PSU modding for higher +5v output for retro PC - Overclock.net - An Overclocking Community
post #1 of 1 (permalink) Old 02-29-2020, 11:43 AM - Thread Starter
no regurts
Kalm_Traveler's Avatar
Rep: 7 (Unique: 6)
Hey guys I have nearly finished my first (and hopefully only) retro rig but the PSU situation has been the only thing holding me back from completion.
As I found out during this adventure, pre-mid 2000's, PCs were mainly +5v and +3.3v rail heavy with not much load on the +12v rail. The core of my retro rig is a dual socket 370 Pentium III workstation board so at the tail end of that era.
This all being said, it won't boot up even with a new Corsair HX1200i which should have enough +5v and +3.3v amps to turn it on I would have thought (has 30A on both of those).
I ended up buying an old Enermax PSU which has 36A on +3.3v and 45A on +5v and that powers it just fine - drawback being that it's 20ish years old and I don't trust the capacitors. I tried replacing them with new ones that I thought were the correct type per the numbers on the sides but after doing that the PSU itself wouldn't turn on - standby power is there and if you try to turn it on it will kick on for about 1 second but then go back to standby.
So this brought me back to an earlier idea that I want to see if you guys think would work.
It occurred to me that perhaps the 1200i won't boot the machine up due to low load on the +12v line that is what we've been using in PCs since mid 2000's, even though it should theoretically have enough amps on the other 2 rails for the old MB and since I want more +5v amps anyway:
Might it work to sever the +5v rail internally and instead of using that one, connect a +12v to +5v buck converter to the +12v rail and feed the +5v rail spot on the part of the PSU where all the modular plugs connect? That way there will be some load on the +12v rail, and I think i can find a 50A +12v to +5v passively cooled buck converter that should fit into the PSU housing.
What do you guys think?
HEDT Overkill
Core i9 10980xe
Asus Rampage VI Extreme Omega
Titan RTX
Titan RTX
G.Skill Trident-Z RGB
Samsung 960 Pro
Samsung 850 EVO
Corsair AX1600i
Thermaltake Tower 900 - black
Operating System
Windows 10 Pro
LG 38GL950-G
Keyboard
Massdrop CTRL
Mouse
Speedlink Decus Respec
9900ks
Maximus XI Extreme
2080 Ti Kingpin
GSkill Trident Z RGB
Samsung 970 Evo Plus
Corsair HX1200
Cooler Master COSMOS C700M
Operating System
Windows 10 Pro
Asus PG348Q
Keyboard
Corsair K70 LUX RGB
Mouse
Corsair Ironclaw RGB
Audio
Klipsch ProMedia Ultra 5.1
Core i7 9750H
RTX 2080 Max-Q
Samsung 960 Pro
Keyboard
Razer Blackwidow TE Chroma V2
Mouse
Razer Mamba Wireless 2018
Kalm_Traveler is offline
