[BUILD LOG] BH8 Green Lantern Rebuild - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 10-11-2017, 11:31 PM - Thread Starter
WaterCooler
Deedaz's Avatar
Rep: 88 (Unique: 72)
Finally got the BH8 today so I'll be moving the green lantern build out of the S8. This will be the third case this build has seen lol. The plan is to put a 240 xflow rad up top and move the white rad from the S8 to the front of the BH8. There should be just enough room...if I measured right tongue.gif
Here's some case pics for ya. I also grabbed a set of case feet from primochill when I got the fittings/rad for the purple build. They aren't quite as big as I had hoped, but they look pretty good.
Deedaz is offline
post #2 of 13 (permalink) Old 10-12-2017, 10:20 AM
mumford's Avatar
Rep: 7 (Unique: 6)
mumford is offline
post #3 of 13 (permalink) Old 10-12-2017, 01:04 PM
Linux Lobbyist
AngryGoldfish's Avatar
Rep: 68 (Unique: 49)
Subbed. I wanted this case.
AngryGoldfish is offline
post #4 of 13 (permalink) Old 10-12-2017, 05:51 PM - Thread Starter
WaterCooler
Deedaz's Avatar
Well I'm not going to be able to use both rads after all. Just not enough clearance to mount them top/front like I wanted. I could put one on the bottom of the case, but there's a lot less airflow down there. Here's a few pics, just need to do a few tube runs and put another fan or two in.
Deedaz is offline
post #5 of 13 (permalink) Old 10-12-2017, 09:48 PM - Thread Starter
WaterCooler
Deedaz's Avatar
Final pics time! I may add some kind of lighting to it in the future but I'm not sure if I want to go UV or just white light. Besides, it's a real pain to get that shell off tongue.gif
Deedaz is offline
post #6 of 13 (permalink) Old 10-13-2017, 04:50 PM - Thread Starter
WaterCooler
Deedaz's Avatar
Deedaz is offline
post #7 of 13 (permalink) Old 10-14-2017, 04:59 AM
Linux Lobbyist
Yeah, that's a perfect level of light.
post #8 of 13 (permalink) Old 10-26-2017, 01:20 PM
EKWB Forum Rep
EKJake's Avatar
Rep: 18 (Unique: 12)
EKWB Forum Rep
EKJake is offline
post #9 of 13 (permalink) Old 04-05-2018, 02:41 AM
superpapu's Avatar
Rep: 0
How did you mount the pump combo over the radiator? and which pump combo is that? Awesome job.
Thanks
superpapu is offline
post #10 of 13 (permalink) Old 04-05-2018, 03:34 AM
skline00's Avatar
Rep: 14 (Unique: 12)
Stellar job on your BH8!
9900k-Kraken X72|Asrock Z390 Taichi|16g-3200 FlareX|EVGA GTX2080TI BE| Corsair MP500-480g|EVGA 850W|Thermaltake V51|Acer ET430k|Win10-64 home
5960x-4.4-EK WB|AsusRE5|16g DDR4-2400|Gigabyte GTX1080TI WB |2-500gb ssds|Win10-64|PC P&C 1200W|Thrmltake X9|3 XSPC RX480 |Dell UM3514W | Win 10-64 home
2700x stock H100i v2 240 AIO|Gigabyte 470|16g-3200 Flare-X|Zotac GTX1080FE|3-500g ssds|Antec 750W|Crsr 100R|BenQ3200+Oculus Rift
skline00 is offline
