[OCN LABS] BE QUIET! DARK BASE PRO 900 ORANGE rev. 2 - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 04-10-2019, 10:13 AM - Thread Starter
I TeK things...
bluedevil's Avatar
Rep: 646 (Unique: 436)
Shhhh be quiet! That’s the company name and premise. bequiet!. Today we are gonna look at the bequiet! Dark Base Pro 900 rev2. Fair warning, there is A LOT of screwing involved.
Now bequiet! being a German company, tries to stick to its name. With more than 15 years of noise reduction and silence, bequiet! arguably makes the most silence based PC components on the market. bequiet’s own Silent Wings and Pure Wings 2 fans are put in a wide variety of bequiet’s own product lines due to their superb quality and silence.
So where do I start with the Dark Base Pro 900 rev2 from bequiet! ? Do I start with the three position motherboard tray? Yeah let’s get started there. So a motherboard tray that has three different heights to let the end user configure the Dark Base Pro 900 rev2 to what they what, not being confined to a set configuration. Did I mention that you could invert the motherboard orientation as well? Yeah this is something that I have been searching for ever since my days of the Lian Li PC-A05N. Inverted designs aren’t really a new thing, but a case that is orientated in the traditional mounting then inverted in a matter of minutes, is really a thing of good engineering. However the Dark Base Pro 900 rev2 does have its shortcomings with this idea. To invert the motherboard, one must take out 20 plus screws to accomplish this task. That’s a lot of screwing, although I did warn you. So when I built in the Dark Base Pro 900 rev2, it was the inverted configuration, mostly due to other reviewers not actually doing that for their review. To me, it’s one of the main reasons why the Dark Base Pro 900 series is to be. Rev2 pretty much added a tempered glass side panel, a full PSU shroud, a Qi charger on the top, and a USB 3.1 Type C Gen 2 connection in the front IO. Speaking of the front IO, there are two USB 3.0 type a ports, headphone and mic jacks, a very large power button, an RGB button, which is very hard to press in, I really suggest if you can, run your RGB lights from your motherboard’s lighting software. I actually can’t push it all the way in to change the lighting with my fingers, I had to use a pen tip instead. Also included are two hard PCB RGB strips that can be used with other RGB components. Next to the RGB button, is a hard drive activity light, further on is a single USB type C Gen 2 port along with a fast charge type a port.
Moving down the Dark Base Pro 900 rev2 is the sound dampened brushed aluminium plastic door. This door can be switched around to swing from the other side if need be. Nice touch, it seems that this attention to detail is often overlooked in other manufacturers. Behind the door, is a stepless fan controller, which is pretty discrete, but functional. Moving down is the first of three fan filters. This one is optimized for the 2 included Silentwings 3 140mm fans that are included in the front. This fan filter is easy to take out and clean as I would expect in a case valued at $270. On the bottom of the front of the Dark Base Pro 900 rev2, is the second fan filter, spanning the entire length of the case. Note if you try and take the front panel off without taking this filter out first, you will take it with you. Moving inside, you are greeted by another new addition, the full length PSU shroud. I for one like seeing PSU shrouds. It really does make for a nicer, cleaner, looking build, without having to look at a cable mess. The PSU shroud even has a place to put your fancy RGB SSD right in the limelight for everyone to see. There is even a spot to mount a single 120mm fan, although I don’t see this making much use, but hey it’s there. However with water-cooling in mind, this PSU shroud can be popped out in places to make room for bigger radiators, like a 420mm radiator in front and in the roof. Radiator thickness for the front is limited to and the roof is limited to. Normally one would want to install the PSU last, but with the Dark Base Pro 900 V2s PSU shroud, it’s easier to start with the PSU installation first. Installing the PSU is slightly cumbersome, but mostly due to the use of the AC extension cable that bequiet! decided to use. Also in play is the two vent extensions that are used to help move the motherboard tray away or closer to the PSU shroud when installing radiators or other cooling solutions.
Moving up into the main compartment, is the ingenious removable motherboard tray. Again I have opted to go the inverted route with the CPU at the bottom close to the PSU shroud. The inverted design allows for a beefy GPU like my Zotac GTX 1070 Ti AMP Extreme! Edition, which is a 2 and half slot GPU. Normally mounted, this guy sags like a mofo. Inverted, just a little bit. In the roof, is the Enermax Liqtech 2 280mm AIO, you can check that review out here. On the mounting side of the motherboard tray, you get the typical 8 slots for PCIe expansion cards, noting the compatibility with EATX motherboards all the way down to mITX motherboards. Another Silentwings 3 140mm fan is set to exhaust, making the total included case fans to 3. On side of the motherboard tray are three rubber grommets, the color of the grommets will be determined by the external color choice of orange, black, or silver. Moving to the rear panel, which has a bump out to allow for more air to pass through with a filter in place as well as more sound dampening. Looking at cable management and drive installation, is well interesting. Putting the back panel back on yielded to be slightly more difficult loaded than unloaded. A hinged side panel system like that of some Corsair, Fractal Design cases or even bequiet’s own Silent Base 801, would have been a good improvement to bequiet!s highest ended case, especially at the $270 price point. Moving to drive installation, a single 2.5” SSD/hard drive mount is located behind the motherboard tray, held in by a single thumb screw, as well as a glamor 2.5” mounting location on top of the PSU shroud. Included for 3.5” hard drive installation, are 3 hard drive enclosures that hold a single 3.5” hard drive or 2 2.5” hard drives or SSDs, which are held in by, you guessed it, thumb screws. In the basement of the Dark Base Pro 900 V2 is a dual 3.5” enclosure that can house obviously 2 3.5” hard drives or 2 2.5” hard drives or SSDs. Note this enclosure can be removed to make room for fatter radiators for water cooling. The dual 3.5” enclosure also can be relocated where the 5.25” bays are located.
Overall my impressions of the Dark Base Pro 900 V2 are quite good. While the case in its own right is made to be more on the silent side, is not exactly silent. The three Silentwings 3 140mm fans when cranked to the max 1600 RPM, are the culprits to blame for the added noise. So when testing the Dark Base Pro 900 V2, I wanted to compare sound noise with temperatures, since this is a silence focused case. Here are four clips showing the two tests.
5 seconds slide showing tests DB and C IDLE Silent
5 seconds slide showing tests DB and C LOAD Silent
5 seconds slide showing tests DB and C IDLE Performance
5 seconds slide showing tests DB and C LOAD Performance
So I guess the question that’s burning in my mind is, at $270, the Dark Base Pro 900 v2 is about $100 more expensive than cases like Lian Li’s PC-011 Dynamic, and the Cooler Master H500P Mesh, see that review here. Even compared against the Silent Base 801 from bequiet! it's hard to justify the additional $100. Being priced at $229 would have sealed the deal for the additional features like the Qi charger and the USB 3.1 Type C Gen 2 connection.
That said, the Dark Base Pro 900 Rev2 gets a very solid 4 out of 5 flames.
Ok guys, If you haven’t liked and subscribed by now, you know what to do! I will see you in the next one!
bluedevil out
Product page
https://www.bequiet.com/en/case/1472
Newegg
https://www.newegg.com/Product/Produ...rclock-bequiet
CLICK TO SUPPORT THE OVERCLOCK YOUTUBE CHANNEL!
bluedevil is offline
post #2 of 11 (permalink) Old 05-13-2019, 03:13 PM
Alex132's Avatar
Rep: 342 (Unique: 274)
Did you just copy paste your review script verbatim?
| This Cannot Continue | We Are Become As Gods | This Cannot Continue |
Vehicles:
Current: None.
Ex: '07 Fiat Palio, '07 Honda Accord Type-S
Illya
(26 items)
Yuki
(23 items)
Intel i9 9900K @ 5.2Ghz
Gigabyte Aorus Master
EVGA 1080 Ti FTW3
G.Skill Trident Z 32GB 4000Mhz
Samsung 970 Pro 512GB
Samsung 850 Evo 1TB
WD Red 8TB
Seasonic Prime Titanium 850W
EK Velocity CPU Block
EK 1080 Ti FTW3 GPU Block
HardwareLabs GTX420
HardwareLabs GTS280
HardwareLabs GTS140
EK D5 140 Glass Pump/res
Phanteks Evolv X
Operating System
Windows 10 Pro
Asus ROG Swift PG279Q 165Hz 1440p
I-INC 1920x1200 TN 27"
Keyboard
Ducky One 2 Midnight
Mouse
Logitech G502
Mousepad
CoolerMaster Swift-RX XL
Audio
Sennhesier HD650
Audio
Schiit Jotunheim Amp/DAC
Audio
Samson C01U Microphone
Audio
Edifier R1700BT
Other
Oculus Rift
Intel 2500K 5Ghz
ASUS P8P67 Pro
EVGA 1080 Ti FTW3
G.Skill RipJaws X 2133Mhz 16GB
120GB Corsair Neutron GTX
Samsung 850 Evo 1TB
WD Red 8TB
EVGA G3 850W
Hyper 212
EK Vardar fans
Corsair 270R w/TG mod
Operating System
Windows 10
I-Inc 1200p
Keyboard
Razer BlackWidow 2013
Mouse
Logitech G502 Proteus Spectrum
Mousepad
Audio
Sennheiser HD650
Audio
Schiit Jotunheim Balanced DAC + Amp
Audio
Edifier R1700BT Speakers
Audio
Other
Oculus Rift
Other
PS4 Controller
Alex132 is offline
post #3 of 11 (permalink) Old 05-13-2019, 03:39 PM - Thread Starter
I TeK things...
bluedevil's Avatar
why what's the issue with that?
post #4 of 11 (permalink) Old 05-17-2019, 12:41 PM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
People like to complain...
Would be interesting to see a comparison with other silent oriented cases such as the Fractal Design Define S2 or Phanteks Eclipse P600S as those cost much less
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #5 of 11 (permalink) Old 05-17-2019, 02:39 PM - Thread Starter
I TeK things...
bluedevil's Avatar
I will see what I can do sir! I would like to see that comparison as well!
post #6 of 11 (permalink) Old 05-21-2019, 11:39 AM
Just living in a van...
technodanvan's Avatar
Rep: 124 (Unique: 100)
While I agree this case could probably be a little less expensive, if it's anything like the thought put into their fans and heatsinks it's probably well worth it. I really don't see how a comparison could be made to either the Lian Li PC-011 or the Cooler Master H500 Mesh though. They're big cases, but to me that's about where the comparison stops.
I've been eyeing this case for a while and am thinking of doing a Threadripper build in her. With the exception of somewhat constricted airflow compared to some 'open' cases, I think this has to be one of the best-featured full-sized cases I've seen in quite some time.
technodanvan is offline
post #7 of 11 (permalink) Old 05-21-2019, 12:48 PM - Thread Starter
I TeK things...
bluedevil's Avatar
Don't get me wrong, it's a great case. But like I said, it's a touch overpriced and I wish the side panels went on easier.
post #8 of 11 (permalink) Old 05-21-2019, 01:19 PM
I can count to potato
Fluxmaven's Avatar
Rep: 56 (Unique: 24)
Really is a sweet case. I feel like they should drop the price a bit and make the Rev. 2 white edition. While it appears to be a high quality case, it's not special enough to be so close to the $300 price point.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
64GB TridentZ 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #9 of 11 (permalink) Old 05-21-2019, 03:19 PM
The side panels thing is a might bit irritating, given it's 2019 and we've struggled with terrible designs for decades. One would think they could see what works in other cases and adapt to that. I guess I'm at the point that, once a computer is working, it's probably staying closed for a few years. So I guess that's not a 'huge' discouragement for me. I can see how that might impact others a lot more though.
As much as I'm anxious to start buying parts, I figure I'll wait until during or after Computex, just in case they have a new revision or sales due to other products. I'm curious though, what cases at the $300 price point are really worth it nowadays? This is coming from someone who currently has a Caselabs case, and has used several Lian Li and Silverstone cases over the years that have been around that price point. As much as I'd like BeQuiet to use a solid brick of aluminum or steel, it's becoming less and less viable due to costs, and plastics are generally getting better.
post #10 of 11 (permalink) Old 05-22-2019, 11:42 AM
Fluxmaven's Avatar
There just aren't a lot of good full tower case options these days. Nearly everything is mid tower. Now that Caselabs is gone, there really isn't much in the super tower form factor either. I'm not a huge fan of the tempered glass trend. Especially when it's a solid panel on the front forcing air to flow through narrow openings along the sides. Slapping a tempered glass panel onto a flimsy thin steel and plastic case doesn't make it premium.
I do recognize that the price of materials is going up, so for BeQuiet to make this same case completely out of aluminum, it would probably push it well out of budget for most people. I don't know what the answer is, I just don't see a lot in the case market they really blows me away currently.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
GTX 1080 FE
WD Black SN750
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Keyboard
Mouse
Glorious Model O
Mousepad
Audio
Audio
Focusrite 2i4 Gen2
Audio
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
WD Blue 3D m.2
Corsair AX760
InWin D-Frame Mini
i7 6700
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
You may not post new threads
