HELP How to Repair Shorted CPU Fan Header. - Overclock.net - An Overclocking Community
post #1 of 1 (permalink) Old 04-08-2020, 10:46 PM - Thread Starter
Rep: 0
I shorted my CPU Header 4 pin. (Here what I do check it using multi-meter and 2 pin got to my multi meter and short it.) Now this 4 pin is not working anymore.
I troubleshot it. here what I do. I Check the Mosfet but I dont know if the Mosfet is good or bad. Check Picture Attached.
I check the CPU Fan Header again with multi-meter, ground is working. 12v is showing 10-12v when not in use. But when I use it or put some load in 12v I got a reading of 1.9v only.
Any one know how to repair it?? Kinda annoying I am now using the sysfan 2 with 4 fin to connect my CPU FAN and control it.
But I want to fix or repair this CPU Fan Header. MY motherboard is
https://www.msi.com/Motherboard/supp...5M-P33-V2.html
DIY MASTER is offline
Tags
4 pin , broken cpu fan , Cpu Fan , header , shorted
