[Project] triple-screen mount - Overclock.net - An Overclocking Community
post #1 of 100 (permalink) Old 04-17-2009, 06:27 PM - Thread Starter
seven9st surfer's Avatar
Rep: 171 (Unique: 134)
I finally got sick of how much desk space was being taken up by my monitor stands. So walking through Home Depot this week, i decided to make a mount for all of them. This was after looking online and seeing that they cost around $300... So here's how I did it:
Parts:
1/2" x 12 pipe x 2 @ 3.31 = 6.62
1/2" x 10 pipe x 3 @ 2.90 = 8.70
1/2" 45 degree elbow x 2 @ 1.53 = 3.06
1/2" tee x 1 @ 1.26 = 1.26
1/2" flange x 1 @ 6.60 = 6.60
1/2" straps x 1 pk @ 1.31 = 1.31
M4 x 200 machine screws x 4 (3/pk) @ 0.79 = 3.16
10-28 x 3/4" machine screws x 1 (8/pk) @ 0.98 = 0.98
10-28 x 1" machine screws x 1 (8/pk) @ 0.98 = 0.98
1/4" - 20 x 1-1/2" machine screws x 1 (4/pk) @ 0.98 = 0.98
2' x 4' sheet of MDF x 1 @ 3.96 = 3.96
for a grand total of: $37.61!
And the process:
First, I fit together all the pieces of piping. You might think that the weight of the monitors would unscrew the joints, but when the whole assembly is this big, you can really get some torque going and get it realllllly tight. The most important part was to get the four pieces across the top level.
Next, I cut the backpieces for the 3 monitors, and a mounting plate for the whole assembly
And here's the three backplates and the mounting plate.
Ignore the extra holes. You wouldn't believe how hard it is to measure out an exact square. Then I realized I had a wallmount assembly for my TV, so I used it as a jig for the holes.
Using the M4 screws (VESA standard is 4mm diameter, 0.7 thread pitch), I attached the plate to the back of the 19"...
And the 22"
Then, using a T-square, I measured the distance from the top of the monitor to where I wanted the center of the piping to run.
Then, I started drilling and fitting the straps to where they go. The bolt heads are behind the plate, and then I tightened the nuts down. I also set up a mockup of how I attatched it to my desk. You can see that I bolted the flange through that board, but I also used that fourth, smaller piece of MDF basically as a big washer underneath the whole thing. Then, I clamped the whole thing down to my table. It's not going anywhere.
And it works!
I had to be careful not to tighten down the screws into the monitor too hard, because of the screw heads coming out the back for the straps. All Home Depot had was round head. If I had used flat-head or even pan-head, I could have counter-sunk the holes, so the head would fit flush, like I was able to do with the screws for the VESA mounts on the back of the monitors.
And the second monitor goes on
And the third
I can't believe it actually worked. Now comes the fun part. Installing the thing. Here's how my desk looked to begin with. And that's an old flight manual and folded up pieces of paper under the main monitor to even it up with the side ones.
And with it all cleared off
First, I had to drill holes in the desk (measuring carefully, of course).
That's my father in law holding it up while i do my best to reach around the back and tighten up those nuts. While the dog helps, of course.
And it holds. I know, it looks a little crooked in this pic, but it's mostly just the way the individual monitors meet each other at the bend. I can still tweak it a little bit to get those monitors perfectly straight.
And here's the setup with everything in its place and wires managed. Except for that one monitor cable on the left. It wasnt quite long enough to get routed with the others, but never fear. Newegg shipped me my new one today.
And a closeup of the stand
So that's it. A triple-screen mount for under $40. Hope this maybe helps out someone, because I asked around here, and couldn't find any guides for homemade mounts like this. So had to come up with one from scratch, and I think it turned out pretty nicely. Let me know what you think!
seven9st surfer is offline
post #2 of 100 (permalink) Old 04-17-2009, 06:33 PM
Phaeton's Avatar
Rep: 52 (Unique: 43)
Wow SMEXY!!!
Originally Posted by assaulth3ro911
c2d isnt server processor it wont work as a server. C2D isnt for multi networking and S%@$ like that, C2D is good for multi tasking, nothing else
Phaeton is offline
post #3 of 100 (permalink) Old 04-17-2009, 06:40 PM
Rep: 2560 (Unique: 1482)
Oh, Dood!
That is frikkin SWEET!
Custom Case building, dream and build
Custom Cases: Obsidian Silence, Silentium, Halcyon, Anvil, Indigo
Case Mods: Liquid Chameleon, LC-Lan Box
"Semper Fidelis"
Syrillian is offline
post #4 of 100 (permalink) Old 04-17-2009, 06:42 PM
It's still almost enough.
Chunky_Chimp's Avatar
Now that's awesome! +1
Combined air and water cooling tips: Fan database | My San Ace 9G1212H1011 review | Don't mix metals or use premixes / dyes | Distilled vs. tap water | Good radiator brands | Water (almost) can't flow too fast | Which PT Nuke to use | Regarding thermal paste spreading
Deep Blood
(15 items)
Soft Sentinel
Intel Core i7 920 D0 (Batch # 3901A240)
Foxconn X58 Blood Rage (non-GTI)
Sapphire Vega 64 8GB
6GB Corsair Dominator 1.6GHz TR3X6G1600C8D Rev 3.2
Samsung SSD830 128GB / Seagate 640GB+2TB+2x4TB
Optical Drive
Samsung SH-S223Q 22X
Antec HCPP-850
XTTH | OCZ Freeze | 9G1212H1011
CaseLabs SM8
Operating System
Windows 7 Ultimate x64 SP1
Dell U2410f (rev. A02)
Keyboard
Code 104 w/O-rings + Vortex PBT/POM doubleshot keycaps
Mouse
Roccat Kone EMP w/Dechanic Mini pad
Audio
Asus Xonar DX / Klipsch RM-14s + Dayton DTA-120 / MXL Tempo
Other
Microsoft Lifecam Cinema
Intel Core 2 Duo E6320
Intel DP35DP
XFX GeForce 7600GT
2GB Mushkin DDR2 800 5-5-5-12
Seagate Barracuda 7200.10 320GB
Optical Drive
Asus 18x multi-burner
Enermax Liberty 400w modular
Rosewill R5604-TBK
Operating System
Windows XP Pro SP3 32-bit
Samsung LN-S2351W
Keyboard
Ideazon MERC
Mouse
Logitech MX-518 (rev.2; 1800 DPI [no Teflon feet])
Mouse
Xtrac Pads Ripper
Chunky_Chimp is offline
post #5 of 100 (permalink) Old 04-17-2009, 06:43 PM
hotwaxisbad's Avatar
Rep: 10 (Unique: 10)
Wow, nice job! I like how you used the PVC/Metal tubing as the arms.
hotwaxisbad is offline
post #6 of 100 (permalink) Old 04-17-2009, 06:44 PM
Rep: 349 (Unique: 308)
Very nice
Set up looks very clean.
±B±
Rest in peace Syr, you won't be forgotten.
I'm a nerd, not a miracle worker.
BlankThis is offline
post #7 of 100 (permalink) Old 04-17-2009, 06:45 PM
Rep: 17 (Unique: 17)
Awesome job on the monitor stand. I've contemplated something like this in the past, but now I know it is possible (and for cheap as well).
+rep
Biggs is offline
post #8 of 100 (permalink) Old 04-17-2009, 06:59 PM - Thread Starter
Wow guys, thanks for all the responses. I really appreciate the compliments!
Like I said, I hoped this could help someone else!
post #9 of 100 (permalink) Old 04-17-2009, 07:06 PM
Bonz(TM)'s Avatar
Rep: 204 (Unique: 177)
Wow, this is amazing. I guess that means I HAVE to buy a 3rd monitor. I've been looking at the triple stands but they are so expensive.
As I got down toward the middle I saw your desk. I was like... that is the exact same desk I am sitting at right now.
As I got further, I saw your dog. I have a dog that looks EXACTLY like that! It's a Shepherd/Husky mix. There is a pic of her in my 'Tiny' link in my sig
Very nice dude. I'm definitely gonna be doing this soon!
Bonz(TM) is offline
post #10 of 100 (permalink) Old 04-17-2009, 07:28 PM
Overclock Failed...
billbartuska's Avatar
Rep: 1249 (Unique: 969)
Cpuld you mount the monitors on the wall instead of the desk, for a totally "floating" effect?
https://www.overclock.net/images/smil...lame-small.gif5 GHz Overclock Club https://www.overclock.net/images/smil...lame-small.gifMisinformation is available from a variety of other sources. Misinformation is just like real information but wrong
....and enough power to shoot the speaker cones through the walls.
billbartuska is offline
