Looking for SMA8(A) Replacement Parts - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 08-11-2018, 01:27 AM - Thread Starter
Linux Lobbyist
yemodin's Avatar
Rep: 0
Arrow Looking for SMA8(A) Replacement Parts
Any chances to buy some replacement parts, from stock if any presented directly from CL? Probably someone have extra spare part?
I'm personally looking for:
SMA8-A motherboard tray backplate (with handles) (http://www.caselabs-store.com/magnum...ricing-varies/)
SMA8-A PCIE backplate with 2 slots(http://www.caselabs-store.com/magnum...ricing-varies/)
SMA8-A PCIE backplate with 5 slots(http://www.caselabs-store.com/magnum...ricing-varies/)
2 X SMA8-A Reservoir mounts (double ones for SMA8-A, no link on website)
Single Wide MAGNUM SSD Mount (http://www.caselabs-store.com/single...num-ssd-mount/)
All in gunmetal color.
yemodin is offline
post #2 of 18 (permalink) Old 08-11-2018, 10:21 AM
Piopi's Avatar
Rep: 0
Yes, I also need the following items:
1. M8 / SMA8 / SMA8-A Standard 8 Slot PCIE Backplate with 2 slot adapter opening and cover plate (http://www.caselabs-store.com/magnum...ricing-varies/)
2. 20cm black riser cable
3. PSU Support Mount - MAGNUM (SKU 600123) - any color
4. SMA8-A Motherboard Chamber LED Light Strip Kit (http://www.caselabs-store.com/sma8-a...ght-strip-kit/)
Piopi is offline
post #3 of 18 (permalink) Old 08-11-2018, 10:52 AM
Rep: 0
best i can say is look at bestcases.eu I ordered parts last night less than 100 euro was decent shipping
Nuc1ear_F1ame is offline
post #4 of 18 (permalink) Old 08-11-2018, 11:45 AM
emsj86's Avatar
Rep: 83 (Unique: 65)
buy them fast caselabs went out of business yesterday
emsj86 is offline
post #5 of 18 (permalink) Old 08-11-2018, 12:29 PM
Piopi's Avatar
Rep: 0
M8 / SMA8 / SMA8-A Standard 8 Slot PCIE Backplate with 2 slot adapter opening and cover plate - you can link to this spare part?
Is this the right part - https://www.bestcases.eu/accessories...th-riser-cable
Piopi is offline
post #6 of 18 (permalink) Old 08-11-2018, 10:56 PM - Thread Starter
Linux Lobbyist
yemodin's Avatar
Rep: 0
Here answer from CL stuff: "I don't have any details, but there have been rumors of a retailer buying up our inventory and selling online."
yemodin is offline
post #7 of 18 (permalink) Old 08-12-2018, 11:25 AM
rioja's Avatar
Rep: 5 (Unique: 4)
Please where can I get it in gunmetal?
Any idea?
6850K | R5E10 | 4x16Gb Dom Plats | 960 PRO 1Tb | 1600T2 | SMA8 | 2x560+2x280 Nemesis GTX
rioja is offline
post #8 of 18 (permalink) Old 08-12-2018, 01:54 PM
Piopi's Avatar
Rep: 0
Exclamation HELP
Who can tell where to get this part?
SMA8-A standard 8 Slot PCIE Backplate with 2 slot adapter opening and cover plate
Piopi is offline
post #9 of 18 (permalink) Old 08-12-2018, 02:28 PM - Thread Starter
Linux Lobbyist
yemodin's Avatar
Rep: 0
I see only 3 options:
1. Wait till some store will buy whole inventory from CL and try to grab parts needed.
2. Try to order this one from bestcases(https://www.bestcases.eu/magnum-2-sl...ser%20cable%20) but ask in comment to order to get not only adapter but also PCIE backplate, better to do it before hand using contact form or direct email. (they usually respond quickly)
3. Buy 5 vertical slot PCIE from bestcases(https://www.bestcases.eu/magnum-vert...%20GPU%20brace), make sure you purchase pci-e riser cables separately.
One extra advise on bestcases: please check shipping cost before placing order, for some countries it's more cost effective to use mail forwarder instead.
yemodin is offline
post #10 of 18 (permalink) Old 08-13-2018, 07:42 AM
Linux Lobbyist
alaindesjardins's Avatar
Rep: 0
I was told the same, but, WHAT retailer? I need SSI-EEB tray for my Mercury S8 along with the SSI-EEB Stealth Mount. I could use a few flex bay accessories, maybe a HDD mount with cages or two to ensure I have enough in the future.
PLEASE someone post if you know where the extra inventory went so I can grab what I need now before prices are ridiculous.
EDIT: I have an extra stealth mount that is painted black that I received with my Mercury S8 if anyone needs it. Just throwing it out there in case someone is desperate.
alaindesjardins is offline
