Antec 300 - Project Martini - Overclock.net - An Overclocking Community
post #1 of 66 (permalink) Old 09-02-2010, 05:04 PM - Thread Starter
Retired Staff
Tator Tot's Avatar
Rep: 2146 (Unique: 1310)
Well let's get on with an Introduction:
This is my Antec 300, my oldest model actually (without the CPU Backplate hole, no Cable Holes, and Tri-Cool fans instead of Two-Cool.)
I'm doing this modding because the case needs it and my last project is on serious hold until I can get a job and lots of money. But might inevitably be scrapped.
The Plan:
  • Cut out Fan Grills
  • Cut Cable Holes
  • Paint inside and out flat black
  • Paint Thermalright TY-140 fan for side panel.
  • Whatever Else I think of
Table of Contents
Day:
  1. Cut fan grills out And did some sanding down of the cuts.
  2. Cable Hole Cutting & Cut Sanding
Tator Tot is offline
post #2 of 66 (permalink) Old 09-02-2010, 05:15 PM - Thread Starter
Retired Staff
Tator Tot's Avatar
Alright it's time to get modding:
Time to do my first cuts:
Thanks for lookin at my mod. I know it's nothing exciting for and it's just another silly mod. But hey it's my mod so
post #3 of 66 (permalink) Old 09-02-2010, 05:17 PM
Retired Staff
staryoshi's Avatar
Rep: 429 (Unique: 310)
Good start! You can get some very reasonable airflow in the 300 Get some u-channel tubing on those holes and roll! I remember doing this on my old 300... I used a wire cutter to cut out the grills, with the u-channel tubing it covered up the jaggies :3
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><b><a href="https://www.overclock.net/t/1294303/review-arctic-cooling-accelero-hybrid/0_20">My Arctic Cooling Accelero Hybrid Review</a></b><br><br><a href="#"><strong>My Other Reviews</strong> <span class="spoiler-help">(Click to show)</span></a><span></span><a class="spoiler-link H-spoiler-toggle" href="#"><strong>Warning: Spoiler!</strong> <span class="spoiler-help">(Click to show)</span></a><div class="spoiler-hidden"><br><a href="https://www.overclock.net/hard-drives-storage/989297-sataii-usb2-0-usb3-0-xfast.html"><span style="font-size: 12px;"><span>Quick USB 3.0 Benchmarks</span></span></a><br><span style="font-size: 12px;"><a href="https://www.overclock.net/nvidia/895590-gtx470-vs-gtx570-comparison.html">GTX470 vs GTX570 Comparison</a></span><br><a href="https://www.overclock.net/nvidia/835606-evga-gts-450-review-tons-content.html">EVGA GTS450 Review</a><br><a href="https://www.overclock.net/computer-cases/855693-myopenpc-dragon-bench-review-build-log.html">MyOpenPC Dragon Review and Build Log</a><br><a href="https://www.overclock.net/nvidia/793143-msi-gtx460-1gb-sli-review.html">GTX460 1GB SLI Review</a><br><a href="https://www.overclock.net/nvidia/778125-evga-gtx460-1gb-superclock-review.html">EVGA GTX460 1GB SC EE Review</a><br><a href="https://www.overclock.net/nvidia/800329-gtx460-1gb-vs-gtx465-review.html">GTX460 1GB vs GTX465</a><br><a href="https://www.overclock.net/ati/705552-5850-vs-5870-comparison-benchmarks.html">HD5850 vs HD5870 Comparison</a><br></div></div></div>
staryoshi is offline
post #4 of 66 (permalink) Old 09-02-2010, 05:20 PM - Thread Starter
Retired Staff
Tator Tot's Avatar
I'll definitely have some U-Channel on the holes. I need to order some stuff from MNPC-Tech that way I have proper modding supplies. Then get some paint.
post #5 of 66 (permalink) Old 09-02-2010, 05:22 PM
Retired Staff
staryoshi's Avatar
I got what I thought was a decent price on u-channel from bestbyte.net, might wanna check there too.
post #6 of 66 (permalink) Old 09-02-2010, 05:31 PM - Thread Starter
Retired Staff
Tator Tot's Avatar
I'm gonna do some shopping around but it's going to end up with who I can order the most stuff from.
I'm going to go to Home Depot & Lowes over the weekend to see if they have the U-Channel I want.
And then look into some Aluminum Carbide cutting disks for my dremel.
post #8 of 66 (permalink) Old 09-02-2010, 07:16 PM - Thread Starter
Retired Staff
Tator Tot's Avatar
Originally Posted by PapaSmurf View Post
Subbed. I love mods on the smaller cases like this.
I just love the Antec 300; if someone would work out the stock config like I plan to finish this mod:
IE: Air filter on the side panel
black insides
cable holes
better fan grills
Then it'd just be a purely epic case.
Right now a CPU Backplate hole is up for consideration. But if I do it, I'm just going to make a mammoth hole and not to any motherboard specifically.
post #9 of 66 (permalink) Old 09-02-2010, 07:20 PM
Retired Staff
Robilar's Avatar
Rep: 675 (Unique: 477)
Always fun to mod an inexpensive case.
One thing I always like to mention is how cheap powdercoating is.
I've done entire cases with accessories for around $25 (as long as its a standard color).
Stripping the paint can be a hassle but places that powder coat typically do paint stripping off metal (either acid bath or sand spray).
Nothing beats a powdercoat finish on a case and by the time you factor in the cost of primer and paint, (not to mention time), its almost the same.
Home PC
Intel G3440
Asus B85M-E/CSM
EVGA GTX 950
Patriot Viper 3 - 2x8GB 1600hz
Samsung EVO 850 - 500GB + 4TB x2 / 3TB x 2 - WD
Optical Drive
LG CH12LS28 Bluray
Corsair CX430 V2
Scythe Big Shuriken 2 w/Corsair SP120 Fan
NMEDIAPC HTPC 6000B w/ Pro LCD Module
Operating System
Windows 10 64 Bit
Samsung 75" TV....
Keyboard
GooBang Doo MX3
Mouse
GooBang Doo MX3
Robilar is offline
post #10 of 66 (permalink) Old 09-02-2010, 07:25 PM - Thread Starter
Retired Staff
Tator Tot's Avatar
If I could find a good powder job for $25 I'd definitely go that route.
Right now I plan to paint it myself but I'm going to look into a powder coat as well (see what's available locally so I don't have to shell out shipping.)
Right now though, cutting; polishing, ect is all WAY more important.
