M.2 Suggestions for a Sabertooth X99 build - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 06-09-2019, 11:44 AM - Thread Starter
Rep: 3 (Unique: 3)
just looking for a COMPATIBLE m.2 drive for my Asus Sabertooth X99 to move Adobe Premiere and OS onto. Having difficulty searching for updated compatibility lists and suggestions for my specific motherboard.
Currently using the 840 EVO SSD. Just figured I could use an easy upgrade while I use the current SSD as the scratch drive when rendering. thx
My 2010-2014 Build (in progress...)
Wildblade is offline
post #2 of 6 (permalink) Old 08-21-2019, 05:41 PM - Thread Starter
Rep: 3 (Unique: 3)
anyone have any suggestions? still looking to upgrade the SSD to an M.2
post #3 of 6 (permalink) Old 08-21-2019, 05:48 PM
Overclocking Enthusiast
ozlay's Avatar
Rep: 274 (Unique: 219)
It supports nvme only. So a 970 evo plus should work. Or any other nvme ssd. It shares bandwidth with the bottom x16 slot. So you can't use the bottom pcie x16 slot if you are using the m.2 slot.
In Loving Memory Of Kassandra
Kaby
Rikka
(9 items)
Intel I5-7600k
Asrock Z270M Extreme 4
Titan X
Gskill Royal
970 Evo
Optane 900p
Seasonic Prime Snow
enthoo evolv matx tempered glass
Operating System
windows 10 pro
ozlay is offline
post #4 of 6 (permalink) Old 08-21-2019, 05:56 PM
Rep: 4 (Unique: 4)
I suspect you would be OK with any modern M key NVME drive, with the proviso that some people report heat issues with fast NVME drives on that motherboard.
clannagh is offline
post #5 of 6 (permalink) Old 08-21-2019, 07:43 PM
Overclocker in training
ThrashZone's Avatar
Rep: 71 (Unique: 55)
Hi,
Any m series m.2 basically
I have a 970 evo 500gb in my x99 sabertooth now
I also have a 970 evo plus in my x299 could swap out no problem
All m.2 get warm so a heat sink is required no matter which you get x99 mother board is no hotter than x299
I added these to mine work pretty good little pricey but I don't mind it was this or pointing a fan directly at it
If you get one don't forget the 2-3 year warranty on it no telling how long the little fan will live.
https://www.amazon.com/Advancing-Gen...tronics&sr=1-3
I returned some XPG 8200 pro m.2's they were so off speed spec's
970's hit spec's no problem and of course samsung is second to none support wise.
One bad thing to think about on the sabertooth is the plastic shielding
I've removed all mine and have room for a good heat sink
The shielding may limit or actually prevent adding a heat sink so be prepared to point a fan of some size at it like a little 50-60mm or something.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #6 of 6 (permalink) Old 08-22-2019, 12:36 AM
Senior OCN Member
shilka's Avatar
Rep: 2747 (Unique: 1629)
Samsung M.2 NVME drives are overpriced and a drive with the Toshiba E12 controller are almost as good and way cheaper
https://www.overclock.net/forum/355-...2-toshiba.html
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
