Hitachi SMART Error code mean? - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 11-26-2011, 03:12 PM - Thread Starter
diehardfan's Avatar
Rep: 0
One of my Hitachi 2TB, H3IK20003272SP, hard drive is giving me a SMART error. Ran the Hitachi Drive Fitness test tool and it gave me a Technical Result Code (TRC) 720023E1, anyone has any idea what this code means?
I have yet to hear back from Hitachi, as they are closed this US long weekend but was curious if anyone on this forum know it thumb.gif.
Thanks
diehardfan is offline
post #2 of 8 (permalink) Old 11-26-2011, 03:16 PM
notNOTmbudden
Rep: 690 (Unique: 508)
Download CrystalDiskInfo / HDTune and rerun the test. It'll tell you the results that people other than Hitachi can understand.
Flick of the wrist.
mbudden is offline
post #3 of 8 (permalink) Old 11-26-2011, 03:38 PM - Thread Starter
diehardfan's Avatar
Rep: 0
This drive is part of RAID 10, so I don't think it will work. Sorry should have mentioned that.
Or should I take it out of RAID and make it stand alone and run CrystalDiskInfo / HDTune? Currently I did take it out of RAID and make it a stand alone drive just to run the Hitachi test (its a bootable DOS tool), but not sure if I should let it run as a stand alone in Windows environment, as it might write something on it and further corrupt the data or am I wrong in thinking so?
Thanks
post #4 of 8 (permalink) Old 11-27-2011, 04:07 AM
Kramy's Avatar
Rep: 1075 (Unique: 804)
Thanks
Windows will write something and mess up your RAID array.
You may be able to get away with firing up a bootable Linux DVD (like SystemRescueCD) and then typing in some cryptic smartctl commands to get at the SMART info. It's not as user friendly as HDTune doing it for you, but it won't mess with your RAID...
http://www.sysresccd.org/Download
SystemRescueCD can boot to a desktop. Once you reach it you fire up Gparted to get your drive's /dev/[email protected] name. (last character varies) Then you use commands like this from the terminal:
Report SMART health of drive:
smartctl -a /dev/sda
Run a quick SMART test:
smartctl --test=short /dev/sda
Run an extended SMART test:
smartctl --test=long /dev/sda
One of the nice things about SystemRescueCD is if you're totally lost, it also has a web browser. Just navigate to this thread or search Google when you're stumped on syntax. thumb.gif
Kramy is offline
post #5 of 8 (permalink) Old 11-28-2011, 11:04 AM - Thread Starter
diehardfan's Avatar
Rep: 0
Kramy, thanks for the above post.
Just tried it, but when I run the SMART test both short and long, it does not give me any report/result of the scan. Just say the scan will take X long will finish in XX:XX:XX.
How do I access the reports?
Sorry I have zero knowledge in Linux OS.
Thanks
post #6 of 8 (permalink) Old 11-28-2011, 11:34 AM - Thread Starter
diehardfan's Avatar
Rep: 0
Never mind, figured it out smile.gif, it was right there.
Any idea what is wrong???
[email protected] /root % smartctl -a /dev/sda
smartctl 5.40 2010-10-16 r3189 [i486-pc-linux-gnu] (local build)
Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Hitachi Deskstar 7K2000
Device Model: Hitachi XXXXXXXX
Serial Number: XXXXXXXXXXXX
Firmware Version: JKAOA3EA
User Capacity: 2,000,398,934,016 bytes
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Mon Nov 28 13:30:31 2011 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 24) The self-test routine was aborted by
the host.
Total time to complete Offline
data collection: (21889) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 133 133 054 Pre-fail Offline - 100
3 Spin_Up_Time 0x0007 121 121 024 Pre-fail Always - 625 (Average 568)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 80
5 Reallocated_Sector_Ct 0x0033 001 001 005 Pre-fail Always FAILING_NOW 2012
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 119 119 020 Pre-fail Offline - 36
9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 9094
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 80
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 105
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 105
194 Temperature_Celsius 0x0002 146 146 000 Old_age Always - 41 (Min/Max 21/54)
196 Reallocated_Event_Count 0x0032 001 001 000 Old_age Always - 2026
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 3
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 2301 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 2301 occurred at disk power-on lifetime: 9066 hours (377 days + 18 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 fb 54 de 5e 0a Error: UNC at LBA = 0x0a5ede54 = 173989460
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
42 00 00 4f d9 5e 40 00 19d+02:02:06.981 READ VERIFY SECTOR(S) EXT
42 00 00 4f c9 5e 40 00 19d+02:02:06.768 READ VERIFY SECTOR(S) EXT
42 00 01 4e c9 5e 40 00 19d+02:02:06.613 READ VERIFY SECTOR(S) EXT
35 00 01 4e c9 5e 40 00 19d+02:02:06.552 WRITE DMA EXT
42 00 00 4d c2 5e 40 00 19d+02:01:49.271 READ VERIFY SECTOR(S) EXT
Error 2300 occurred at disk power-on lifetime: 9066 hours (377 days + 18 hours)
40 51 ff 4e c9 5e 0a Error: UNC at LBA = 0x0a5ec94e = 173984078
42 00 01 4c c2 5e 40 00 19d+02:01:49.117 READ VERIFY SECTOR(S) EXT
35 00 01 4c c2 5e 40 00 19d+02:01:49.057 WRITE DMA EXT
42 00 00 c5 bb 5e 40 00 19d+02:01:31.682 READ VERIFY SECTOR(S) EXT
42 00 00 c5 ab 5e 40 00 19d+02:01:31.364 READ VERIFY SECTOR(S) EXT
Error 2299 occurred at disk power-on lifetime: 9066 hours (377 days + 18 hours)
40 51 79 4c c2 5e 0a Error: UNC at LBA = 0x0a5ec24c = 173982284
42 00 00 c5 9b 5e 40 00 19d+02:01:31.047 READ VERIFY SECTOR(S) EXT
42 00 00 c5 8b 5e 40 00 19d+02:01:30.729 READ VERIFY SECTOR(S) EXT
42 00 00 c5 7b 5e 40 00 19d+02:01:30.514 READ VERIFY SECTOR(S) EXT
Error 2298 occurred at disk power-on lifetime: 9066 hours (377 days + 18 hours)
40 51 df c4 6b 5e 0a Error: UNC at LBA = 0x0a5e6bc4 = 173960132
42 00 00 a3 5e 5e 40 00 19d+02:01:12.604 READ VERIFY SECTOR(S) EXT
42 00 00 a3 4e 5e 40 00 19d+02:01:12.184 READ VERIFY SECTOR(S) EXT
42 00 00 a3 3e 5e 40 00 19d+02:01:11.969 READ VERIFY SECTOR(S) EXT
42 00 00 a3 2e 5e 40 00 19d+02:01:11.651 READ VERIFY SECTOR(S) EXT
42 00 00 a3 1e 5e 40 00 19d+02:01:11.334 READ VERIFY SECTOR(S) EXT
Error 2297 occurred at disk power-on lifetime: 9066 hours (377 days + 18 hours)
40 51 5b a2 ce 33 0a Error: UNC at LBA = 0x0a33cea2 = 171167394
42 00 00 fd bf 33 40 00 19d+01:58:26.634 READ VERIFY SECTOR(S) EXT
42 00 00 fd af 33 40 00 19d+01:58:26.418 READ VERIFY SECTOR(S) EXT
42 00 00 fd 9f 33 40 00 19d+01:58:26.101 READ VERIFY SECTOR(S) EXT
42 00 00 fd 8f 33 40 00 19d+01:58:25.783 READ VERIFY SECTOR(S) EXT
42 00 00 fd 7f 33 40 00 19d+01:58:25.467 READ VERIFY SECTOR(S) EXT
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Aborted by host 80% 9094 -
# 2 Short offline Completed without error 00% 9093 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
post #7 of 8 (permalink) Old 11-28-2011, 08:38 PM
Kramy's Avatar
2000+ bad sectors. It's safe to say the drive is dying and needs to be replaced.
Those sets of three numbers "001 001 005" are apparently health percentages. I'm not sure what they stand for, but "100%" is probably good and "1%" or "5%" is probably bad. Considering how high the first two numbers are, I'm inclined to believe that the drive is in very poor health.
This also worries me a bit:
I've had drives die with far fewer errors recorded than that.
Kramy is offline
post #8 of 8 (permalink) Old 11-29-2011, 10:34 PM - Thread Starter
diehardfan's Avatar
Rep: 0
Thanks Kramy for the report and help.
Sending the drive back to Hitachi for RMA, so should get a replacement soon.
Thanks
