Need a in-depth DIFFERENCE between these 3 WD hdd's :) - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 05-04-2016, 11:35 PM - Thread Starter
MrITguru87's Avatar
Rep: 0
advantages, disadvantages, and recommended use:
1. WD Blue 4TB Model WD40EZRZ
2. WD Blue SSHD 4TB Model WD40E31X
3. WD Black 4TB Model WD4003FZEX
4. WD Re 4TB Model WD4000FYYZ
Need to compare in detail there specification such as spin rate,cache,capacity and elaborate if one of the models has a unique feature of the other model for eg. If one model has a higher spin rate explain to me what this means in terms of hard drive performance?thumb.gif. I've been looking for ages all i can really find is just the basic specifications of each hard drive ?? I need to know the differences and compare between the 3 if anyone can help? redface.gif
MrITguru87 is offline
post #2 of 5 (permalink) Old 05-05-2016, 02:11 AM - Thread Starter
MrITguru87's Avatar
Rep: 0
post #3 of 5 (permalink) Old 05-05-2016, 01:28 PM
Linux Lobbyist
Deuce65's Avatar
Rep: 47 (Unique: 44)
Western digital's website has detailed specs for each of the drives.
Deuce65 is offline
post #4 of 5 (permalink) Old 05-05-2016, 01:33 PM
KaffieneKing's Avatar
Rep: 68 (Unique: 62)
1. Standard basic model with the lowest speed, durability and warranty, also the cheapest
2. For when you cant afford an SSD as your boot drive but otherwise the same as 1.
3. Faster than 1, more expansive than 1 with a slightly better warranty (I think)
4. Probably not any faster than 1 but is more durable and rated for 24/7 use, longer warranty
But all this stuff is on Western Digital's website, just saying.
KaffieneKing is offline
post #5 of 5 (permalink) Old 05-05-2016, 01:57 PM
Senioritis Member
Lady Fitzgerald's Avatar
Rep: 513 (Unique: 323)
You are close:
This a basic storage drive. The 7200 rpm models are faster than the 5400 rpm models. The 5400 rpm models use a bit less power than the 7200 rpm models and will be slower. Warranty is two years. I use the predecessor to the 5400 rpm Blues, the Greens, for my backup drives since they cost less and are in service only an average of a few minutes a day while updating backups (the rest of the time, the are stored in a drawer).
This is an HDD with a small SSD cache (typically 8GB). Some people may get a slight performance increase but most do not, especially when used for storage only. The prices of SSDs have dropped enough that there is no real advantage to an SSHD.
It has a much better warranty than 1; five years. This the drive I use for storage in my desktop machine since I run it 24/7. It's increased reliability and speed and longer warranty make it well worth the extra expense.
The Reds are intended for use in RAID. They tend to get poorer reviews than the Blues and Blacks. I do not recommend them.
Jeannie
i7-3930k
ASUS P9X79 WS
MSI R7850 Twin Frozr 2GD5/OC Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Monoprice 1x2 powered HDMI Splitter
Kingston HyperX 32GB (8 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K8/32GX
128GB Samsung 840 Pro SSD
4TB Samsung 850 EVO SSD
Optical Drive
LG 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive CH12LS28
Corsair HX750W
COOLER MASTER GeminII S524 120mm Long Life Sleeve CPU Cooler
Antec Two Hundred v2
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Logitech M525 with Unifying Receiving
Audio
Corsair SP2500 2.1 Speakers
Audio
ASUS Xonar Essence STX Virtual 7.1 Channels 24-bit 192KHz PCI Express x1 Interface 124 dB SNR / Headphone AMP Card
Other
LSI 9211-8i HBA card
Other
HooToo® HT-CR001 3.5" PCI-E to USB 3.0 Multi-in-One Front Panel Internal Card Reader (6 Memory Slots, Genesys GL3220 Chipset) & SuperSpeed USB 3.0 3-Port Hub (VIA VL800 Chipset), can read & write: M2/MS Micro, High-Speed CF(UDMA), UHS-I, SD, SDHC,...
Other
StarTech HSB220SAT25B 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane
i7-5930K Haswell-e
Asus X99-E WS/USB 3.1
Visiontek Radeon 7870 2GB with 6 miniDisplayports
G-Skill Ripjaws 64GB (8x8GB) DDR4 2133
Samsung 850 EVO 4TB SSDs
Samsung 950 Pro 512GB m.2 SSD boot drive
Corsair AX760
Noctua NH-D15S Cpu cooler
Scratch built. Currently under construction at https://www.overclock.net/t/1602023/preparing-for-a-scratch-built-case
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
El Cheapo Allsop hard plastic
Lady Fitzgerald is offline
