[OCN LABS] 280MM CPU Cooling Fight! Enermax Liqtech II 280 AIO vs Swiftech H240X2 Prestige (custom water) - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 03-13-2019, 05:31 AM - Thread Starter
I TeK things...
bluedevil's Avatar
I have been an avid watercooler for quite a while, something like 10 years or so...So when a claim comes out saying that a 280mm radiator can dissipate 500 watts, well I want to know how. I have seen thick radiators that can’t dissipate half that amount, so what does Enermax have in terms of special sauce?
Intro
Hey what’s up OCNers! Bluedevil here. AIOs are pretty much the golden standard when it comes to high end CPU coolers. Those whom would want more, will go for more exotic cooling, or go custom water and I just happen to have a Swiftech H240X2 Prestige, which is part custom water, part AIO. So my question is, can the Enermax Liqtech 2 280mm beat the Swiftech H240X2 Prestige?
Now the Enermax Liqtech 2 series is being marketed as high efficiency performance, namely claiming to be able to support 500w+ TDP. Having a patented Shunt Channel Technology, which boosts thermal conductivity and increases the heat exchange rate by 30%. The integrated EF1 pump, which boosts it’s 7 times more powerful than other traditional AIO pumps. Taking both the EF1 and the Shunt Channel Technology, this might be Enermax’s secret in able to cool such a high TDP.
Now what would be an AIO be today without aRGB? Well surprisingly enough, there is only one element of aRGB, on the EF1 pump/block. It’s subtle, yet tasteful at the same time. Controlling it is easy from your 5v 3 pin header on your motherboard or by using the included wired controller. Which enables you to control up to ten preferred lighting effects with colors, brightness, and speed. Personally, the included controller, is great for people that haven’t yet upgraded to a motherboard that has a 5v 3 pin header.
The new 140mm fans might also add to the secret sauce that Enermax has been brewing up as well. The innovative high pressure fan blades are more of a swept blade design rather than traditional fan blades, rated to provide 32 to 81 cfm of static pressure through the aluminum 280mm radiator. Speaking of radiator, the FPI, or Fins Per Inch, also might be another ingredient on why the 500W TDP is present. Having a high FPI increases surface area, effectively allowing for more cooling headroom, which the Liqtech 2 280mm has a very tight fin stack.
Ok, enough talky talky, let’s look at some numbers
My bench system is a Intel 8700K overclocked to 5ghz, on an Asus Z370 Maximus X Code motherboard, 16GB of DDR4-3000 from Team Group, and a Zotac GTX 1070 Ti Amp Extreme. Also being an AIO test, this was performed on an open air test bench, the Streacom BC1. Installation was pretty standard, so if you have installed an AIO liquid cooler before, the Liqtech 2 280mm is no different.
Temp test
DB sound test
Alright, in the world of AIO coolers, the Liqtech 2 280mm offers some of the best cooling available. Just looking at my test results, I would say that if anyone wants near custom WC, with pretty much the same temps and noise, well the Liqtech 2 280 might be your next AIO. At $150, the Liqtech 2 280mm starting to skirt the pricing of some custom kits, that offer much more expandability. Even at sub $150, the Corsair H115i is quite popular, and should offer comparable performance.
Pricing aside, the Liqtech 2 280mm AIO is really nice. The finishes like the heatsinks on the side of the radiator, the rubber dampeners on both sides of the fan mounts, everything just feels polished. This brings me back to my original question, can and does the Liqtech 2 280mm dissipate 500 watts? I wouldn’t think a 280 aluminum radiator can.
Downsides are pricing with a dash of an overzealous dissipation claim.
With that 4 out of 5 flames.
Ok guys, it’s been real, it’s been fun, it’s been real fun. If you haven’t liked and subscribed by now, you know what to do!
bluedevil out.
AMAZON
Liqtech II 240
https://www.amazon.com/Enermax-LIQTE...language=en_US
Liqtech II 280
Liqtech II 360
NEWEGG
Liqtech II 240
http://www.anrdoezrs.net/links/90136...-091-_-Product
Liqtech II 280
http://www.anrdoezrs.net/links/90136...-092-_-Product
Liqtech II 360
http://www.anrdoezrs.net/links/90136...-093-_-Product
Product Link
https://www.enermaxusa.com/product.p...egory=20957352
bluedevil is offline
post #2 of 9 (permalink) Old 04-10-2019, 02:13 AM
Loosing Vision
BinaryBummer's Avatar
Rep: 66 (Unique: 65)
I own a Enermax product (LEPA LC-240) and the cooler I had already posted why not to, or caution on buying.
First they are out marketing like all these days Boosting the product, but out of the box both time the one of the two cooling fans rattle horrendously and it is something they should check before packing or shipping for that matter. I don't enjoy expecting the product to be solid and it is faulty out of box.
The second thing is yes the unit lasted one month before the warranty was up. We relocated and after plugging up I was having issues with shutting down for no reason. Turns out the coolant had all but evaporated. After removing the unit shaking the radiator you could here very little coolant within.
After a rather hassle of a time trying to return they finally sent me a replacement unit, as I stated above out of box new wrapping defective fan. Don't get me wrong I do like the fan blade design but a bit more Q&A could prove better to the consumers.
As with any choice of AIO or Liquid Cooling do keep a factory or aftermarket CPU cooler on hand with extra Thermal Paste of choice.
Always have a backup. I not saying the units here are bad, I stating buyer beware as I found the elbows hoses from the block push pretty hard against my memory stick that places a lot of pressure on the mounting area. Again very thick hose as concept that it can maintain less chance of evaporation.
The product can work fine but Q&A should be a bit better, Some of these issue do not show till weeks or months of usage.
Enermax Support is rather shoddy to with all the requirement to take photos and removing this and that, only to get a refurbished unit with x2 new fans mounts and all.
Cheers!
BinaryBummer is offline
post #3 of 9 (permalink) Old 04-16-2019, 03:55 PM
External VRM FTW
mllrkllr88's Avatar
Nice work! The video quality, editing, and B-roll footage was high quality.
Some friendly criticism... Here you have a powerful AIO which apparently deigned to handle modern high-wattage HEDT CPU's, but you didn't evaluate it's lofty claims. The company touts the 500+ watt TDP as if it was hard earned, and looking at their website it's clear they quite proud of it. In my opinion you didn't do the product justice by testing with an 8700k, which has a stock TDP of 95w. Even overclocked to 5G as you have done, you wont be anywhere near where you need to be to adequately test the claims of this AIO. I suppose that would be like trying to do a review for the new XMP-4800 DDR4 memory modules on a midrange 4-dimm gaming motherboard.
Cheers
24/7 BENCH
(9 items)
[LGA115x] 8700k, 7700K, 7350k, G3258
[LGA2066] 7940X, 7740X
[OCF FTW] X299 OCF, Z170M OCF, Z97 OCF
E-Power, G-Power, H-Power, A-Power
B-DIE, HYKO, PSC, MFR
Seasonic Prime Platinum 1200W
Kingpin Cooling: Venom & T-REX
2x360 RAD Custom Loop
Dimastech Easy V3.0
mllrkllr88 is offline
post #4 of 9 (permalink) Old 04-16-2019, 04:13 PM - Thread Starter
I TeK things...
bluedevil's Avatar
Cheers [IMG class=inlineimg]/forum/images/smilies/thumb.gif[/IMG]
Thank you for your appreciation to how hard the video work is.
Like I said on YT, I don't have a HEDT chip atm. I test with what I got. And no I am not sending it to you.
post #5 of 9 (permalink) Old 04-20-2019, 08:27 PM
Hardware Maniac
bonami2's Avatar
Rep: 54 (Unique: 41)
They cooled fx 9590 with h100i back in the days..
Watercooler are just overated the 5 years old 280mm perform the same as a new one almost.
I wonder who build this one ? Is it asetek ?
bonami2 is offline
post #6 of 9 (permalink) Old 04-27-2019, 05:44 AM
Desolutional's Avatar
Rep: 165 (Unique: 101)
There is only so much you can improve a simple concept before you hit a brick wall. Watercooling simply moves the heat soak source from one location to another. When both an air cooler and water cooler are run under steady state conditions, it is the cooler with better thermal transfer and heat sink cooling that wins. Watercooling definitely has its uses, but like for like, assuming both coolers are as efficient as each other, the benefits of water cooling is: less lateral force on mobo CPU socket, more room for high profile DIMMs and more room to change PCIe devices.
CPU: i7-6950X @ 4.1Ghz (-0.08V/1.30V Adaptive = 1.22V); Cache: 3.2GHz (1.07V); VCCIN: 1.90V @ LLC 5 12hr AVX2 Stable
RAM: 64GB @ 3000MHz (14-14-12-31 1T, 1.35V) 12hr GSAT Stable
GPU: EVGA Hybrid GTX 1070 @ 2076MHz Core, 8.6GHz VRAM, Stock Voltage 24hr [email protected] Stable
Desolutional is offline
post #7 of 9 (permalink) Old 04-28-2019, 02:07 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1408 (Unique: 724)
kind of a blanket statement. unless you have an oddball and/or ITX motherboard, no heatsink should block a PCI-E slot. and there are plenty of good coolers (ala Le Grand Macho RT) that can accommodate DIMMs ∞ tall.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
The Pook is online now
post #8 of 9 (permalink) Old 05-03-2019, 07:58 AM
Venomal1c3's Avatar
Rep: 0
Cheers!
I have an Enermax Liqmax II 120S & one of the factory fans actually leaks oil! Not a ton, but it is noticeable. I had to have my wife confirm I wasn't crazy & just seeing things. I contacted Enermax about it, they suggested I detach the fan blades (btw, probably the greatest innovation to fans besides the "Fluid" or "Hydro" updated bearing designs) & reattach them after a minute or so. I guess to ensure it was correctly seated or something. They also told me if that didn't solve the problem to contact them & provide more information & pictures of the fan & serial numbers & whatnot, so they could open up a ticket for a warranty RMA.
I did as suggested in regards to the fan, making sure to clean the blades & frame thoroughly before mounting back on the rad, something that Enermax hadn't suggested I do. Well, it took about a week before I started to see the tell tale sign of the bearing weeping oil: a darkening of the back of the blades more prominent at the bottom of the blades, & a clearly visible ring of what would appear to be moisture (gee, I wonder why? ) all the way around the inside of the frame. I was checking it every time I shut down my rig, I'd shine my Fenix flashlight into the side window of my case & inspect the fan.
Now I have to dig up the email & the pics I took so I can have it fixed/replaced while it's still under warranty. It wasn't affecting the performance YET, but eventually it will. I have another fan, also an Enermax, a Vegas LED fan, in the defective one's place for now. Looks cooler, doesn't sling droplets of oil around, but it is more audible & lacks rubber on the corners to reduce vibration. Also, they aren't the Batwing design, so the static pressure isn't as good & it's the push fan, of course. I did have a Fractal Design Venturi HP-12 PWM fan in its place for a while, excellent fan, very quiet, & only maybe a degree or two warmer temps overall. Overall, the AIO is not bad, I probably should have gone for the 240, but it didn't seem like there would be enough clearance between the mobo & case since the best option in the current setup is as an exhaust.
Would I buy another Enermax/Lepa AIO? Probably not. I do, however, like their fans & I feel they fall somewhere between "good" & borderline "great" depending on the particular model & if it works flawlessly. That detachable blade thing is tits, though! I have 3 other fans with that feature, one of which is a front intake & therefore gets de bladed at least once a month & sometimes more. Still quietly spinning & looking cool (LED model) & much quieter than the Corsair fan beneath it/farther away from me. It's been there for about 2 years. I've not had any problems with it or the other fan
Oh, my backup is a Cooler Master Hyper 212 Evo. I'd likely put the Fractal fan mentioned above on it as I've done in the past, because it's way quieter than the stock CM fan.
Venomal1c3 is offline
post #9 of 9 (permalink) Old 05-03-2019, 12:01 PM
Martin778's Avatar
Rep: 17 (Unique: 17)
Well, for just a bit more you can grab yourself a 360mm Kraken or H150i from Corsair...
I think the Swiftech performs really poor for a 'just-not' a custom LC loop and for a product from a company like Switftech. Same for the EK AiO products, I've seen the reviews and could not understand how a kit with EK Supremacy block, DDC pomp and thicc hoses couldn't perform any better than a plasticky Asetek Kraken or EVGA CLC thingy.
Threadripper 3960X PBO | Aorus TRX40 Xtreme | Enermax Liqtech II 360 TR4 + EK Clear flush + 3x Noctua A12x25 | 4x8GB G.Skill TridentZ Royal Gold @ 3733 CL16 | EVGA Kingpin 2080Ti @ 2100MHz + Noctua A12-25 | 4x1TB 970 PRO raid0 | Corsair MP600 2TB | Seasonic Prime Platinum 1300W | In Win D-Frame 2.0 Gold | ASUS PG349Q
Martin778 is offline
You may not post new threads
