Lamptron FC8 Controller modification - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 08-06-2015, 11:27 AM - Thread Starter
AlienPrime173's Avatar
Rep: 15 (Unique: 14)
Planning on running about 9.2A @ 12v through this controller. I know molex pins can carry 11A @ 12v.
OEM recommends using all three Molex. I'm guessing this is for amperage separation?
I was going to cut extras off, run single pin into female, heatshrink the connection for power and ground then sleeve the entire thing without plastic connectors through a small hole in my case.
This is what i have loaded on the controller
7 x Koolance @ 0.75A each (5.25A) 4 channels
2 x Scythe @ 0.53A each (1.06A) 1 channel
4 x Custom LED strips (2.00A) 2 channels
1 x Temperature Monitor (0.85A) 1 channel
Total (9.16A)
Thoughts? Thank you!
"The more things are forbidden, the more popular they become."
uᴉʞɥsnɯ > < mushkin
AlienPrime173 is offline
post #2 of 4 (permalink) Old 08-07-2015, 07:13 AM - Thread Starter
nobody really has insight on this?
uᴉʞɥsnɯ > < mushkin
post #3 of 4 (permalink) Old 08-07-2015, 07:19 AM - Thread Starter
I personally think OEM requests having 3 molex in order to use your connectors so you aren't over loading the PSU. It cannot be the wire or pin maximums as the molex string is wired in series....
uᴉʞɥsnɯ > < mushkin
post #4 of 4 (permalink) Old 08-09-2015, 02:57 PM
mandrix's Avatar
Rep: 170 (Unique: 116)
I use both an FC8 & FC9 in my rigs and have one wired with a single molex, the other is wired with m/f mini Tamiya connectors. No problems with either.
In my personal opinion, they only have multiple connectors to insure a good, solid electrical connection as poor current supply can cause problems pretty fast. I only use 4 pin molex when I just have to as a rule, I'm really surprised I haven't got around to changing out the molex on the FC9 to mini Tamiya connectors like the FC8.
Maximus VIII Hero/6700K delidded w/CLP @ 4.8/Corsair LPX 4x4GB 2666 OC'd @ 3200/PCS 390X w/EK blockMain Rig specs (Click to show)
White Case Labs SM8 w/dual pedestals-Custom top extension
Rigid acrylic tubing/Dual D5's-MCP35x2
3x480mm-1x240mm Radiators
All psu wiring & sleeving by myself
2xAquaero 5 Pro's w/c - 1xFC8 for light panel & various led's
PowerColor PCS 390X w/EK block
6700K/Maximus VIII Hero/Corsair 4x4GB RAM
Build Logs (Click to show)Validations (Click to show)
mandrix is offline
