EVGA Z390 Dark Overview / Overclocking Guide - Page 2 - Overclock.net - An Overclocking Community
post #11 of 17 (permalink) Old 03-02-2019, 05:46 AM - Thread Starter
Jedson3614's Avatar
Rep: 62 (Unique: 53)
Quote: Originally Posted by elmor View Post
I'm sure this is a great board by EVGA, they've certainly put much effort into making the board. However, to state "I think this is the best Z390 motherboard you can get" without testing the competition for comparison is taking quite some liberty.
Good point! I’m going to reword it to the best one I’ve tested becuase I’ve only tested a few. I will reword it and update the article. Thanks for your input. I think the point I was trying to make was I love the layout and I’ve had better successful memory overclocks with this board. I’m over 4000MHz. I am going to add in an update soon.
I can add in results from the other boards I’ve used for comparison. What tests would you like to see? I’m trying to add more value to my reviews and like anything it’s a process. Every audience can be tricky!
Jeffrey M Edson
Jedson3614 is offline
post #12 of 17 (permalink) Old 03-02-2019, 06:59 AM - Thread Starter
Jedson3614's Avatar
Quote: Originally Posted by tatmMRKIV View Post
Yeah I only use e-leet for monitoring, and other people have also had issues with making adjustments from it.
you should check out the evga forum for info on the vdroop. the evga bios is not like other setups.
Yeah, I can! Since I'm testing it though and supposed to learn and be the expert on it, I may just play around with it. I've looked into it and worked with EVGA on it. I think normal believe it or not may be my best bet but I don't mind the voltage overshooting a little bit. I'm trying to get my voltage as static as possible to my manual input.
Jeffrey M Edson
post #13 of 17 (permalink) Old 03-03-2019, 06:54 PM
elmor's Avatar
Rep: 354 (Unique: 158)
I appreciate the way you received my feedback. Of course it's fine to say that you like the board and that it's the best you've tested.
elmor is offline
post #14 of 17 (permalink) Old 03-04-2019, 07:40 AM - Thread Starter
Jedson3614's Avatar
I appreciate the way you received my feedback. Of course, it's fine to say that you like the board and that it's the best you've tested.
When reviewing items you kind of have to accept constructive criticism. I don't mind when people have issues and they offer a solution or suggestions. It's when people complain but don't offer any value. That never helps the reviewer grow.
post #15 of 17 (permalink) Old 03-04-2019, 08:15 AM
tatmMRKIV's Avatar
Rep: 132 (Unique: 88)
elmor is an asus rep... I think he wants you to give the new apex some attention... Sadly the good asus OC boards aren't available in the US
I just mean on the forum someone, has gone through and found out what voltage ranges the LLC settings do. you should hunt for that...
really the LLC is the most difficult part of this board
(If y'all) ain’t ready for the old murder, then what you gonna do with the new me?
tatmMRKIV is offline
post #16 of 17 (permalink) Old 03-06-2019, 11:08 PM
Atlantida's Avatar
Rep: 9 (Unique: 9)
Great Guide. I was actually looking at this board and noticed the price. I think I'll just continue to look at it, until the price drops. I do appreciate their attention to simplicity and stability over bling and aesthetics, though I think this board looks amazing. But the price and availability is just too much.
Atlantida is offline
post #17 of 17 (permalink) Old 03-11-2019, 01:50 PM
FlanK3r's Avatar
Rep: 163 (Unique: 112)
Good article, nice to see Steponz guy in review
I like my Apex as enthusiast OC board. Only XP support ismissing on Apex XI (but could be added with unofficial BIOS?). But Dark is one of the best OC boards, thats true (in TOP5 for LGA1151)
Ryzen Threadripper TBD ,-), Ryzen Threadripper 1950X, Ryzen 7 2700X, Ryzen 5 2400G, Ryzen 7 1800X, Ryzen 7 1700X, Ryzen 5 1500X, Ryzen 5 1600X, FX-8320E, FX-8370, FX-8370E, 2x FX-9590, 4x AMD FX-8350, 2x FX-8320, 2xFX-8300, 4xAMD FX-8150, AMD FX-8120 95W, AMD FX-8120 125W, AMD Phenom II x6 1100T BE, AMD Phenom II x6 1090T BE 4.3 GHz stable, AMD Phenom II x 980 BE, Phenom II x4 975 BE,Phenom II x4 970 BE, 2x Phenom II x4 965 BE C3, Phenom II x4 965 BE C2, Athlon 860K, Athlon 845, A10-7870K, 2xA10-7850K, 2x A10-7700K, A10-6800K, A10-6800B, A8-6600K, A10-5800K, A8-5600K, A10-3870K, A8-3850, Athlon 5150 Kabini,Intel core i9-7900X, Intel core i7-6950X, Intel core i7-5960X, core i7-3930K, i7-980X,3x Intel core i7-8700K, i7-7700K,i3-7350K, 2x i7-6700K, i5-6600K, i7-4770K, i7-3770K, i7-2600K
AMD AIR cooling challenge Cinebench R10
FlanK3r is offline
You may not post new threads
