Case Mod GPU(s) Cooling Guide - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 11-16-2008, 07:27 PM - Thread Starter
I Love this Hobby!
Gunderman456's Avatar
Rep: 580 (Unique: 485)
Hi Folks,
I would like to share my experience when it came to modding my CoolerMaster Cosmos 1000 Case to improve my GPU cooling in SLI.
While I love the good looks, roominess and tooless features of the Cosmos 1000, most reviews quibbled about it's lack luster cooling around the Hard Drive bay. I had already solved this problem by removing the bottom case 120mm fan and placing it directly on top of the HD bay. I replaced the bottom 120mm fan with the 120mm fan at the back of the case and purchased a CoolerMaster 120mm Led Blue Silent Fan (TLF-S12-EB) and placed it at the back of the case where the blue hues could be appreciated.
Although I have RivaTuner moderating my GPU temps by incorporating three fan profile speeds, as the temps increase while playing 3D intensive games, I also exercised additional caution by removing my side case panel.
Since I was getting tired of removing the side panel every time I gamed, I decided to mod the side panel to enable ventilation by placing a newly purchased CoolerMaster 120mm Led Blue Silent Fan (TLF-S12-EB) to directly exhaust the heat generated by the GPUs.
I've added five pictures (below) to demonstrate my progression.
As you can see in Picture #1, I took a piece of paper (size of the CoolerMaster 120mm fan) and punctured the fan screw holes directly in the paper. Then I traced a grid with each square measuring 5,6 mm (7/32") the circumference of the Titanium Drill Bit. I traced an X in each square for centering. I then predrilled with a smaller Drill Bit (to prevent slippage) before I used the 5.6mm Titanium Drill Bit to drill all the required holes.
In Picture #2, you can see that all the holes have been drilled, the schemata had been removed and the metal shavings have been cleaned from in and around the holes.
In Picture #3, you can see the back side of the panel, where in my case, I had to remove some of the sound proofing material prior to drilling.
Picture #4, showcases the Fan screwed onto the case.
Picture #5, the Fan is now in operation!
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ 1160GHz Core/1350GHz Mem
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Open Water Loop
Fractal Design Arc Midi R2
Operating System
Win 7 Pro 64bit
Nixeus EDG 27" Freesync 1440p 144Hz
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Microsoft Sidewinder X5
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Intel Core i5-3570K @ 4.5GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990
G.SKILL Ripjaws X DDR3 8GB 1600MHz
Crucial SSD 128GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Corsair Vengeance MM200
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
AMD Athlon II X4 640
ASRock N68C-GS
NVIDIA 6600GT
G. Skill Ripjaws DDR3 1600MHz
WD Caviar Blue 500GB 16MB Cache 7200RPM
Optical Drive
LG Optical Drive
Thermaltake TR2 600W
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Viewsonic 19” Flatscreen CRT
Keyboard
Gigabyte GK-K6800 103
Mouse
Zalman ZM-M300
Mouse
Gunderman456 is offline
post #2 of 10 (permalink) Old 11-16-2008, 07:36 PM
spartacus's Avatar
Rep: 154 (Unique: 138)
Very nice and good idea! The outside aluminum panel looks really clean.
steam: a4erik
sc: spartacus:835
spartacus is offline
post #3 of 10 (permalink) Old 11-16-2008, 07:41 PM - Thread Starter
I Love this Hobby!
Thanks! I was worried that the drill holes would look like a product of a bullet tear, but thankfully, the holes drilled with the Titanium bit were clean. I had to make sure that the bit went all the way through to its smooth shaft and it helped create the clean look.
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Optical Drive
Open Water Loop
Operating System
Win 7 Pro 64bit
Keyboard
Logitech G15
Mouse
Mousepad
Audio
Crucial SSD 128GB
Optical Drive
LG DVD R/W
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Mouse
Mousepad
Audio
ASRock N68C-GS
NVIDIA 6600GT
Optical Drive
LG Optical Drive
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Keyboard
Mouse
Zalman ZM-M300
Mouse
post #4 of 10 (permalink) Old 11-16-2008, 07:48 PM
Rep: 329 (Unique: 253)
I bet it's a pain plugging that fan in and removing the side panel once it is plugged in, I did the same thing just to see how much it improved my temps a while back on a botched window mod, anyway the wire is a bit short to plug it into your mobo huh? Used to be frustrating. I used to forget about it and end up yanking it out when removing the side panel ;x
It looks real nice though ;]
GeforceGTS is offline
post #5 of 10 (permalink) Old 11-16-2008, 07:59 PM - Thread Starter
I Love this Hobby!
Thanks GeforceGTS!
I thought about that when I went to plug the new fan into the MOBO and decided to forgo the predictable frustration one could suffer if one plugged it directly into the MOBO.
I reached for the included 3 to 4 pin adapter that came with the new 120mm CoolerMaster fan, which not only acted as an extender to the fan wire but now I could connect it to the power supply cables.
In that manner, I can open the side panel without worrying about accidentally pulling the fan from the MOBO and possibly damaging the MOBO/fan.
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Optical Drive
Open Water Loop
Operating System
Win 7 Pro 64bit
Keyboard
Logitech G15
Mouse
Mousepad
Audio
Crucial SSD 128GB
Optical Drive
LG DVD R/W
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Mouse
Mousepad
Audio
ASRock N68C-GS
NVIDIA 6600GT
Optical Drive
LG Optical Drive
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Keyboard
Mouse
Zalman ZM-M300
Mouse
post #6 of 10 (permalink) Old 11-16-2008, 08:03 PM
Derp's Avatar
Rep: 735 (Unique: 515)
Well done the finished work looks clean enough to have been there from the factory, +rep deserved
Derp is offline
post #7 of 10 (permalink) Old 11-16-2008, 08:13 PM - Thread Starter
I Love this Hobby!
Thanks Auld! Interesting enough, CoolerMaster thought enough about this problem and in the Cosmos S revision, they placed a factory side intake fan on the case.
So anyone with the Cosmos 1000 should consider this mod, since even CoolerMaster themselves tried to fix this shortcoming.
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Optical Drive
Open Water Loop
Operating System
Win 7 Pro 64bit
Keyboard
Logitech G15
Mouse
Mousepad
Audio
Crucial SSD 128GB
Optical Drive
LG DVD R/W
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Mouse
Mousepad
Audio
ASRock N68C-GS
NVIDIA 6600GT
Optical Drive
LG Optical Drive
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Keyboard
Mouse
Zalman ZM-M300
Mouse
post #8 of 10 (permalink) Old 11-17-2008, 02:14 PM - Thread Starter
I Love this Hobby!
For a comparison between CoolerMaster Cosmos 1000 and the CoolerMaster Cosmos S go here;
http://www.tomshardware.com/news/ces...case,4653.html
Some things to consider when modding the Cosmos 1000.
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Optical Drive
Open Water Loop
Operating System
Win 7 Pro 64bit
Keyboard
Logitech G15
Mouse
Mousepad
Audio
Crucial SSD 128GB
Optical Drive
LG DVD R/W
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Mouse
Mousepad
Audio
ASRock N68C-GS
NVIDIA 6600GT
Optical Drive
LG Optical Drive
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Keyboard
Mouse
Zalman ZM-M300
Mouse
post #9 of 10 (permalink) Old 11-27-2008, 09:35 PM
skywarp00's Avatar
Rep: 18 (Unique: 13)
very nice. so stealing your idea!
skywarp00 is offline
post #10 of 10 (permalink) Old 11-28-2008, 06:58 AM - Thread Starter
I Love this Hobby!
Welcome, that is why it's there!
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Optical Drive
Open Water Loop
Operating System
Win 7 Pro 64bit
Keyboard
Logitech G15
Mouse
Mousepad
Audio
Crucial SSD 128GB
Optical Drive
LG DVD R/W
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Mouse
Mousepad
Audio
ASRock N68C-GS
NVIDIA 6600GT
Optical Drive
LG Optical Drive
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Keyboard
Mouse
Zalman ZM-M300
Mouse
