Fake-Optane? 1TB NVME, I want to set up a 256GB partition and use that as a buffer to load to a standard drive, or not.. - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 02-06-2019, 09:29 PM - Thread Starter
Rep: 0
I have a 1TB NVME 970 Pro. I want to set up a partition of 256GB or so, so that it can be used the same way as Windows 10 uses memory ( On startup the most used programs, apps, whatever.. are loaded into memory for speed )... I want the most used programs, files, etc.. to be moved to that partition so they are loaded faster.. I want to be able to load all of my games on a standard hard-drive, then as I load them they be moved to the NVME drive, or the more the files are used, they are moved over... As I stop using something, the files are removed.
I don't care if a copy always remains on the other hard-drive.
Does software like this exist? And, yes.. It would need to be a driver...
I know AMD has some type of software like this, and Intel has Optane which acts as a buffer between the hard-drive.. But is there something so I can use my own drive or do I have to purchase an Optane drive specifically for that ( but with the limited PCI-E lanes it wouldn't work but at SATA speeds )...
Acecool is offline
post #2 of 3 (permalink) Old 02-07-2019, 12:53 PM
Not New to OCN
100cotton's Avatar
Rep: 92 (Unique: 86)
I think what you're looking for would be SSD caching for your HDD. I myself am not sure how to set it up.
How much data do you actually have total? In my opinion, it's far easier to place your OS and all programs on the SSD, and then a HDD can store the bulk of your games, pictures, videos, etc. If you're playing a game consistently at any point in time, it's not much of a hassle to transfer it to the SSD, and remove it when sometime later when you don't play it anymore.
My System
(19 items)
i7 5820k - 4.4GHz
MSI X99S Sli Plus
PNY GTX 1080
G.Skill 4x4GB DDR4 3000Mhz
Samsung 960 EVO 500GB
Seagate Barracuda 2TB x2 - Raid 1
Corsair HX750
EKWB A240G
Cooler Master 690 ii Advanced
Operating System
Win7 x64
DELL S2716DG 27"
Asus VH226H 21.5"
Asus VH226H 21.5"
Keyboard
Logitech G510
Mouse
Logitech G502 Proteus Core RGB
Audio
Gamecon 780 Headset
Audio
Corsair SP2500 2.1
Other
Mount It! Triple Monitor Stand
Other
Rosewill RNX-N150PCe Wireless Card
100cotton is offline
post #3 of 3 (permalink) Old 02-07-2019, 01:04 PM
deepor's Avatar
Rep: 464 (Unique: 312)
I remember hearing the name "PrimoCache". This here seems to be their website:
https://www.romexsoftware.com/en-us/primo-cache/
I never tried that tool, so no idea if it works well or not.
deepor is offline
