[OCN LABS] First Build of 2020! The Vulcan Build Ft Team Group T-Force Vulcan SSD and Vulcan Z DDR4 - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 01-30-2020, 07:24 AM - Thread Starter
I TeK things...
bluedevil's Avatar
Hello good people of Overclock, I am bluedevil. Meet the Vulcan build, my first build of 2020. This PC build was inspired by all the grey components, giving it kinda a volcanic look. Housed in the BeQuiet! Pure Base 500, which mind you has a new version that was announced at CES called the Pure Base 500DX, providing power is the Silverstone SX700-G SFX PSU, with memory and an SSD from T-Force, subsequently the DDR4 is named Vulcan Z, and the SSD, Vulcan. Also present is my older but fully capable Asus Z370 Maximus Code X motherboard, with my 8700K, cooled by a DeepCool Castle 240EX. Handling graphics, is a Nvidia RTX 2080 Super founders edition. So why don’t I get my build on, as well as some benchmarks.
So a few things to get out of the way, does the Pure Base 500 really support 3 140mm fans in the front. No it’s not officially supported, but I did manage to fit 3 Silent Wings 3 140mm fans, really supporting 2 140mm fans or 3 120mm fans with supporting radiators.
Alight OCNer's I hope you enjoyed the Vulcan build, I know I love how it came out. Thanks again to BeQuiet!, Team Group and Silverstone for supplying the parts. If you could drop a like and a sub, it’s much appreciated!
bluedevil out.
Oh I almost forgot, ratings.
Airflow was a slight issue, temps slightly higher than anticipated. Same BeQuiet features, smaller package. Great case for the money!
Silverstone SX700-G
Great SFX PSU, if using cable extensions, cables are perfect lengths.
Low key, straight to the point SATA SSD.
Team Group T-Force Vulcan Z DDR4-3200
Low profile DDR4 ram that fits into just about any build.
bluedevil is offline
post #2 of 5 (permalink) Old 02-02-2020, 10:29 PM
AMD K6-2 500MHz
neurotix's Avatar
Rep: 341 (Unique: 196)
Looks great dude. I just rebuilt mine too. Would love some feedback, I did a full build log here and it hasn't gotten much of any replies If you click Pics in my sig it'll go right to the build process pictures
I would've liked to see more of the cable management process + rear panel after full cable managing, maybe next time, or you can post a photo. Either way it looks great and the case was a nice choice, as it matches the "tactical" esque dark green-gray of the board and the cooler. I went for a powder coated dark gray and chrome for mine which matched my board well
Anyway, good work, greetings from the Badger State too
Ryzen 9 3900X @ 4.5GHz CCD0 1.375v VID OC, 4.2GHz CCD1- 1900Mhz fclk/uclk
ASUS ROG Crosshair VIII Hero BIOS 1201
EVGA GTX 1080ti FTW3 2025/5940MHz
EVGA RGB SLI HB Bridge
G.SKILL Flare X B-Die 3200 C14 @ 3800MHz C14-16-15-15-30-48 1T 1.475v GDM off
Samsung 970 Evo 500GB m.2 2280 PCI-E NVMe SSD
WD Black 2TB
WD Blue 4TB
WD Blue 6TB
Samsung 840 Evo SATA 256GB
COOLERMASTER V1000 (Seasonic 1000w 80+ Gold)
Arctic Cooling Liquid Freezer II 38mm 360mm AIO
Anidées AI-AUREOLA RGB fans x7
Prolimatech PK-3 Nano 30g tube
Anidées AI CRYSTAL AR3 RGB Midtower
Operating System
Debian Linux 10
Operating System
Win10 X64 Pro 1903 (gaming only), stripped down, updates blocked, Firewalled.
LG 34WN80C 34" 3440x1440 21:9 IPS, 300 nit, HDR
Keyboard
GMMK v2 104 key | Kailh Box Jades | HyperX PBT pudding (for now)
Keyboard
OCN Ducky DK1008 MX Blues
Keyboard
Corsair K70 Lux red led/MX Reds
Keyboard
Rosewill K85 RGB Kailh/Kaihua Blue switches
Keyboard
Ducky One 2 RGB fullsize
Mouse
Redragon Chroma M710 RGB (Omron Switches)
Mousepad
Corsair Polaris RGB
Audio
Logitech G230 red
Audio
Logitech Z2300 2.1 120w 8" sub, w/ 40w satellites
Other
Phanteks RGB 5050/Digital RGB strips
Other
Respawn Black/Gray Racing Chair
Raspberry Pi 3B
Optical Drive
DENON DCD-560 CD Player, dual integrated 20bit Burr Brown PCM61P DAC's
Operating System
Kodi 17.2
ASUS V238H 23" 1080p 60 Hz
Audio
Pioneer SX-255R Receiver, 4x 100w
Audio
TECHNICS SB-A32 Floor Standers, 4x8" polyurethane woofers, 100w/cabinet, 1" His and 3" Midrange
Audio
Polk Audio PSW-505 300w subwoofer, replaced woofer with CT SOUNDS TROPO 12" 4Ω DVC car sub wired in series, 8Ω, 300w
Audio
Kenwood GE-4030 Stereo Graphic Equalizer
Audio
TECHNICS RS-T18 dual tape deck
Motorola 68000 @ 7.8MHz
Macintosh SE logic board
Macintosh SE analog board (provides voltage + timing to CRT)
None. Graphics generated by ROM, OS and 68k (sans fpu)
NEC Electronics 80ns 9-chip 1MB SIMMs (four, 4MB total RAM)
FloppyEmu Ver C in clear case, front-mounted, 500MB HFS .dsk file
Optical Drive
Sony 800KB Double-Sided floppy disk drive. Cleaned and relubricated
stock, 75W
Single fan. Very small. (25mm?)
Cage in the case itself provides convection cooling.
Macintosh SE, platinum color, Snow White design language
Operating System
System Software 6.0.8 w/ Multifinder
Operating System
System Software 7.1 (rarely used; needed for Macintalk 2 speech synthesis)
9" 1-bit (black and white) CRT, 512x342, 58Hz
Keyboard
Apple Desktop Bus Keyboard 1 (cleaned and restored.)
Mouse
Apple Desktop Bus Mouse 1 (cleaned)
Audio
Mono Speaker
Other
"Macintosh Toolbox" 128Kb ROM chip- accelerates OS/System calls
Other
Replaced soldered 3.6V PRAM battery liable to explode/leak w/ 3V lithium coin cell meant for Gameboy games.
neurotix is offline
post #3 of 5 (permalink) Old 02-03-2020, 05:51 AM - Thread Starter
I TeK things...
bluedevil's Avatar
I actually have a little snippet of that. Sorry it didn't make it into the video.
post #4 of 5 (permalink) Old 02-03-2020, 09:51 AM
AMD K6-2 500MHz
neurotix's Avatar
It looks good. Using sleeved extensions myself in my last build, and having used them for years (including from Bitfenix and TTMods/Thermaltake) I know how rigid they are.
If you feel open to suggestions or improving it- maybe you know this already- there's a little vertical groove on the left side of that photo, where you put your PCI-E extensions through at the bottom. This is a cable management groove and maybe you'd notice that its about the thickness of the stock psu 24-pin connector lead. Ideally you would want to route that into that groove going up and anything else that can be (for example, take your pci-extensions out and off then run the pci-e cables from the psu into this groove, fold them down on themselves and tuck them into the groove, then attach your extensions and run them the same way. Do this for as many wires as you can)... if that makes sense. The way you ran all the wires up already looks really good, if you undo the nylon velcro cable ties and move all those vertical runs of cables over to the left and into the groove it'll look even cleaner.
My case has a similar cable management groove and it really is a pretty great innovation in case design recently. Though with 3 hdds, a SSD, 2 GPUs that each require 2 8 pin, my motherboard requiring both 4 pin ATX and 8 pin EPS power connectors, etc it didn't help much
Also I realize why that 24 pin is like that, to keep it flat where it connects to the extension, to be able to put the panel on.
Anyway there's my two cents on the cables and it looking great from the visible side matters more than the back that only you will ever see Don't take my criticism seriously but I wondered if maybe you knew the purpose of the cable management groove.
WD Black 2TB
WD Blue 4TB
WD Blue 6TB
Operating System
Debian Linux 10
Operating System
Keyboard
Keyboard
Keyboard
Keyboard
Keyboard
Mouse
Mousepad
Corsair Polaris RGB
Audio
Logitech G230 red
Audio
Other
Other
Raspberry Pi 3B
Optical Drive
Operating System
Kodi 17.2
Audio
Audio
Audio
Audio
Audio
Optical Drive
stock, 75W
Operating System
Operating System
Keyboard
Mouse
Audio
Mono Speaker
Other
Other
neurotix is offline
post #5 of 5 (permalink) Old 02-03-2020, 04:09 PM - Thread Starter
I TeK things...
bluedevil's Avatar
Yeah I seen that cable groove there. I have used them in the past, which I will be doing for an upcoming case review (which is under NDA).
You may not post new threads
