DIY PC Case - Aluminium all over the place - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 05-30-2020, 12:57 PM - Thread Starter
Yuriewitsch's Avatar
Rep: 21 (Unique: 16)
After fidling with custom cooling on AMD graphics cards(HD 7950, 290X, 5700XT) I used my "special skills" for creating my own PC case.
I wanted to do an upgrade of my PC and I also wanted smaller case, which would be placed right on my desk. I did my search according to mATX from factor and also I wanted simple color scheme without RGB - black/grey.
Here are components, which will be used for upgrade of my PC:
MB - MSI B450M Mortar MAX - under 90 € deal, decent VRM cooling, BIOS flashback, Ryzen 3000 compatibility, whole layout is "cup of tea",
CPU - AMD Ryzen 7 3800X - also nice deal, otherwise I would take 3700X,
CPU Cooler - Arctic Freezer 34 eSports DUO - great little cooler, cheap and great performer,
DDR4 - Kingston HyperX Predator 2x16 GB 3200 MHz CL16 - cheap 32GB kit, nothing extra, at least no RGB and simple black color,
SSD - ADATA XPG SX8200 PRO M.2 512GB - simple SSD for OS,
HDD - Seagate BarraCuda 2,5" 1TB ST1000LM048 - quiet HDD for data, will be placed behind MB tray through antivibration screws (inspired by Jonsbo RM4),
GPU - Sapphire 5700 XT + Raijintek Morpheus II + VRM heatsink - will see, how it performs in this new case,
PSU - Corsair SF600 - small but still great PSU,
Fans - Arctic P14 PWM PST CO 140mm - awesome deal for decent fans.
Here is most of boxes from components:
Well, the case itself will be a tough one to make, after some time of preparing and planning I decided to use 3mm aluminium plates for outside of case and 8x8mm aluminium profiles for inner frame. Everything will be screwed together by M3 screws. Dimensions will be 350 x 330 x 230 mm.
From old PC case (CoolerMaster Elite 430) I took whole MB tray and used it as template for new piece made from aluminium. This backside of MB tray I modified to match mATX MB and painted it with matte black spray.
A lots of things like push buttons, antivibration silicone screws, rubber wire grommets, PSU extensions, various screws and cover caps, etc I ordered from aliexpress. I still waiting for delivery on some of them. Thx to COVID-19.
4 feets for this case is gonna be used from old PC case - Jonsbo RM4, also 8 distancing screws for MB instalation are from old case - CoolerMaster Elite 430.
It took a lot of work and measuring, Dremel tool and straight saw were a big help at cutting. Almost done on MB tray, only rubber wire grommet will be placed near PSU position.
Backside panel of case is practically done, I need to screw it into inner frame and do top and bottom panel of case. I am not decided on side panels, maybe from acrylic or aluminium.
I did some preliminary test fit, if everything is fine and checks. So far so good.
Still a lot of work left and some little things from China to wait for.
Maybe painting everything into black color, I dont know. No RGB though.
So far, this is the progress. Hoping that I find more time to do this right.
Case: DIY Aluminium Case PSU: Corsair SF600 CPU: AMD Ryzen 7 3800X RAM: Kingston HyperX Predator 32GB 3200MHz CL16 GPU: Sapphire 5700XT + Raijintech Morpheus II mod
Yuriewitsch is offline
post #2 of 10 (permalink) Old 05-31-2020, 04:16 PM
Ecopot's Avatar
Rep: 3 (Unique: 3)
Wow nice job on hand cutting the aluminum! Looks great so far.
Sent from my iPhone using Tapatalk
https://www.overclock.net/forum/1808...ook-shelf.html
AMD 3500
Biostar B450GT3
Radeon RX 560
T-Force Vulcan Z
M.2 XPG SX8200 Pro
Enhance Rage Power
Scythe Choten
Porable Book Shelf
Ecopot is offline
post #3 of 10 (permalink) Old 06-03-2020, 07:32 AM
Mod your socks off!
zZ_e_Nn's Avatar
Rep: 4 (Unique: 3)
Hand crafted
keep those updates coming
Project R4W v1.0
R4W
(11 items)
3900X
Asrock X570M Pro4
ASUS 1080TI Strix
Gskill NEO
M2 Samsung 950 PRO
M2 GIGABYTE NVMe
Corsair 760i
3x 280mm
VRM and SB Anfi-Tec
CPU block Aqua Computer cuplex kryos NEXT AM4
Other
Display Aqua Computer VISION Touch
zZ_e_Nn is offline
post #4 of 10 (permalink) Old 06-03-2020, 07:59 AM
I can count to potato
Fluxmaven's Avatar
Rep: 54 (Unique: 23)
Off to a good start!
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
64GB TridentZ 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #5 of 10 (permalink) Old 06-03-2020, 11:14 AM - Thread Starter
Thx guys, I will try to keep doing some progress, but it's hard to find some time to do this.
So here is at least some update:
I took a picture of aluminium leftovers from front and back plates, basically I drilled a hole in corner and then I cut those openings with jig saw. Mini files were used to smooth the edges.
I used miter box and hand saw to cut those 8mm profiles for inner frame. I tried to make them as straight and even as I could.
With this dremel accessory (a big help with this project and also with my 5700XT mod) I've made 2,5mm holes in those profiles and threaded them with M3 screw-tap. Inner frame was screwed together by M3 embedded screws, just like whole case will be.
I don't have all holes and threads finished, but I already tried to get the case together, yet without MB's tray. Here is how it looks right now.
The clearings between plates are pretty nice or "okayish", but I will need to adjust 1 place a little. It has like 1mm gap between front and top plate, but nothing serious so far.
For next update, I will need to embed those screws into plates around whole case to keep it clean. And maybe put MB's tray in. And secure it, off course.
See ya.
post #6 of 10 (permalink) Old 06-09-2020, 07:41 AM - Thread Starter
Well, another update is here.
Firstly, I drilled remaining holes a countersinked them.
I installed all four feet with M4 screws.
Also I cut a hole in MB's tray for cables from PSU. I hope a rubber grommet will fit in (if it actually will come from China)
Another cutting into 8mm inner frame was needed to make room for rear fan.
Here are some pictures of the case as it is right now:
Only one place is not fitting as it should, but it is covered by PSU, so no problem at all.
I installed hardware into the case so I could see, how it looks like and if there is some colliding problem. So far so good.
I also checked if a side panel behind MB's tray fits and how it looks. Good enough I'll say.
I'm still waiting for lots of things from China (rubber grommet, cables, screws, plastic head caps for screws, M.2 heatsink), so there is bunch of things left to do:
- transparent side panel,
- fixing side panels into case (4 screws in corners maybe?),
- front dust filter (one month more to wait for demciflex),
- cable management,
- maybe painting whole case with grey or anthracite color, I like that contrast between black and grey/silver color, but scratches - not so much,
- and other little things...
So, this is it.
For now.
post #7 of 10 (permalink) Old 06-09-2020, 11:28 AM
Senioritis Member
Lady Fitzgerald's Avatar
Rep: 533 (Unique: 335)
Very impressive! Keep up the good work!
Jeannie
i7-3930k
ASUS P9X79 WS
MSI R7850 Twin Frozr 2GD5/OC Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Monoprice 1x2 powered HDMI Splitter
Kingston HyperX 32GB (8 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K8/32GX
128GB Samsung 840 Pro SSD
4TB Samsung 850 EVO SSD
Optical Drive
LG 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive CH12LS28
Corsair HX750W
COOLER MASTER GeminII S524 120mm Long Life Sleeve CPU Cooler
Antec Two Hundred v2
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Logitech M525 with Unifying Receiving
Audio
Corsair SP2500 2.1 Speakers
Audio
ASUS Xonar Essence STX Virtual 7.1 Channels 24-bit 192KHz PCI Express x1 Interface 124 dB SNR / Headphone AMP Card
Other
LSI 9211-8i HBA card
Other
HooToo® HT-CR001 3.5" PCI-E to USB 3.0 Multi-in-One Front Panel Internal Card Reader (6 Memory Slots, Genesys GL3220 Chipset) & SuperSpeed USB 3.0 3-Port Hub (VIA VL800 Chipset), can read & write: M2/MS Micro, High-Speed CF(UDMA), UHS-I, SD, SDHC,...
Other
StarTech HSB220SAT25B 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane
i7-5930K Haswell-e
Asus X99-E WS/USB 3.1
Visiontek Radeon 7870 2GB with 6 miniDisplayports
G-Skill Ripjaws 64GB (8x8GB) DDR4 2133
Samsung 850 EVO 4TB SSDs
Samsung 950 Pro 512GB m.2 SSD boot drive
Corsair AX760
Noctua NH-D15S Cpu cooler
Scratch built. Currently under construction at https://www.overclock.net/t/1602023/preparing-for-a-scratch-built-case
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
El Cheapo Allsop hard plastic
Lady Fitzgerald is offline
post #8 of 10 (permalink) Old 06-10-2020, 07:36 AM
BSME
dirty elf's Avatar
Rep: 8 (Unique: 8)
awesome, love the look of fresh milled aluminum. dont paint it black just polish it!!
///M
First Build
(15 items)
10 Year Upgrade
(9 items)
Intel Core i7-870 Lynnfield
Asus P7P55D-E Pro
MSI RADEON RX480 8GB
G.Skill Ripjaws 2 x 8GB
Crucial MX 300
Western Digital Caviar Black SATA 6gb/s 7200rpm Drive
Optical Drive
LG Blu-Ray Drive
Corsair 650TX 650 Watt
Cooler Master Hyper 212 Evo
Antec Three Hundred
Operating System
Windows 7 64-bit Home
Dell U2417H
Dell U2417H
Keyboard
Apple USB Keyboard
Mouse
Logitech M510
Ryzen 9 3900x
MSI B450 Tomahawk Max
RX480
Crucial Ballistix Sport LT
Samsung 970 Evo Plus
Seasonic PRIME Ultra Titanium
Be Quiet Dark Rock Pro 4
NZXT 500
Operating System
Windows 10
dirty elf is offline
post #9 of 10 (permalink) Old 06-10-2020, 03:04 PM - Thread Starter
Thx.
I like that contrast between aluminium and black hardware, somehow I'm slowly changing my mind on that paint too.
post #10 of 10 (permalink) Old 06-20-2020, 10:05 AM - Thread Starter
It's going a little slower, because I already using this PC case. But some minor "little things" were done.
Side panel from 3mm acrylic is already cut, with jig saw like into butter.
However it is a little darker than I hoped, so maybe later I am going to try a clear acrylic.
Here is a photo of temporary support for GPU, I am already thinking of better and less conspicuous version.
Cable management is also done, it could be better, but I think it is fine as it is.
Right now I spending too much time with Windows 10 and reinstallation of games and programs, so it will be even more slower. :-)
Next time I will place a RADEON logo onto GPU from original 5700 XT cooler. And maybe mounting side panels and making that new support for GPU.
Will see.
Cheers.
