[OCN Labs] NobleChairs Icon Review by Duality92 - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 01-21-2019, 11:28 AM - Thread Starter
ლ(╹ε╹ლ)
Rep: 180 (Unique: 141)
What’s up everyone! So, I’ve been using my Noblechairs Icon for a few months now, so it’s time to put out the review.
After reading up online on the now very vast market of computer chairs, while most of them are marketed as “gaming chairs” (likely referring to “still comfortable after long sitting sessions”), one stood out for me, that was the Noblechairs Icon line-up, unlike others, it was subtle, premium looking and I had seen nothing but good things being said on social media. It was then that I sent off an email to them about getting my hands on a sample as my old leather chair was starting to give out after 10+ years being sat on and wasn’t very adjustable, but still very comfortable.
I had them send the Gold/Black version, I felt it would sit well at my setup and not stick out like a sore thumb (unlike the two RGB builds on my desk). The day it got to my doorstep, I was quite surprised by the sheer weight of the box. I brought it in my workshop and was happy when I could put it down that’s for sure. It was then that began the adventure of assembly, the manual instructs you to assemble the chair with help from someone and we can clearly see why during the assembly, but it can be done solo. Even so, I’d still suggest having someone help with at least the back portion of the chair.
Assembly is quite easy and straight forward; there are a total of 4 hex bolts for the base and 4 hex bolts for the back rest (already installed loosely), then 2 smaller bolts for the covers that go over the back rest brackets. The manual is very clear and easy to follow. Overall assembly is really easy; the only part I needed to use the manual is for the base orientation, to make sure I had it the right way.
All the materials used in the construction of the chair feel ultra-premium, the stitching, the chromed portions of the arms, the fully aluminum casted base and included neck and lumbar pillows, even the packaging made the experience feel premium.
Now things get ever better, because any product isn’t worth purchasing if the customer service backing it makes the experience a nightmare. My experience is one that basically never happens when dealing with sponsored or review products, but my first sample wasn’t up to par, it just wasn’t at the height of what I felt Noblechairs was aiming for in terms of quality and premiumity (is that even a word? It is now.). In my day to day, I’m a QA Manager and I thought to myself, this chair wouldn’t have left my factory if I was manufacturing these chairs. At this point, you might be saying, “Well, isn’t that bad??”, but actually it’s quite the opposite, because after contacting Noblechairs, they offered to send me a second one, out of the same warehouse, to show this is an isolated issue, I also did some investigating on my own with people I know own Noblechairs chairs and none of them reported the issue I had with mine.
You might be wondering what the issue with my chair was, well, they were relatively minor. I’m assuming that their chairs when quality checked, get a marking on them from the inspector doing the inspection, both the back and seat had these, usually these just wipe off with a bit of rubbing, but on mine, it wouldn’t come off, so markings on the chair back and seat were clearly visible (too visible). The other issue I had was that the aluminum logo on the back had a grainy surface, which made aluminum stick out and made it look bad, as well as a being quite crooked. Both tiny, aesthetical issues, but didn’t fit the premium image I had of the company, neither did it rest well with them. The second chair I received did have the same markings, but much less visible and wiped off with a few strokes of clean damp cloth. These markings are normal since it proves the parts have been quality checked, but should be barely visible or entirely erased before packaging (and be removable if visible).
This made my experience feel even more premium as they could’ve just told me to clean my chair and redo my pictures to “hide” the logo or put Sharpie over it so it’s not visible.
Now, with my ultra-lengthy intro, let’s dive into the technical specs and use of this chair.
The arm rests are fully adjustable, they slide from left to right, rotate to some degree in both directions, you can bring them further up front or closer to the back rest and you can raise or lower them. On top of this, you can loosen the four bolts for each under the seat to bring the whole arm rest assembly closer or further to the seat, so that’s 5 total adjustable settings on them.
As far as the base goes, the stock gas shock is a tad high; being just the right height for my 5’10” frame at its lowest point, but there’s a shock with 3cm less height that is available for purchasing for shorter people or with shorter legs as ergonomically, your feet should lay flat on the ground. The whole base structure is made out of thick cast aluminum, then powder coated matte black. The wheels are nice, smooth, not too big and feel high quality, they insert easily into the base. The shock and shock cover are both as high quality as the rest of the chair, but I think the shorter shock should be included as default to cater to people shorter and taller than myself, which I think is more within the center of the average height of users.
The tilt lever and mechanism is easily usable and locks adequately when used as well as easily disengaged. For the height lever, it’s very smooth and doesn’t take too much for it to actuate, but enough to not accidently press it (unlike my work chair where I often hook it with my feet and it drops me about an inch suddenly, what a rush!). The location of these levers are easily accessible while sitting too, which is a sign of a properly thought out design. The seat and back are very firm at first, but quickly become the perfect density for my comfort (comfort is subjective, so I won’t dwell too much into this, but know it is a firm chair, so firm that the first two nights using it, I had lower back pains, but that quickly went away when I broke in the foam and adjusted the chair properly for my form and shape).
The lever for the back has a very stiff spring, so I wouldn’t suggest actuating it when you’re not sitting in the chair as I’m sure you could catapult stuff with the chair if needed (bonus, this chair could be used against zombies!). However, when sitting on it, it is easily adjustable and you can almost lay the back flat. When at its lowest position, I was not able to tip the chair over when laying down on it. This means the base is adequately positioned to prevent toppling over.
The included head cushion is soft, very comfortable when using, it also has anti slip backing so that when you have it installed it stays where you put it. The lumbar cushion for me, is too big, but is adequately sized when compared to ergonomic lumbar chair accessories (the mesh kind that strap onto chairs is sized similarly as far as thickness goes).
Logos are found on both cushions, on the pivot points covers for the backrest, two on the back rest; one aluminum in the middle at back level and that other stamped into the faux-leather at head level. I think it would’ve added a nice touch to have the Noblechairs name and logo on one of the base legs, but that’s totally my opinion.
I would give this chair an easy 4.5 out of 5 flames, but this is a pricey chair, but premium is pricey. If you’re in the market for a high quality, premium feeling chair, you’re not going to be looking at $200 chairs, this is the price bracket you’ll be in, so considering that, I can easily recommend the Noblechairs Icon to anyone in the market for a subtle, premium, fully adjustable, well-built chair. The customer support is above the vast majority of other computer enthusiast manufacturers, which I consider a great selling point. I removed a half flame because I think the shorter shock should be included instead of the one included and the longer one be available for purchase instead.
I hope you guys have enjoyed the read; I really enjoyed this chair and writing this review. I also want to thank Noblechairs again for supplying me these samples; I really hope to own more of your products in the future.
Duality92 is offline
post #2 of 16 (permalink) Old 02-22-2019, 10:53 AM - Thread Starter
ლ(╹ε╹ლ)
up.
post #3 of 16 (permalink) Old 02-28-2019, 06:04 PM
stangflyer's Avatar
Rep: 23 (Unique: 22)
Nice review!
stangflyer is offline
post #4 of 16 (permalink) Old 02-28-2019, 06:21 PM
LTSC for life crew
speed_demon's Avatar
Rep: 144 (Unique: 103)
I was expecting a higher price point after reading the review. Looks like a comfy and well built product!
Ryzen 1600 AF
MSI X470 Gaming Plus
MSI R9 390 8GB
16GB DDR4-3000
120GB HP M700 SSD
Samsung Spintpoint M9T 2TB
Seagate Barracuda 500GB
Corsair HX1200 (2017)
Thermalright True Spirit 140
Fractal Define S
Operating System
Windows 10 LTSC
Keyboard
Alienware W/Cherry MX Switches
Mouse
Logitech G5
speed_demon is offline
post #5 of 16 (permalink) Old 03-11-2019, 01:13 PM - Thread Starter
ლ(╹ε╹ლ)
Quote: Originally Posted by stangflyer View Post
Nice review!
Thanks!
I know right?!
post #6 of 16 (permalink) Old 03-19-2019, 05:50 PM
Hardware Rep
Peter Nixeus's Avatar
Rep: 181 (Unique: 119)
Good review! I love the diamond stitch!
Director Product Development
Nixeus Technology, Inc
Peter Nixeus is offline
post #7 of 16 (permalink) Old 03-20-2019, 02:57 AM - Thread Starter
ლ(╹ε╹ლ)
Thanks Peter!
The stitching is definitely super nice on these chairs.
post #8 of 16 (permalink) Old 03-21-2019, 07:48 PM
KCDC's Avatar
Rep: 28 (Unique: 23)
I've had one for about a year now and love the back support support being a taller guy. One of the few at this price point that doesn't have the racecar aesthetic that also appealed to my tastes. Going faux leather really drops the price.
ZMT watercool setup -- Phanteks Enthoo Elite -- hwlabs gtr 420 x 2 -- -- xspc tx360 crossflow -- noctua A14 PWM x9 -- 10940x -- Rampage VI Extreme Encore
Optimus Signature V2 -- 64gb 3200 tridentZ Royal CL14 @3600 CL16 -- AX1500i -- 2x 7600p nvme -- EK ZMT Tubing -- Ek Fittings -- dual Aorus Waterforce xtreme 2080ti -- asus PG279UZ monitors x3 7680x1440 surround
Bertha5.5
(22 items)
9900x
X2399 TUF Mk1
Aorus 2080ti Waterforce Xtreme
TridentZ Royal 3200 CL14
VROC 7600P x2
Ax1500i
HWL GTR 420 x2
XSPC TX360 Crossflow
EK ZMT 10/16
Corsair XC9
Corsair XD5
EK 10/16 Fittings
Noctua A14 PWM x9
Noctua NF-P12 PWM redux x3
Corsair Commander Pro
Enthoo Elite
Operating System
Win 10 Pro 64
Asus PG279QZ x3
Keyboard
Corsair K95 RGB Platinum
Mouse
Corsair Nightsword
Mousepad
Corsair MM800
KCDC is offline
post #9 of 16 (permalink) Old 03-21-2019, 07:54 PM - Thread Starter
ლ(╹ε╹ლ)
Time is the only factor with leatherette, it usually doesn't last over 10 years if you use it daily.
post #10 of 16 (permalink) Old 03-21-2019, 08:07 PM
KCDC's Avatar
Quite true, but not sure if I've ever owned a chair for that long yet. I think it was 3 years on the last one before the gas shock started leaking and ever-so-slowly drooping..
Bertha5.5
(22 items)
9900x
X2399 TUF Mk1
VROC 7600P x2
Ax1500i
HWL GTR 420 x2
EK ZMT 10/16
Corsair XC9
Corsair XD5
EK 10/16 Fittings
Noctua A14 PWM x9
Enthoo Elite
Operating System
Win 10 Pro 64
Asus PG279QZ x3
Keyboard
Mouse
Corsair Nightsword
Mousepad
Corsair MM800
KCDC is offline
You may not post new threads
