mainline Amp
Audio
RME ADI-2 Pro FS 2-in/4-out AD/DA Converter
Audio
FOCAL Clear Professional Headphones
Audio
Mr. Schpeakers ETHER C Flow 1.1 Headphones
Other
Protectli Firewall Micro Appliance With 6x Intel Gigabit Ports, Intel i5 7200U, AES-NI
Other
Misc. see build description for details
iamjanco is offline
post #5 of 18 (permalink) Old 03-21-2020, 12:17 PM - Thread Starter
Rep: 0
Planning, yes there has been some
Just in case you might think this is all a bit ad-hoc... Oh no, there has been some planning while I talked myself into tackling this.
post #6 of 18 (permalink) Old 03-21-2020, 12:29 PM - Thread Starter
Rep: 0
And now we resume our scheduled programing
Some more progress, firstly small Allen keys are really useful (Pic1). Not only for pushing the pins out of the power block, but also for pulling the wires into the right curves. I also found that having the cable combs half way around each bend (or at least the last few when you have quite so many on a run) holds the wires so they don't slip as you bend the next one.
(Pic 3) I could measure this or YOLO... that'll do.
(Pic 4) While I could just do a nice 90 degree bend against the cable combs for the inner radius, I found that pushing the cable towards the corner got me a nice outer radius.
post #7 of 18 (permalink) Old 03-21-2020, 12:33 PM - Thread Starter
Rep: 0
A new day dawns
"No dear, I am definitely not having breakfast with my wires..."
post #8 of 18 (permalink) Old 03-21-2020, 01:11 PM - Thread Starter
Rep: 0
Measure twice, cut once
Right so we have got this far (Pic1), and all the cables line up from start to end, apart from the pair I've tied together. Admittedly the bends into the PSU are currently approximate, because I was getting tired last night and needed coffee.
So first (Pic2) a quick check that even the shortest will reach (I already made that mistake on the 24 pin ATX)
post #9 of 18 (permalink) Old 03-21-2020, 01:16 PM - Thread Starter
Rep: 0
Measure twice, cut erm... twice
So obviously we can cut the wires to all match the length of the shortest. Then just a quick tidy up of the bends into the PSU and check it.
Oh, its too long...
Where did I put those wire cutters?
post #10 of 18 (permalink) Old 03-21-2020, 01:21 PM
Meep
Gilles3000's Avatar
Rep: 332 (Unique: 234)
Subbed! What kind of cable (and gauge) are you using? Don't think I've seen any that hold bends that well.
Gilles3000 is offline
